求助 CUBE 写24C02 存入32位数据和读出问题
lvning296 提问时间:2017-9-6 17:13 /
求:想用存入一组数据32位;然后相对应的位置读出相关内容; 只存16个的时候可以存入但大于16的时候数据就没法存入;还请教给完大神。
部分代码;如何把这组数据全部存入和相对应的读出来
        I2C_WriteBuffer[0]= 0;
        I2C_WriteBuffer[1] = 1;
        I2C_WriteBuffer[2]= 2;
        I2C_WriteBuffer[3] = 3;
        I2C_WriteBuffer[4]= 4;
        I2C_WriteBuffer[5] = 5;
        I2C_WriteBuffer[6]= 6;
        I2C_WriteBuffer[7] = 7;
        I2C_WriteBuffer[8]= 8;
        I2C_WriteBuffer[9] = 9;
        I2C_WriteBuffer[10]= 10;
        I2C_WriteBuffer[11] = 11;
        I2C_WriteBuffer[12]= 12;
        I2C_WriteBuffer[13] = 13;
        I2C_WriteBuffer[14]= 14;
        I2C_WriteBuffer[15] = 15;
        //5通道
        I2C_WriteBuffer[16]= 16;
        I2C_WriteBuffer[17] = 17;
        I2C_WriteBuffer[18]= 18;
        I2C_WriteBuffer[19] = 19;
                I2C_WriteBuffer[20]= 20;
        I2C_WriteBuffer[21] = 21;
        I2C_WriteBuffer[22]= 22;
        I2C_WriteBuffer[23] =23;
        I2C_WriteBuffer[24]= 24;
        I2C_WriteBuffer[25] = 25;
        I2C_WriteBuffer[26]= 26;
        I2C_WriteBuffer[27] = 27;
        I2C_WriteBuffer[28]= 28;
        I2C_WriteBuffer[29] = 29;
        I2C_WriteBuffer[30]= 30;
        I2C_WriteBuffer[31] = 31;
                                           for(i = 0; i<32; i+=8){
                                                         HAL_I2C_Mem_Write(&hi2c2, ADDR_24LCxx_Write, i, I2C_MEMADD_SIZE_8BIT,&I2C_WriteBuffer[i],8,0xff);
                                                        //读
                                                HAL_I2C_Mem_Read(&hi2c2, ADDR_24LCxx_Read, 0, I2C_MEMADD_SIZE_8BIT,&I2C_ReadBuffer[0],32, 0xff);
                                                  HAL_GPIO_WritePin(GPIOB, GPIO_PIN_5, GPIO_PIN_SET);
        printf("I2C_ReadBuffer ");
        HAL_GPIO_TogglePin(GPIOB,GPIO_PIN_5);
                                                        for(i=0; i<32; i++)
        printf("0x%02X  ",I2C_ReadBuffer[i]);
赞 收藏 评论5 发布时间:2017-9-6 17:13
5个回答
lvning296 回答时间:2017-9-6 17:49:38
        printf("\r\n EEPROM 24C02 Write \r\n");
        for(i = 0;i<32;i++){
        printf("0x%02X  ",I2C_WriteBuffer);
        //HAL_I2C_Mem_Read(&hi2c2, ADDR_24LCxx_Read, 0, I2C_MEMADD_SIZE_8BIT,I2C_ReadBuffer,BufferSize, 0x10);
        //读
                                                        //  HAL_I2C_Mem_Read(&hi2c2, ADDR_24LCxx_Read, 1, I2C_MEMADD_SIZE_8BIT,&I2C_ReadBuffer[8],8,0x10);
                                                        if( HAL_I2C_Mem_Read(&hi2c2, ADDR_24LCxx_Read, 0, I2C_MEMADD_SIZE_8BIT,I2C_ReadBuffer,32,0x10) == HAL_OK){
        printf("\r\n EEPROM 24C02 READ0 \r\n");
        printf("0x%02X  ",I2C_ReadBuffer);
这个存入后,读出来第16位和7重复了
EEPROM 24C02 Write
0x00  0x01  0x02  0x03  0x04  0x05  0x06  0x07  0x08  0x09  0x0A  0x0B  0x0C  0x0D  0x0E  0x0F  0x10  0x11  0x12  0x13  0x14  0x15  0x16  0x17  0x18  0x19  0x1A  0x1B  0x1C  0x1D  0x1E  0x1F
EEPROM 24C02 READ0
0x00  0x01  0x02  0x03  0x04  0x05  0x06  0x07  0x08  0x09  0x0A  0x0B  0x0C  0x0D  0x0E  0x0F  0x11  0x11 0x12  0x13  0x14  0x15  0x16  0x17  0x18  0x19  0x1A  0x1B  0x1C  0x1D  0x1E  0x1F
Dandjinh 回答时间:2017-9-6 19:11:23
写的时候要注意下,换page的时候要等5ms,读的时候可以一次性读
参与人数 1ST金币 +2 收起 理由
lvning296 回答时间:2017-9-6 20:32:43
我这样存 老是存不了后面的16个数组 下面是我存入和读取方法 是哪里不正确;存入我加入延时就读取不了
//存入EEprom
        if(HAL_I2C_Mem_Write(&hi2c2, ADDR_24LCxx_Write, 0, I2C_MEMADD_SIZE_8BIT,&I2C_WriteBuffer[0],16, 0x10) == HAL_OK)
        else
                                                        //HAL_Delay(500);
                                                          if(HAL_I2C_Mem_Write(&hi2c2, ADDR_24LCxx_Write, 2, I2C_MEMADD_SIZE_8BIT,&I2C_WriteBuffer[16],16, 0x10) == HAL_OK)
        else
        //读------------------------------
                                                        if( HAL_I2C_Mem_Read(&hi2c2, ADDR_24LCxx_Read, 0, I2C_MEMADD_SIZE_8BIT,I2C_ReadBuffer,32,0xFF) == HAL_OK){
Dandjinh 回答时间:2017-9-7 09:55:07
24C02一页的大小是8,所以写入的时候每到8的倍数的时候要等5ms换页
给你两个写入函数做参考
  1. static HAL_StatusTypeDef EepromWriteSinglePage(uint8_t page, uint8_t *data, uint8_t len)
  2. {
  3.         HAL_StatusTypeDef ret;
  4.         uint16_t pos = page * EEPROM_PAGE_SIZE;
  5.
  6.         wrFlag = IIC_TX_BUSY;
  7.
  8.         ret = HAL_I2C_Mem_Write_DMA(&hi2c1, EEPROM_ADDRESS, pos, I2C_MEMADD_SIZE_8BIT, data, len);
  9.         osDelay(5);
  10.
  11.         while (wrFlag != IIC_TX_FREE);
  12.
  13.         return ret;
  14. }
  15. static HAL_StatusTypeDef EepromWritePages(uint8_t startPage, uint8_t *data, uint8_t len)
  16. {
  17.         uint8_t pageSum, dataLeft, i;
  18.         HAL_StatusTypeDef ret;
  19.
  20.         pageSum = len / EEPROM_PAGE_SIZE;
  21.         dataLeft = len - pageSum * EEPROM_PAGE_SIZE;
  22.
  23.         for (i=0; i<pageSum; i++, data += EEPROM_PAGE_SIZE)
  24.         {
  25.                 ret = EepromWriteSinglePage(startPage + i, data, EEPROM_PAGE_SIZE);
  26.                 if (ret != HAL_OK)
  27.                 {
  28.                         break;
  29.                 }
  30.         }
  31.
  32.         if (i != pageSum)
  33.         {
  34.                 return ret;
  35.         }
  36.         else
  37.         {
  38.                 if (dataLeft > 0)
  39.                 {
  40.                         return EepromWriteSinglePage(startPage + i, data, dataLeft);
  41.                 }
  42.         }
  43.
  44.         return HAL_OK;
  45. }
lvning296 回答时间:2017-9-7 20:14:23
给你两个写入函数做参考
谢谢;  还想请教下 IIC_TX_BUSY  和 IIC_TX_FREE 这两个是如何定义的
