stm32fo72用IDLE接收不定长数据
xp3 提问时间:2018-3-8 09:39 /
求助  stm32fo72用IDLE接收不定长数据,
点评
fo72,可以不要写这么随意吗  发表于 2018-3-8 10:24
赞 收藏 评论13 发布时间:2018-3-8 09:39
13个回答
xp3 回答时间:2018-3-8 09:43:46
串口初始化
USART_InitTypeDef usart_init_structure;
        GPIO_InitTypeDef gpio_init_structure;
        NVIC_InitTypeDef nvic_init_structure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART4, ENABLE);
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource0,GPIO_AF_4);
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource1,GPIO_AF_4);
        gpio_init_structure.GPIO_Pin = (GPIO_Pin_0| GPIO_Pin_1);
  gpio_init_structure.GPIO_Mode = GPIO_Mode_AF;
  gpio_init_structure.GPIO_OType = GPIO_OType_PP;
  gpio_init_structure.GPIO_Speed = GPIO_Speed_50MHz;
  gpio_init_structure.GPIO_PuPd= GPIO_PuPd_UP;
  GPIO_Init(GPIOA, &gpio_init_structure);
        usart_init_structure.USART_BaudRate=115200;
        usart_init_structure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
        usart_init_structure.USART_Mode=USART_Mode_Rx | USART_Mode_Tx;
        usart_init_structure.USART_Parity = USART_Parity_No;
        usart_init_structure.USART_StopBits = USART_StopBits_1;
        usart_init_structure.USART_WordLength = USART_WordLength_8b;
        USART_Init(USART4,&usart_init_structure);
        USART_ITConfig(USART4,USART_IT_RXNE,ENABLE);
        USART_ITConfig(USART4,USART_IT_TC,ENABLE);
        USART_ITConfig(USART4,USART_IT_IDLE,ENABLE);
        USART_Cmd(USART4,ENABLE);
        nvic_init_structure.NVIC_IRQChannel=USART3_4_IRQn;
        nvic_init_structure.NVIC_IRQChannelPriority=1;
        nvic_init_structure.NVIC_IRQChannelCmd=ENABLE;
        NVIC_Init(&nvic_init_structure);
xp3 回答时间:2018-3-8 09:44:09
已经开启了IDLE中断
xp3 回答时间:2018-3-8 09:44:46
void USART3_4_IRQHandler(void)
        uint8_t Clear=Clear;
        if(USART_GetITStatus(USART4, USART_IT_RXNE) != RESET)
                Recvbuffer4[USART4_RX_STA++]=USART4->RDR;
        else if(USART_GetITStatus(USART4, USART_IT_IDLE) != RESET)
          Clear=USART4->ISR;
                Clear=USART4->RDR ;
          Recivestate=1;
xp3 回答时间:2018-3-8 09:45:08
中断接收
xp3 回答时间:2018-3-8 09:56:05
数据就接收不了了
jjbboox 回答时间:2018-3-8 10:21:17
不要elseif
把两段if 分开试一下。很可能这两个标志位是同时产生的,你用elseif的话,下面的IDLE永远进不去。
wenyangzeng 回答时间:2018-3-8 10:22:39
xp3 回答时间:2018-3-8 10:53:42
jjbboox 发表于 2018-3-8 10:21
不要elseif
把两段if 分开试一下。很可能这两个标志位是同时产生的,你用elseif的话,下面的IDLE永远进不去 ...
还是不行啊
jjbboox 回答时间:2018-3-8 11:12:18
我是用HAL库实现的,可能和你不太一样。
xp3 回答时间:2018-3-8 12:51:49
点评
楼主乖,不哭  发表于 2018-3-8 18:00
埃斯提爱慕 回答时间:2018-3-15 15:56:34
