关于232转485的问题
weiyaogun 提问时间:2017-11-3 19:50 /
小弟初学,现在在做一个232转485的板子,目前在485这里出了问题,利用75176芯片进行ttl到485的变换,程序结构也挺简单,但是485要么无法进中断要么无法正确发出,求大神帮看看!
主程序在:
#include "stm32f10x.h"
#include "usart1.h"
#include "led.h"
//#include "CAN.h"
void NVIC_Configuration(void)
  /* Configure the NVIC Preemption Priority Bits */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  /* Enable the USART1 Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
  /* Enable the USART3 Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
        /* Enable the CAN Interrupt */
  //NVIC_InitStructure.NVIC_IRQChannel =USB_LP_CAN1_RX0_IRQn;
// NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
// NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
// NVIC_Init(&NVIC_InitStructure);
        int main(void)
        SystemInit();//ÅäÖÃϵͳʱÖÓΪ 72M
        LED_Init();//led³õʼ»¯
        LED(ON);
        USART1_Config(); //USART1 ÅäÖà
        USART3_Config(); //USART3 ÅäÖà
        //CAN_Config();
        NVIC_Configuration();// ½ÓÊÕÖжÏÅäÖÃ
  while (1){;}
串口程序在:
/*DE¸úGPIOA8¹Ü½ÅÏàÁ¬*/
#define Set_DE  GPIO_SetBits(GPIOA,GPIO_Pin_8);
#define Clr_DE  GPIO_ResetBits(GPIOA,GPIO_Pin_8);
void delay_ms(u16 nms)
        u32 temp;
        SysTick->LOAD=9000*nms;
        SysTick->VAL=0X00;
        SysTick->CTRL=0X01;
        do{ temp=SysTick->CTRL;}
        while((temp&0x01)&&(!(temp&(1<<16))));
        SysTick->CTRL=0x00;
        SysTick->VAL=0X00;
//USART1³õʼ»¯£¬PA8:RS485_DE$ PA9:RS485_TX$ PA8:RS485_RX$
void USART1_Config(void)
        /* ʹÄÜ USART1 ʱÖÓ*/
                RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
                RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
                 Clr_DE;
        /* USART1 ʹÓÃIO¶Ë¿ÚÅäÖà */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //¸´ÓÃÍÆÍìÊä³ö
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;        //¸¡¿ÕÊäÈë
  GPIO_Init(GPIOA, &GPIO_InitStructure);   //³õʼ»¯GPIOA
        /* USART1 ¹¤×÷ģʽÅäÖà */
        USART_InitStructure.USART_BaudRate = 9600;        //²¨ÌØÂÊÉèÖãº9600
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;        //Êý¾ÝλÊýÉèÖãº8λ
        USART_InitStructure.USART_StopBits = USART_StopBits_1;         //ֹͣλÉèÖãº1λ
        USART_InitStructure.USART_Parity = USART_Parity_No ;  //ÊÇ·ñÆæÅ¼Ð£Ñ飺ÎÞ
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;        //Ó²¼þÁ÷¿ØÖÆÄ£Ê½ÉèÖãºÃ»ÓÐʹÄÜ
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//½ÓÊÕÓë·¢ËͶ¼Ê¹ÄÜ
        USART_Init(USART1, &USART_InitStructure);  //³õʼ»¯USART1
    /*ʹÄÜ´®¿Ú1½ÓÊÕÖжÏ*/
USART_ITConfig(USART1, USART_IT_RXNE,ENABLE);
  USART_Cmd(USART1, ENABLE);// USART1ʹÄÜ
USART_ClearFlag(USART2,USART_FLAG_TC);
void RS485_SendByte(unsigned char SendData )
        Set_DE;
                                delay_ms(200);
                                USART_ClearFlag(USART1,USART_FLAG_TC);
        USART_SendData(USART1,SendData);
        while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);//TXE=·¢ËͼĴæÆ÷Ϊ¿Õ
                                delay_ms(200);
                                Clr_DE;
//USART3³õʼ»¯£¬PB10:RS232_TX$ PB11:RS232_RX$
void USART3_Config(void)
        /* ʹÄÜ USART3 ʱÖÓ*/
                RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
/* USART3 ʹÓÃIO¶Ë¿ÚÅäÖà */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
  GPIO_Init(GPIOB, &GPIO_InitStructure);   //³õʼ»¯GPIOA
        /* USART3 ¹¤×÷ģʽÅäÖà */
        USART_Init(USART3, &USART_InitStructure);  //³õʼ»¯USART3
    /*ʹÄÜ´®¿Ú3½ÓÊÕÖжÏ*/
  USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
  USART_Cmd(USART3,ENABLE);// USART3ʹÄÜ
         /*·¢ËÍÒ»¸ö×Ö½ÚÊý¾Ý*/
void UART3SendByte(unsigned char SendData )
        USART_SendData(USART3,SendData);
        while(USART_GetFlagStatus(USART3, USART_FLAG_TXE) == RESET);
中断:
        void USART1_IRQHandler(void)
{ unsigned char i=0;
        if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
    /* Read one byte from the receive data register */
    i = USART_ReceiveData(USART1);
    UART3SendByte(1);                   //485½ÓÊÕµ½µÄÊý¾Ýͨ¹ý232·¢ËͳöÈ¥
//cansend(i);
void USART3_IRQHandler(void)
         unsigned char i=0;
  if(USART_GetITStatus(USART3, USART_IT_RXNE) != RESET)
    i = USART_ReceiveData(USART3);
   //232½ÓÊÕµ½µÄÊý¾Ýͨ¹ý·¢ËͳöÈ¥
                 RS485_SendByte(i);
//cansend(i);
求大神!!!!!
赞 收藏 评论1 发布时间:2017-11-3 19:50
贺工 回答时间:2017-11-4 08:00:10
一般硬件做法是:232转TTL,TTL加485芯片转485.我不知道你的硬件方案对不对。首先确定硬件方案。485通信和串口编程差不多,如果发送完不想做点延时的话,就采用串口中断发送。有问题可以加我微信:longskill
参与人数 1ST金币 +2 收起 理由
