ARM CMSIS Driver 学习 之 SPI
XinLiYF 发布时间:2018-4-14 18:00
ARM CMSIS Driver 学习 之 SPI# [9 O# s& c* z! w1 M
& Q3 h. c# J9 \* L9 `, A       CMSIS Driver 都有着相似的 API 函数和相似的调用方法,它是在 ST HAL 库的基础上又进一步的封装,使用和配置起来都要比 ST HAL 库要方便和简单许多,并且还是跨平台的,非常有学习和使用的价值。今天学习 SPI API 的使用,详细介绍见 CMSIS Driver SPI API
( S" N1 B: x; u$ m4 }2 f- A
3 I5 \) A2 Y$ r7 P( W! @SPI 发送与接收4 d8 ]7 p9 R) ?# u1 |: T
  1. /**0 Q2 N0 C, C! M2 A4 v! G
  2.   ******************************************************************************
    & w0 M2 C8 _  R* @
  3.   * @file    main.c& s% h+ w; V/ F/ Q# n
  4.   * @author  XinLi
    1 ^' O6 C1 m' [1 M1 j3 P6 J, e) J
  5.   * @version v1.08 R& o6 O/ C+ `+ }6 T* S
  6.   * @date    20-March-2018
    % ]% A: R: Y, w9 \/ o4 G+ J
  7.   * @brief   Main program body.
    + n# u3 A! W. _  w2 ]' Z  s. r
  8.   ******************************************************************************( V; r' ]2 G5 E% d- Q1 d
  9.   * @attention
    * U+ g9 P9 ?; Z$ x: m% B7 V
  10.   *7 S+ {/ p- L+ z+ O. x
  11.   * <h2><center>Copyright © 2018 XinLi</center></h2>
    ) V0 g8 Z- s$ A
  12.   *
    4 O8 A) M7 A0 p) B+ L, ]
  13.   * This program is free software: you can redistribute it and/or modify# g* j: m! p- N# @: }0 i
  14.   * it under the terms of the GNU General Public License as published by
    7 c+ `8 t2 R4 A
  15.   * the Free Software Foundation, either version 3 of the License, or* |7 Z# U) ], k+ ~
  16.   * (at your option) any later version.
    * z" m5 @" O! C$ b  t# h8 h) g
  17.   *+ R- R' j. x2 h! z: }6 Y( T- `
  18.   * This program is distributed in the hope that it will be useful,% [: p; l' q2 K5 K
  19.   * but WITHOUT ANY WARRANTY; without even the implied warranty of# y& |: a+ N, ?: t5 Q
  20.   * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the: g; F4 s- @% v  d9 N5 L
  21.   * GNU General Public License for more details.. @! ]% P% i0 K; w+ _
  22.   *2 N0 M! G8 g% l1 Q
  23.   * You should have received a copy of the GNU General Public License( s- l  y& O1 e! d) w; n* B9 P1 w4 a
  24.   * along with this program.  If not, see <http://www.gnu.org/licenses/>.2 d( @. D! r% k; n% N
  25.   ** b; O& U1 i: B) l1 h) |8 u
  26.   ******************************************************************************
    1 r( S+ Y% }' @+ W% d/ e: r6 M
  27.   */. K" v3 b: s2 b
  28. # K, J! }8 V! r& I1 ?! U. q
  29. /* Header includes -----------------------------------------------------------*/$ Q8 M* W! r& f; }( A
  30. #include "stm32f4xx.h"
    . L# u: n  Y/ K5 r# K
  31. #include "Driver_SPI.h"
      M; W! T0 W0 ?/ K9 S% F$ E
  32. #include <string.h>
    ' P: J% d+ O6 Q3 f% e: m
  33. # l) `# U. X# A2 Z8 Z
  34. /* Macro definitions ---------------------------------------------------------*/; Z2 v! e: `: U: W' b8 m
  35. /* Type definitions ----------------------------------------------------------*/6 X" Q- w, ?8 I0 S$ X* d
  36. /* Variable declarations -----------------------------------------------------*/
    9 t, t2 r$ G2 B5 e: P9 G0 o6 T
  37. extern ARM_DRIVER_SPI Driver_SPI1;" W& P& z: v3 o% M% \% E8 D- P  r
  38. ) R& a3 ^$ N% ~4 y
  39. /* Variable definitions ------------------------------------------------------*/
    - w- s1 c+ @  F
  40. static uint8_t txBuffer[5]   = {0xAB};
    2 H2 M  ]4 A; Q" |' t
  41. static uint8_t rxBuffer[5]   = {0};
    9 n; j& x4 f' W9 g( m0 r9 Q; b
  42. static uint8_t dataBuffer[5] = {0};
    4 u2 J6 d( h! k- f; E' ?6 B& I
  43. / \9 i' Q6 C/ d4 V3 A2 G6 L! B9 f6 h
  44. /* Function declarations -----------------------------------------------------*/
    ; |4 h  I4 V( x. Z. a
  45. static void SPI1_Callback(uint32_t event);6 f# @: I7 s$ z" S& V, u
  46. static void SPI1_CS_Init(void);& L6 H, {7 V4 B2 ~7 e0 Z6 C
  47. static void SPI1_CS_Low(void);
      j: _, t: U) ]( ^  j
  48. static void SPI1_CS_High(void);
    . P' t( v$ A* |- @0 ?, y8 m
  49. static void SystemClock_Config(void);
    3 [, I7 W& ~' G" W! S8 ?/ z  ~4 E
  50. + S& ?0 ~1 K3 W" c% e
  51. /* Function definitions ------------------------------------------------------*/
    ) U# A4 S* A5 @$ P) p, f6 R2 M
  52. 4 S; f1 }' r3 c( r" H- ?9 }
  53. /**! z! A3 Q% h. ^6 |
  54.   * @brief  Main program.
    " d8 d7 v2 ?3 ]2 g- M$ B( Q" W3 d
  55.   * @param  None.
    - `( I. h% z5 L, y
  56.   * @return None.
    6 c" s8 P/ [, B+ o" ]% r5 S
  57.   */: Q# A# L  t6 S: _+ B
  58. int main(void)
    ! C' h% V" G% b) p# T
  59. {
    . E" r( F  m( o9 @5 u* e
  60.   /* STM32F4xx HAL library initialization:
    / G0 [+ S: T$ F; ]* e4 ?+ p
  61.        - Configure the Flash prefetch, instruction and Data caches8 J' ~& X6 _6 t9 d" A# T
  62.        - Configure the Systick to generate an interrupt each 1 msec" n/ f' O( _: t  u' Z9 i% H/ B
  63.        - Set NVIC Group Priority to 43 M, K# C/ T) Q
  64.        - Global MSP (MCU Support Package) initialization5 l! r: G# q- O3 }
  65.      */2 g% K2 [  y+ E2 Q; K
  66.   HAL_Init();8 `* a! j7 o8 _
  67.   0 N! R! |% Y! L$ p( m0 D# C. R3 \8 a
  68.   /* Configure the system clock to 168 MHz */$ X) C% G8 F, b' G1 x4 u8 P
  69.   SystemClock_Config();5 Q* R6 Z4 n4 {( M
  70.   9 J. e- D3 t0 Y8 [( i7 E
  71.   SPI1_CS_Init();/ y$ D: h* B' k* r0 o
  72.   4 O$ I% T* }' E% v$ J* I5 y4 D$ P
  73.   Driver_SPI1.Initialize(SPI1_Callback);  J9 {' C+ u: l" H9 s; ^  i
  74.   Driver_SPI1.PowerControl(ARM_POWER_FULL);" Y! F8 Z% y& s
  75.   Driver_SPI1.Control(ARM_SPI_MODE_MASTER |
    : ]5 ?/ x# _6 q
  76.                       ARM_SPI_CPOL0_CPHA0 |
    9 e! l/ i& b( n. x1 s
  77.                       ARM_SPI_MSB_LSB |9 s9 `; y- M0 E2 B( s
  78.                       ARM_SPI_SS_MASTER_UNUSED |
    2 a! m$ ^2 i3 l) X) }8 h( A
  79.                       ARM_SPI_DATA_BITS(8), 10000000);' g- {0 w& l$ n3 Q  t3 N
  80.   - u7 Y1 t9 v& k5 G" H, \& u
  81.   SPI1_CS_Low();5 H. C, I$ o% b* m  s* y% b
  82.   Driver_SPI1.Transfer(txBuffer, rxBuffer, sizeof(txBuffer));
    , r9 K2 m2 F+ J0 w/ G" U
  83.
    7 c6 R' h& [; z  m( T: p4 X1 J" F
  84.   for(;;)
    5 ?9 {1 Z; Q  C  h  o2 R
  85.   {3 [1 q4 f9 d! u  u
  86.     / ^: `% ]+ Q+ u2 H7 G3 X/ T
  87.   }! V2 [) t* D4 W
  88. }
      S7 u. T; F2 W3 C- Q
  89. 9 {; Q/ }+ z& H7 z
  90. /**
    + @+ Y; s' y+ T2 E
  91.   * @brief  SPI1 callback function.
    1 p3 E  h: u' m7 c8 m, O0 ]+ D: g
  92.   * @param  event: SPI events notification mask.
    0 ]! p! }8 m2 i6 }7 G7 T1 p
  93.   * @return None.
    3 _& j$ {% Q0 `7 i4 ~
  94.   */
    6 x! z. Q7 ^4 [" M8 M* L4 j
  95. static void SPI1_Callback(uint32_t event)- a( \, ^  H  [4 d6 q/ {
  96. {' c0 b; ~8 Y% B; h9 B
  97.   if(event & ARM_SPI_EVENT_TRANSFER_COMPLETE)
    3 W4 h9 ?; \; @3 C
  98.   {# i9 e( d6 q8 N* ?) q& d" f
  99.     SPI1_CS_High();
    0 R* i* Z( o5 [1 g% q7 |- X2 Q
  100.     memcpy(dataBuffer, rxBuffer, sizeof(rxBuffer));
    ! i( @6 r/ H# h* [* ?0 ~) P, ~; q
  101.   }
    . _* O. ?" s; y3 ~
  102. }
    6 d: }- }. Y1 c! {( l- ^
  103. ' q4 S! E5 j: \+ Z; W5 h
  104. /**. t! R* p, `! W/ Z. C' c/ V+ q
  105.   * @brief  SPI1 CS pin initialize.5 G, c" n. U( t3 X; o" `
  106.   * @param  None.9 j  L" v. n: S* `+ Z" n
  107.   * @return None.+ Y% k& D. @7 C  e. C  s
  108.   */
    8 Y3 {+ u$ k: k! v8 W9 d4 c  B7 V
  109. static void SPI1_CS_Init(void)
    ; H& |/ w" _& d4 ^9 m
  110. {
    3 b5 |: I% z9 H; Z( O9 G
  111.   GPIO_InitTypeDef GPIO_InitStruct = {0};1 X* s# p# N# p+ N7 i9 H$ Y' {2 \/ i0 q
  112.   , M) I2 _; ]! G' W
  113.   /* GPIO Ports Clock Enable */
      x" ]6 X5 l/ F/ h7 ?
  114.   __HAL_RCC_GPIOB_CLK_ENABLE();
    & D, Y( H( Z" j  [# v
  115.   / F# X& F. [% Q7 Q- J  [
  116.   /* Configure GPIO pin : PtPin */
    - W5 t. \; N, r5 h4 A
  117.   GPIO_InitStruct.Pin   = GPIO_PIN_14;/ i- q4 P4 p  V! ~
  118.   GPIO_InitStruct.Mode  = GPIO_MODE_OUTPUT_PP;
    " @6 g  J3 s9 R. W# R
  119.   GPIO_InitStruct.Pull  = GPIO_PULLUP;8 q4 u& x9 {/ v$ {, \# r
  120.   GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
    5 |4 |: f+ b8 |9 i: J
  121.   HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);, X8 m) h, F2 @8 [- [, t3 N
  122.   7 z0 q: w$ B. {
  123.   /* Configure GPIO pin Output Level */3 [" B9 Y1 g+ J! O+ M- W
  124.   HAL_GPIO_WritePin(GPIOB, GPIO_PIN_14, GPIO_PIN_SET);
    & g9 y, q1 `0 X" `
  125. }
    6 s1 q* q6 T% ]/ P4 U/ h- W9 c
  126. % R* o. F( Q# Z6 Y: s4 s; A# g
  127. /**
      z# G9 @# Q$ D, W, z8 H' U  I
  128.   * @brief  SPI1 CS pin level pull low.
    & a* e  E8 l  E- B
  129.   * @param  None.! U7 ]. `( @7 O2 p3 M" G+ x
  130.   * @return None.
    - `# ?7 P8 E% I% D4 p4 r  G* q
  131.   */
    # _7 V+ }, `9 [0 T* m5 i
  132. static void SPI1_CS_Low(void)
    : u! ]1 e, @4 ~) K! I
  133. {5 ?# Z, c. x/ g
  134.   /* Configure GPIO pin Output Level */
    / e4 ?+ z! J) j& q7 B
  135.   HAL_GPIO_WritePin(GPIOB, GPIO_PIN_14, GPIO_PIN_RESET);4 K4 k+ c5 P+ ~' j: B" E
  136. }! C6 N6 m' H$ j6 R6 ^
  137. ; O6 Q3 W: K& n# {: b
  138. /**: L1 [8 p4 `9 p& ^1 b
  139.   * @brief  SPI1 CS pin level pull high.
    ; ^6 J5 v1 U. f5 K6 Z  K$ j2 L
  140.   * @param  None.
    & @# ]1 V& R' V7 ~: o
  141.   * @return None.5 P7 L- S5 c! p; S8 Y
  142.   */
    ' c% j( x$ Y* N, p
  143. static void SPI1_CS_High(void)* W. I( P0 g9 u2 U# h8 I
  144. {
    9 y8 q6 i3 [# a3 ]
  145.   /* Configure GPIO pin Output Level */
    4 }+ n# ~7 F/ S- m
  146.   HAL_GPIO_WritePin(GPIOB, GPIO_PIN_14, GPIO_PIN_SET);
    . U6 @: ?. M' d5 F( C! L
  147. }
    7 U# i% ~+ g1 U
  148. 0 ^) k7 j0 b* i- v
  149. /**1 t" N" O8 o. X4 O
  150.   * @brief  System Clock Configuration
    " y. b8 I) B9 {7 C' L1 k! C  a* e  G
  151.   *         The system Clock is configured as follow : & A4 H$ ?! r' E/ W$ W5 v
  152.   *            System Clock source            = PLL (HSE)" P: u1 X+ I( r( R5 C
  153.   *            SYSCLK(Hz)                     = 168000000& }' _. |$ C% Y$ {/ g
  154.   *            HCLK(Hz)                       = 1680000004 n8 u( z! R& @8 D3 Y( C9 n* {  S4 `
  155.   *            AHB Prescaler                  = 1
      A! r" l! m& ^6 M5 K1 L: f" U
  156.   *            APB1 Prescaler                 = 4
    5 L; P  O, s, e2 @4 s& c3 f
  157.   *            APB2 Prescaler                 = 2# z' l) y1 t8 J& Q% v. \
  158.   *            HSE Frequency(Hz)              = 8000000) y, i3 ~5 a% P: s1 P
  159.   *            PLL_M                          = 8
    * p7 u9 Q# P1 K( {7 S0 O
  160.   *            PLL_N                          = 336/ t, V7 e6 W/ \6 b' U
  161.   *            PLL_P                          = 2/ X% ]4 b& t/ F" o
  162.   *            PLL_Q                          = 7
      O9 W+ X* q) V- z) m  {
  163.   *            VDD(V)                         = 3.3+ n; n' r- g  L% ~
  164.   *            Main regulator output voltage  = Scale1 mode0 o3 v% O: I& p! n1 h% o: r
  165.   *            Flash Latency(WS)              = 5/ J' [4 p1 u0 Y. ~0 `
  166.   * @param  None8 E/ J. H& f% X8 n7 P% t
  167.   * @retval None
    6 D  n& T0 h* l! w3 @
  168.   */
    9 _: N* B0 ^1 n! C* M8 Z2 Y
  169. static void SystemClock_Config(void)5 J+ R' l, x1 b+ E9 m7 S
  170. {
    / Z' G" o1 Y% a$ `: O8 R& h
  171.   RCC_ClkInitTypeDef RCC_ClkInitStruct;
    / A; p/ s2 |3 l, i! o5 f. b
  172.   RCC_OscInitTypeDef RCC_OscInitStruct;
    , Y' Q6 W# c% [2 O6 M% _8 \% _- J- x
  173. * Y6 y' r( u5 t4 D
  174.   /* Enable Power Control clock */' B' O" e8 G; N- V
  175.   __HAL_RCC_PWR_CLK_ENABLE();- E4 C6 T5 `9 i6 T+ ]
  176. ' |! D# r1 H9 ^- p5 F
  177.   /* The voltage scaling allows optimizing the power consumption when the device is
    1 G1 g9 @$ X$ ^1 [
  178.      clocked below the maximum system frequency, to update the voltage scaling value 7 u# z6 y+ A9 q  C+ W
  179.      regarding system frequency refer to product datasheet.  */
    3 o/ @; W2 A" l  e6 E
  180.   __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);2 m% a+ ^; i. ], h/ w
  181. $ U, S' h4 M! O" i% Y
  182.   /* Enable HSE Oscillator and activate PLL with HSE as source */- \7 k+ K  S/ l
  183.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;! c0 J3 f, s& G- D% n) @( ]
  184.   RCC_OscInitStruct.HSEState = RCC_HSE_ON;
    : j  Z* X+ L1 p' g$ a7 S& n9 b' C
  185.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
    & n8 d" {. l, A4 h
  186.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
    $ ^% k. U8 [0 e  _0 g0 V  Z
  187.   RCC_OscInitStruct.PLL.PLLM = 8;$ H( _. m( D; x9 _
  188.   RCC_OscInitStruct.PLL.PLLN = 336;
      j: p% x2 x% n& }) o
  189.   RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
    ! m% `  Y( M  f3 O) H7 x
  190.   RCC_OscInitStruct.PLL.PLLQ = 7;! m2 Z8 \9 W' l9 J: s& d6 T; _5 q
  191.   HAL_RCC_OscConfig(&RCC_OscInitStruct);
    7 J/ V  x* I& Z0 `2 L/ l8 G) t
  192.
    # i& a+ a5 b1 Y: g3 R2 @& P, U: V# c
  193.   /* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
    8 R) A* Z+ f9 y$ ^
  194.      clocks dividers */% D' y3 g1 f7 E2 ~
  195.   RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);* C2 a9 X) j3 [7 z2 W2 g/ H4 D" B
  196.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;$ K+ o% F2 P2 U/ J  [# g( r
  197.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
    " d9 W' }2 t0 }
  198.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
    % a+ {& Q3 I' ~
  199.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;  ( k3 _) l4 D2 Q4 f" A
  200.   HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5);: q! a* Y, M4 \. ~5 q2 V$ [' N
  201.   Z& n1 D! ~+ g' {; `
  202.   /* STM32F405x/407x/415x/417x Revision Z devices: prefetch is supported  */7 m8 _7 U6 ^6 e" F
  203.   if (HAL_GetREVID() == 0x1001)3 F1 F/ o. W# V0 s( s( g" P
  204.   {
    $ a( d& a4 B; B9 O- W% l
  205.     /* Enable the Flash prefetch */
    , Y, g! {) e4 q. `8 v' k
  206.     __HAL_FLASH_PREFETCH_BUFFER_ENABLE();* {- J, Z% e6 U+ j' C: ~' S
  207.   }3 [" ~! z6 l. n6 \$ p2 B# [3 @
  208. }
    * c/ l$ l9 v( T
" t4 h3 \$ |2 ?: d, }; h
归档链接% l2 r3 P) M, G5 E  J: X
ARM CMSIS Driver 学习 之 USART5 y) b& |& y" ?" w0 Q
赞 收藏 评论0 发布时间:2018-4-14 18:00
