F407的SPI读写问题
miracle533 提问时间:2018-3-6 21:16 /
悬赏3ST金币已解决
小弟最近在调试NRF24L01模块,遇到了几个问题:1NRF24L01的最大时钟频率是多少?(我在网上找的最大不超过10MHz)
2先带上SPI配置的程序
  1. //配置系统时钟
  2. //        SystemInit();
  3.         /*APB1 84MHz,具体有哪些在此时钟上可跳进去查看*/
  4.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR ,ENABLE);        /* 84MHZ*/
  5.
  6.         /*APB2 168MHz 具体有哪些在此时钟上可跳进去查看*/
  7.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_SYSCFG | RCC_APB2Periph_SPI1, ENABLE);/* 168MHZ */
  8.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC | RCC_AHB1Periph_GPIOE | RCC_AHB1Periph_GPIOD | RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOF, ENABLE);
  9. }
  2.           /* <font color="#ff0000">IRQ(PB8)    CS(PB7)   CE(PB6) </font>  */
  3.                 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_8;
  4.                 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通输出模式
  5.                 GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出
  6.                 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
  7.                 GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
  8.                 GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化PG6,7
  9.
  10.                 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
  11.                 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;//普通输出模式
  12.                 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
  13.                 GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
  14.                 GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化PB14
  1.   /* <font color="#ff0000">SPI_MISO(PB4)    SPI_MOSI(PB5)   SCK(PB3</font>) */
  2.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;//PB3~5复用功能输出
  3.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用功能
  4.   GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出
  5.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
  6.   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
  7.   GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化
  8.
  9.         GPIO_PinAFConfig(GPIOB,GPIO_PinSource3,GPIO_AF_SPI1); //PB3复用为 SPI1
  10.         GPIO_PinAFConfig(GPIOB,GPIO_PinSource4,GPIO_AF_SPI1); //PB4复用为 SPI1
  11.         GPIO_PinAFConfig(GPIOB,GPIO_PinSource5,GPIO_AF_SPI1); //PB5复用为 SPI1
  12.         //这里只针对SPI口初始化
  13.         RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,ENABLE);//复位SPI1
  14.         RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,DISABLE);//停止复位SPI1
  15.
  16. //        GPIO_SetBits(GPIOB,GPIO_Pin_10);
  17.         SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;  //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工
  18.         SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                //设置SPI工作模式:设置为主SPI
  19.         SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;                //设置SPI的数据大小:SPI发送接收8位帧结构
  20.         SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;                //串行同步时钟的空闲状态为高电平
  21.         SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;        //串行同步时钟的第二个跳变沿(上升或下降)数据被采样
  22.         SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;                //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制
  23.         SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_16;                //定义波特率预分频的值:波特率预分频值为256
  24.         SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;        //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始
  25.         SPI_InitStructure.SPI_CRCPolynomial = 7;        //CRC值计算的多项式
  26.         SPI_Init(SPI1, &SPI_InitStructure);  //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器
  27.         SPI_Cmd(SPI1, ENABLE); //使能SPI外设
  28.         SPI1_ReadWriteByte(0x31);//启动传输
  1. u8 SPI1_ReadWriteByte(u8 TxData)
  2. {
  3. while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET){}//
  4.
  5.         SPI_I2S_SendData(SPI1,TxData); //
  6.
  7.   while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET){}//
  8.         return SPI_I2S_ReceiveData(SPI1); //
  9.
  10. }
然后问题出在了SPI1_ReadWriteByte函数,不管我写入的是0X31还是0X22或是其他,仿真调试看到的DR寄存器里都是0XFF.插上NRF24L01模块以后也是如此。先让大佬们看看我的SPI配置有什么问题,感激不尽
最佳答案
查看完整内容
1、官网资料的确说SPI最快是10Mbps 各种资料见链接,http://www.nordicsemi.com/eng/Products/2.4GHz-RF/nRF24L01 2、IRQ(PB8) CS(PB7),是不是注释反了呢,CS是输出,IRQ是输入,而你实际定义是PB8是输出,PB7是输入。 NRF24L01的SPI通信过程中,必须是在CS由高变低后发送指令,CS由低变高后结束传输。
赞 收藏 评论13 发布时间:2018-3-6 21:16
13个回答
七哥 回答时间:2018-3-6 21:16:53
nAN24-12.zip (933.08 KB, 下载次数: 9)
参与人数 1蝴蝶豆 +3 收起 理由
zero99 + 3
myxiexing 回答时间:2018-3-6 23:20:52
没有看到相关外设和GPIO时钟的开启。另外可以测试下SPI的信号数据波形是否正常..
琦子 回答时间:2018-3-7 08:06:45
1.io口时钟使能代码没有看到
2.TxData没有看到写数据代码
3.第一段代码和第二段代码 关于PB678引脚的定义有点不一致啊 第一段代码你这是写来干嘛的啊
MrJiu 回答时间:2018-3-7 13:40:19
直接用CUbe配置,妥妥的!!!!
miracle533 回答时间:2018-3-8 19:00:54
xself 发表于 2018-3-6 23:20
没有看到相关外设和GPIO时钟的开启。另外可以测试下SPI的信号数据波形是否正常.. ...
你好,1相关外设和GPIO时钟在程序里配置过,在帖子里没有发出,现已补上;
2测试SPI的信号数据波形可以用软件仿真测试吗?
miracle533 回答时间:2018-3-8 19:09:54
bargagebaobei 发表于 2018-3-7 08:06
1.io口时钟使能代码没有看到
2.TxData没有看到写数据代码
3.第一段代码和第二段代码 关于PB678引脚的定义有 ...
你好,1 io口时钟代码没有在帖子里贴上,现已补上
2 TxData函数是最后那个写代码的函数吧
3 第一段的PB678,是设置NRF24L01的CE CS IRQ接口,下面的PB345是设置SCK MISO MOSI
miracle533 回答时间:2018-3-8 19:11:20
MrJiu 发表于 2018-3-7 13:40
直接用CUbe配置,妥妥的!!!!
你好,请问这个CUBE配置,在会用库函数的基础下学习大概需要多长时间呢?
miracle533 回答时间:2018-3-8 20:14:59
1.io口时钟使能代码没有看到
2.TxData没有看到写数据代码
问题已解决,谢谢大佬回复
miracle533 回答时间:2018-3-8 20:15:55
各种资料见链接,http://www.nordicsemi.com/eng/Products/2.4GHz-RF/nR ...
问题已解决,,确实是第2点上的问题;谢谢大佬
zero99 + 2 结帖奖励
琦子 回答时间:2018-3-9 08:04:27
别客气了  互相帮助
miracle533 回答时间:2018-3-9 08:05:11
bargagebaobei 发表于 2018-3-9 08:04
别客气了  互相帮助
MrJiu 回答时间:2018-3-9 20:43:18
miracle533 发表于 2018-3-8 19:11
你好,请问这个CUBE配置,在会用库函数的基础下学习大概需要多长时间呢? ...
很快的啦。。。直接图形化配置,不过唯一有可能麻烦的是,第一次最好看一下hal库的初始化流程。。。这样子会了解更多!!!
miracle533 回答时间:2018-3-9 20:50:33
MrJiu 发表于 2018-3-9 20:43
很快的啦。。。直接图形化配置,不过唯一有可能麻烦的是,第一次最好看一下hal库的初始化流程。。。这样 ...
好的,,谢谢
