Who can help check the clock configuration code for stm32f072-sicovery board.THS
hellonsn 提问时间:2018-1-9 08:30 /
void stm32f0_clockconfig(void)
  uint32_t regval;
  /*  Verify if PLL is already setup.  If so configure to use HSI mode */
  if ((getreg32(STM32F0_RCC_CFGR) & RCC_CFGR_SWS_MASK) == RCC_CFGR_SWS_PLL)
      /* Select HSI mode */
      regval  = getreg32(STM32F0_RCC_CFGR);
      regval &= ~RCC_CFGR_SW_MASK;
      putreg32(regval, STM32F0_RCC_CFGR);
      while ((getreg32(STM32F0_RCC_CFGR) & RCC_CFGR_SWS_MASK) != RCC_CFGR_SWS_HSI);
  /* Disable the PLL */
  regval  = getreg32(STM32F0_RCC_CR);
  regval &= ~RCC_CR_PLLON;
  putreg32(regval, STM32F0_RCC_CR);
  while ((getreg32(STM32F0_RCC_CR) & RCC_CR_PLLRDY) != 0);
  /* Enable FLASH prefetch buffer and set flash latency */
  regval = getreg32(STM32_FLASH_ACR);
  regval &= ~FLASH_ACR_LATENCY_MASK;
  regval |= (FLASH_ACR_LATENCY_1 | FLASH_ACR_PRTFBE);
  putreg32(regval, STM32_FLASH_ACR);
  /* Set HCLK = SYSCLK */
  regval &= ~RCC_CFGR_HPRE_MASK;
  regval |= RCC_CFGR_HPRE_SYSCLK;
  /* Set PCLK = HCLK */
  regval &= ~RCC_CFGR_PPRE1_MASK;
  regval |= RCC_CFGR_PPRE1_HCLK;
  /* Configure the PLL to generate the system clock
   * 1. Use source = HSI/2
   * 2. Use PREDIV = 1
   * 3. Use multiplier from board.h
  regval &= ~(RCC_CFGR_PLLSRC_MASK | RCC_CFGR_PLLXTPRE_MASK | RCC_CFGR_PLLMUL_MASK);
  regval |= (RCC_CFGR_PLLSRC_HSId2 | RCC_CFGR_PLLXTPRE_DIV1 | STM32F0_CFGR_PLLMUL);
  /* Enable the PLL */
  regval |= RCC_CR_PLLON;
  while ((getreg32(STM32F0_RCC_CR) & RCC_CR_PLLRDY) == 0);
  /* Configure to use the PLL */
  regval |= RCC_CFGR_SW_PLL;
  while ((getreg32(STM32F0_RCC_CFGR) & RCC_CFGR_SW_MASK) != RCC_CFGR_SW_PLL);
  /* Enable basic peripheral support */
  /* Enable all GPIO modules */
  regval  = getreg32(STM32F0_RCC_AHBENR);
  regval |= RCC_AHBENR_IOPAEN | RCC_AHBENR_IOPAEN | RCC_AHBENR_IOPAEN |\
            RCC_AHBENR_IOPAEN | RCC_AHBENR_IOPAEN | RCC_AHBENR_IOPAEN;
  putreg32(regval, STM32F0_RCC_AHBENR);
Could anyone give some suggestion for the clock configuration on stm32f072-discovery board ?
赞 收藏 评论5 发布时间:2018-1-9 08:30
5个回答
Dandjinh 回答时间:2018-1-9 09:09:44
it's easy to build configuration using stm32cube which is visualized
Inc_brza 回答时间:2018-1-9 09:20:40
what is your question. your clock configuration code do not work? or u just want other guys check the code for u?
anywill 回答时间:2018-1-9 09:30:34
use cubemx to easy to simpleit's a good chance to show my chinglish
Stm32McuLover 回答时间:2018-1-9 11:23:18
ask PoZong for help.
ctang 回答时间:2018-1-9 11:33:14
it's easy to fuck code.
