STMF407VE FSMC配置LCD失败
ZXiang 提问时间:2017-9-15 14:35 /
悬赏5ST金币已解决
FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
         FSMC_NORSRAMTimingInitTypeDef  readWriteTiming;
FSMC_NORSRAMTimingInitTypeDef  writeTiming;
//使能FSMC时钟
RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC,ENABLE);
//使能PORTB,D,E,时钟
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB|RCC_AHB1Periph_GPIOD|RCC_AHB1Periph_GPIOE, ENABLE);
//LCD使能I/O设置
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
         /*FSMC
         * data lines,FSMC-D0~D15: PD 0 1 8 9 10 14 15,PE 7 8 9 10 11 12 13 14 15
         * PD4-FSMC_NOE  CD-RD PD4
         * PD5-FSMC_NWE  CD-WR PD5
         * PD7-FSMC_NE1  CD-CS PD7
         * PD11-FSMC_A18 CD-DC PD13
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
   GPIO_Init(GPIOD,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
         GPIO_Init(GPIOE,&GPIO_InitStructure);
         //复用映射
         GPIO_PinAFConfig(GPIOD,GPIO_PinSource0,GPIO_AF_FSMC);
         GPIO_PinAFConfig(GPIOD,GPIO_PinSource1,GPIO_AF_FSMC);
         GPIO_PinAFConfig(GPIOD,GPIO_PinSource4,GPIO_AF_FSMC);
         GPIO_PinAFConfig(GPIOD,GPIO_PinSource5,GPIO_AF_FSMC);
         GPIO_PinAFConfig(GPIOD,GPIO_PinSource7,GPIO_AF_FSMC);
         GPIO_PinAFConfig(GPIOD,GPIO_PinSource8,GPIO_AF_FSMC);
         GPIO_PinAFConfig(GPIOD,GPIO_PinSource9,GPIO_AF_FSMC);
         GPIO_PinAFConfig(GPIOD,GPIO_PinSource10,GPIO_AF_FSMC);
         GPIO_PinAFConfig(GPIOD,GPIO_PinSource13,GPIO_AF_FSMC);
         GPIO_PinAFConfig(GPIOD,GPIO_PinSource14,GPIO_AF_FSMC);
         GPIO_PinAFConfig(GPIOD,GPIO_PinSource15,GPIO_AF_FSMC);
         GPIO_PinAFConfig(GPIOE,GPIO_PinSource7,GPIO_AF_FSMC);
         GPIO_PinAFConfig(GPIOE,GPIO_PinSource8,GPIO_AF_FSMC);
         GPIO_PinAFConfig(GPIOE,GPIO_PinSource9,GPIO_AF_FSMC);
         GPIO_PinAFConfig(GPIOE,GPIO_PinSource10,GPIO_AF_FSMC);
         GPIO_PinAFConfig(GPIOE,GPIO_PinSource11,GPIO_AF_FSMC);
         GPIO_PinAFConfig(GPIOE,GPIO_PinSource12,GPIO_AF_FSMC);
         GPIO_PinAFConfig(GPIOE,GPIO_PinSource13,GPIO_AF_FSMC);
         GPIO_PinAFConfig(GPIOE,GPIO_PinSource14,GPIO_AF_FSMC);
         GPIO_PinAFConfig(GPIOE,GPIO_PinSource15,GPIO_AF_FSMC);
//地址建立时间(ADDSET)为16个HCLK 1/168M=96ns
readWriteTiming.FSMC_AddressSetupTime = 0xf;
//地址保持时间(ADDHLD)模式A未用到
readWriteTiming.FSMC_AddressHoldTime = 0x00;
//数据保存时间为60个HCLK,因为液晶驱动IC的读数据的时候,速度不能太快
readWriteTiming.FSMC_DataSetupTime = 60;
readWriteTiming.FSMC_BusTurnAroundDuration = 0x00;
readWriteTiming.FSMC_CLKDivision = 0x00;
readWriteTiming.FSMC_DataLatency = 0x00;
//模式A
readWriteTiming.FSMC_AccessMode = FSMC_AccessMode_A;
//地址建立时间(ADDSET)为9个HCLK
writeTiming.FSMC_AddressSetupTime = 9;
writeTiming.FSMC_AddressHoldTime = 0x00;
//数据保存时间为8个HCLK
writeTiming.FSMC_DataSetupTime = 8;
writeTiming.FSMC_BusTurnAroundDuration = 0x00;
writeTiming.FSMC_CLKDivision = 0x00;
writeTiming.FSMC_DataLatency = 0x00;
//模式A
writeTiming.FSMC_AccessMode = FSMC_AccessMode_A;
//使用NE1
FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;
//不复用数据地址
FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
//FSMC_MemoryType_SRAM;  //SRAM
FSMC_NORSRAMInitStructure.FSMC_MemoryType =FSMC_MemoryType_SRAM;
//存储器数据宽度为16bit
FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
//FSMC_BurstAccessMode_Disable
FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode =FSMC_BurstAccessMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;
FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
//存储器写使能
FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
//读写使用不同的时序
FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Enable;
FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
//读写时序
FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &readWriteTiming;
//写时序
FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &writeTiming;
//初始化FSMC配置
FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
//使能BANK1
         FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);
Delay_ms(50);
         printf("5555555555555\r\n");
LCD_Write(0x0000,0x0001);/*程序卡死在这*/
         printf("6666666666666\r\n");
Delay_ms(50);
//ID 9325
LCD_infor.ID = LCD_Read(0x0000);
         printf("ID:%x\r\n",LCD_infor.ID);
最佳答案
查看完整内容
给你个STM32F103ZET6的程序,得按套路来。 ILI9325屏比较经典,在开发板STM3210E上用的就是这个屏,在其它开发板中也见到用这个屏的。
赞 收藏 2 评论3 发布时间:2017-9-15 14:35
3个回答
七哥 回答时间:2017-9-15 14:35:54
液晶屏TFT测试程2.rar (1.14 MB, 下载次数: 7)
参与人数 1蝴蝶豆 +3 收起 理由
zero99 + 3
wenyangzeng 回答时间:2018-1-15 09:44:42
貌似没有看到楼主配置FSMC读写地址
typedef struct
  __IO uint16_t LCD_REG;
  __IO uint16_t LCD_RAM;
} LCD_TypeDef;
#define LCD_BASE           ((uint32_t)(0x60000000 | 0x0C000000))
#define LCD                ((LCD_TypeDef *) LCD_BASE)
参与人数 1蝴蝶豆 +3 收起 理由
zero99 + 3
海迹天涯 回答时间:2018-1-15 11:08:46
给你顶起
