请教下,播放flac音乐时,屏幕有干扰,是怎么回事啊 ?
hpdell 提问时间:2017-9-19 20:04 /
刚开始时貌似有地方卡住了的感觉,会发出卡卡卡的使用,但是过一会就好了,声音就正常播放了,只是屏幕有干扰发生,不知道是怎么情况 ???
播放部分代码如下:
int flac_play_song(char* path)
  FLACContext fc;
  int fd;
  int n;
  int bytesleft;
  int consumed;
  char tmp[20];
  static volatile int8_t i;
  unsigned char *filebuf;
  unsigned short *temp_buffer;
  char value=0;
  uint8_t res;
  int16_t *PCM_buffer0=0;
  int16_t *PCM_buffer1=0;
  uint8_t *p8;
  UINT br;
  u32 flac_fptr=0;
  char PlayAddr[100] = {0};
  strcpy(PlayAddr, (const char *)path);
  audiodev.file = (FIL*)mymalloc(SRAMDTCM,sizeof(FIL));
  res=f_open(audiodev.file,(char*)PlayAddr,FA_READ); //读取文件错误
  if(res!=FR_OK)
    myfree(SRAMDTCM, audiodev.file);
    return 0xff;
  flacctrl      = mymalloc(SRAMDTCM,sizeof(__flacctrl));
  /* Read the metadata and position the file pointer at the start of the
   first audio frame */
  flac_init(audiodev.file,  flacctrl,  &fc);
    dump_headers(&fc);
    f_lseek (audiodev.file , audiodev.file->fptr);
    printf("波特率:%dKbps\n\r\n",fc.bitrate);
    printf("采样率:%d\n\r\n",fc.samplerate);
    if (fc.length/1000%60>=10)
    printf("总时间:%d:%d\n\r\n",fc.length/1000/60, fc.length/1000%60);
    else
    printf(tmp,"总时间:%d:0%d\n\r\n",fc.length/1000/60, fc.length/1000%60);
    printf("块大小:%d\n\r\n",fc.max_blocksize);
    PCM_buffer0 = (int16_t *)mymalloc(SRAMEX,MAX_BLOCKSIZE * MAX_CHANNELS * 2);
    PCM_buffer1 = (int16_t *)mymalloc(SRAMEX,MAX_BLOCKSIZE * MAX_CHANNELS * 2);
    filebuf = (uint8_t *)mymalloc(SRAMEX,MAX_FRAMESIZE * 2);    //内存分配.
    if (filebuf==NULL)
        printf("\n\r no mem!!\n\r\n");
        goto fail;
    temp_buffer= (unsigned short *)mymalloc(SRAMEX,MAX_FRAMESIZE * MAX_CHANNELS * 2);    //内存分配.
    if((fc.min_blocksize != fc.max_blocksize) || (fc.max_blocksize > MAX_BLOCKSIZE ) || (fc.max_framesize > MAX_FRAMESIZE))
        printf("\n\rOo Do not support this file!!\n\r\n");
        printf("You can choose another Converter.Such as foobar2000 ^_^\n\r\n");
        goto fail;
    audiodev.i2sbuf1 = (uint8_t *)PCM_buffer0;
    audiodev.i2sbuf2 = (uint8_t *)PCM_buffer1;
    FLAC_Stop();
    FLAC_EnterPlayMode();    //进入播放模式
    FLAC_SaiConfInit(flacctrl->bps, flacctrl->samplerate, flacctrl->outsamples);
    __LTDC_drv->LTDC_DispStringAt(5, 375, LCD_COLOR_BLUE,               //显示当前播放的 .wav文件名字
                              LCD_COLOR_WHITE,
                              &FontAscii8x16,
                              (const uint8_t *)PlayAddr);
        f_read(audiodev.file,filebuf,MAX_FRAMESIZE,&br);//读取最大帧长数据
        bytesleft = br;
        flac_fptr = audiodev.file->fptr;    //记录当前的文件位置.
    FLAC_Start();                    //开始播放
    while (bytesleft)
      while(audiodev.AudioTransferEnd==0)//等待传输完成
      audiodev.AudioTransferEnd=0;
            if(audiodev.AudioSwitchBuf == 0)
        p8 = audiodev.i2sbuf1;
            else
        p8 = audiodev.i2sbuf2;
      fc.decoded0 = (int32_t *)p8;
      fc.decoded1 = (int32_t *)temp_buffer;
       flac_decode_frame(&fc,filebuf,bytesleft,(int16_t *)p8);
        consumed=fc.gb.index/8;
        rt_memmove(filebuf,&filebuf[consumed],bytesleft-consumed);
        bytesleft-=consumed;
        f_read(audiodev.file, &filebuf[bytesleft],MAX_FRAMESIZE-bytesleft, &br);
        if (br > 0)
            bytesleft+=br;
        flac_fptr=audiodev.file->fptr;    //记录当前的文件位置.
        while(audiodev.status&(1<<1))    //正常播放中
          FLAC_MsgShow(audiodev.file); //得到总时间和当前播放的时间
          audiodev.totsec=flacctrl->totsec;        //参数传递
          audiodev.cursec=flacctrl->cursec;
          audiodev.bitrate=flacctrl->bitrate;
          audiodev.samplerate=flacctrl->samplerate;
          audiodev.bps=flacctrl->bps;
            if(audiodev.status&0X01)break;    //没有按下暂停
        //    else
        //    HAL_Delay(5);    // delay_ms(1000/OS_TICKS_PER_SEC);
        if((audiodev.status&(1<<1))==0)        //请求结束播放/播放完成
          break;
fail:
     Getmemtablestatus(); //获取内存块状态
   f_close(audiodev.file);
   myfree(SRAMDTCM,audiodev.file);
   myfree(SRAMDTCM,flacctrl);
        myfree(SRAMEX,PCM_buffer0);
      myfree(SRAMEX,PCM_buffer1);
      myfree(SRAMEX,filebuf);
        myfree(SRAMEX,temp_buffer);
    return value;
具体效果你可以看看这个视频
https://v.youku.com/v_show/id_XMz ... j.8428770.3416059.1
播放其他的 wav, mp3 都是完全没有任何问题的,而且只要不播放 flac ,显示完全正常
赞 收藏 评论11 发布时间:2017-9-19 20:04
11个回答
MrJiu 回答时间:2017-9-20 09:41:54
有干扰?是闪烁?屏幕是什么接口方式?
hpdell 回答时间:2017-9-24 22:36:32
MrJiu 发表于 2017-9-20 09:41
有干扰?是闪烁?屏幕是什么接口方式?
rgb接口的,但是播放ape,wav等音频屏幕显示非常好,就唯独这个 flac 音频就不行,估计应该是什么地址搞错了,但是具体的也不清楚到底是哪里出了问题,播放 flac 音频时,声音貌似还可以
MrJiu 回答时间:2017-9-25 09:00:55
hpdell 发表于 2017-9-24 22:36
rgb接口的,但是播放ape,wav等音频屏幕显示非常好,就唯独这个 flac 音频就不行,估计应该是什么地址搞错 ...
你这里的屏幕闪烁指的是:乱码,还是数据闪烁?
hpdell 回答时间:2017-9-25 12:33:30
屏幕闪烁,目前指的显示貌似有干扰条纹出现,另外,显示的汉字乱码,但是 洋文显示正常,
等播放完 flac 文件 后,再播放其他 音频音乐时,此时播放出来的音乐貌似也不行,貌似有些断断续续的声音。
如果不播放 flac文件,连续播放 wav,mp3, ape 格式的都完全没有问题。
播放其他格式的 音乐,显示都是正常的,包括 中文。
MrJiu 回答时间:2017-9-25 13:49:41
等播放完 flac ...
你这么来说,我个人猜测,是不是屏幕的数据线受到干扰。。。
hpdell 回答时间:2017-9-25 22:33:55
具体效果你可以看看这个视频
hpdell 回答时间:2017-9-26 22:01:12
你好,我刚刚把 优化基本设置为最高貌似就可以了,
播放 flac 的文件屏幕不闪,但是 播放完后不能够播放其他 类型的 音乐文件了,
我的编译器使用的 是  iar
这个问题是不是说明 这个 flac 的库文件有些指针写的不支持 iar 编译器啊 ?
或者是需要修改哪里 ??
MrJiu 回答时间:2017-9-27 09:55:27
播放 flac 的文件屏幕不闪,但是 播放完后不能够播放 ...
我觉得乱码或者闪烁,就两个原因,要么显示数据有问题,要么数据线受到干扰。。。
参与人数 1ST金币 +2 收起 理由
hpdell 回答时间:2017-9-28 16:00:10
MrJiu 发表于 2017-9-27 09:55
我觉得乱码或者闪烁,就两个原因,要么显示数据有问题,要么数据线受到干扰。。。 ...
如果数据线收到干扰,那么播放 wav,MP3, ape 的音乐都完全不会闪烁啊
硬件都是一样的
这个程序我是移植 keil 工程的,现在把他移植到 iar 的工程上来,有没有可能是底层的有些不兼容造成的啊 ?
冰葑世纪 回答时间:2020-7-2 16:40:32
时隔3年,我竟遇到和楼主一样的问题,我使用的是MDK工程,H7芯片,现象和楼主的一模一样。请问楼主,当年有没有继续查根问底,找到根源处?除了优化外,有没有更好的解决办法?
hpdell 回答时间:2020-7-3 09:04:13
冰葑世纪 发表于 2020-7-2 16:40
时隔3年,我竟遇到和楼主一样的问题,我使用的是MDK工程,H7芯片,现象和楼主的一模一样。请问楼主,当年有 ...
貌似没有更换的办法,
后来也没有怎么去深入的研究了,比较使用 单片机 播放 flac 只是玩玩而已
