stm32使能timer3导致程序不正常运行的问题
hqw 提问时间:2018-4-12 13:21 /
主程序非常简单,就是一个跑马灯:int main(void)
  extern uint8_t uart_input_finish;
  extern uint16_t uart_input_count;
Bsp_Init();
        while(1)
      GPIO_WriteBit(GPIOB, GPIO_Pin_6, (BitAction)(1 - GPIO_ReadOutputDataBit(GPIOB, GPIO_Pin_6)));
                   Delay_ms(6000);
但如果下面这句TIM3_Count_Init(9999,719);屏蔽它就可以正常跑灯,不屏蔽则没反应,应该是死机?
static void Bsp_Init(void)
  RCC_Configuration();
  NVIC_Configuration();
        TIM3_Count_Init(9999,719);//1ms//NG
或者:不屏蔽IM3_Count_Init(9999,719);改成屏蔽 TIM_Cmd(TIM3, (FunctionalState)ENABLE); 这句也是可以正常跑灯的。
void TIM3_Count_Init(u16 arr,u16 psc)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, (FunctionalState)ENABLE);
  TIM_DeInit(TIM3);
  TIM_TimeBaseStructure.TIM_Period = arr;
  TIM_TimeBaseStructure.TIM_Prescaler = psc;
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  TIM_ClearFlag(TIM3, TIM_FLAG_Update);
  TIM_ITConfig(TIM3,TIM_IT_Update, (FunctionalState)ENABLE);
  NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 4;
  NVIC_InitStructure.NVIC_IRQChannelCmd = (FunctionalState)ENABLE;
  Timer_Count_Value = 0;
  Timer3_Value = 0;
我反复看了它的中断服务涵数,也没看出哪有不妥:
void TIM3_IRQHandler(void)
  static uint8_t sec_count = 0;
  static uint8_t min_count = 0;
  if(TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET)
    TIM_ClearITPendingBit(TIM3, TIM_IT_Update);
    Timer_Count_Value ++;
    if(Timer_Count_Value % 250 == 0)
      Timer3_Value ++;
      if(Timer3_Value == 12)
        Timer3_Value = 0;
      if(Timer3_Value % 4 == 0)
        sec_count ++;
        if(sec_count >= 15)
          is_read_time = 1;
          sec_count = 0;
        if(FlashBuffer.power_switch == 1)
          min_count ++;
          if(min_count >= 60)
            min_count = 0;
            FlashBuffer.run_time ++;
            if(FlashBuffer.run_time % 30 == 0)
              //±£´æÔËÐÐʱ¼ä
              Earse_Flash(PARA_ADDR);
              if(Write_Flash(PARA_ADDR,(unsigned char *)&FlashBuffer,sizeof(FlashBuffer)) == ERROR)
        else
          min_count = 0;
@toofree
desk(改自空气净化器) - 0331 - FAE.zip
4.5 MB, 下载次数: 4, 下载积分: ST金币 -1
desk(改自空气净化器) - 0331 -A - 副本.rar
4.37 MB, 下载次数: 2, 下载积分: ST金币 -1
赞 收藏 评论11 发布时间:2018-4-12 13:21
11个回答
hqw 回答时间:2018-4-12 16:58:45
我在另一项目模板,project_template_led里
也把 TIM3_Count_Init(9999,719);//1ms//NG用上,并把use_timer.c也都添进去,运行都正常。说明实际或许跟timer3的中断没关,(但在大家找不出原因的那个项目里,把TIM3_Count_Init(9999,719);屏蔽它就可以正常跑灯,不屏蔽则没反应,死机,这也是事实)
   大家可以比较下这两个项目哪里不同?desk这个项目里面哪部分会导致?其实我的主程序都只用了极少的东西,大家要分析的范围应该不大。这两个项目都是用同一个开发板来调试。真希望有人能解这个谜
int main(void)
        LED_GPIO_Config();
   Delay_Init(72);
        while (1)
        while(1)
                   Delay_ms(6000);
desk(改自空气净化器) - 0331 -A - 副本 -野火(不正常).zip
5.42 MB, 下载次数: 0, 下载积分: ST金币 -1
project_template_led(改自野火)OK -TIMER3(正常).zip
5.73 MB, 下载次数: 56, 下载积分: ST金币 -1
MrJiu 回答时间:2018-4-12 13:48:22
STM32CubeMX走起,啥都解决。。。标准库都没研究了!!!
wenyangzeng 回答时间:2018-4-12 13:53:33
跑马灯只要在whuke()循环里延时(你已经是这样做了)翻转GPIO口就可以了。为何要定时器参加这个函数的调用让人看不明白,写GPIO口为何要带那么多调用函数?
GPIO_WriteBit(GPIO, GPIO_Pin_6, (BitAction)(1 - GPIO_ReadOutputDataBit(GPIOB, GPIO_Pin_6)));
改成:
GPIOB->BSRR = 0x00000040;
Delay_ms(6000);
GPIOB->BRR  = 0x00000040;
Delay_ms(6000);。
增加其他LED.........
就OK了
参与人数 1蝴蝶豆 +4 收起 理由
zero99 + 4
STMWoodData 回答时间:2018-4-12 14:31:57
hqw 回答时间:2018-4-12 15:39:00
wenyangzeng 发表于 2018-4-12 13:53
跑马灯只要在whuke()循环里延时(你已经是这样做了)翻转GPIO口就可以了。为何要定时器参加这个函数的调用让 ...
我用STM32不是为了写个跑马灯,是程序写完了,发现运行有问题。为了让自己找问题和大家便于分析,这专门把主程序改成个非常简单的跑马灯。
hqw 回答时间:2018-4-12 15:41:55
流水源 发表于 2018-4-12 14:31
DEBUG调试一下,单步运行看看死在哪里
我用st_link,也没办法知道它运行到哪里了,没跑到设好的断点。st_link的两个灯是在闪。
七哥 回答时间:2018-4-12 15:43:18
中服服务程序中只保留最简单的形式,其它一律不要。
参与人数 1蝴蝶豆 +3 收起 理由
zero99 + 3
hqw 回答时间:2018-4-12 16:27:42
按这样改了,没用。
hqw 回答时间:2018-4-12 16:29:34
按你说的试了,没解决问题
feixiang20 回答时间:2018-4-13 01:15:30
代码运行异常的话可以开个中断逐句检查,看看问题出在什么地方,最好找官方实例进行对比
hqw 回答时间:2018-4-13 16:32:06
问题解决了,
//#define         ENABLE_BOOT                             //使能BOOT(固件升级功能)把这句屏蔽就好了
static void NVIC_Configuration(void)
#ifdef ENABLE_BOOT
  NVIC_SetVectorTable(NVIC_VectTab_FLASH,OFFSET_FIRMWARE_L);
#else
  NVIC_SetVectorTable(NVIC_VectTab_FLASH,0);
#endif
  //Configure the NVIC Preemption Priority Bits
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
zero99 + 2 结帖奖励
