stm32f030 rtc闹钟中断我这样配置为什么是一分钟进一次中断?
qianrushian 提问时间:2018-4-28 10:04 /
我想改成5s进一次中断怎么改?求助大神!!!!!!!!!!!!!!!!!!!!!
void RTC_AlarmConfig(void)
RTC_TimeTypeDef   RTC_TimeStructure;
  RTC_AlarmTypeDef  RTC_AlarmStructure;
  EXTI_InitTypeDef EXTI_InitStructure;
RTC_DateTimeTypeDef RTC_DateTimeStructure;
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);
PWR_BackupAccessCmd(ENABLE);
RCC_LSICmd(ENABLE);
RCC_RTCCLKConfig(RCC_RTCCLKSource_LSI);//ÄÚ²¿
RCC_RTCCLKCmd(ENABLE);
  RTC_AlarmCmd(RTC_Alarm_A,DISABLE);//¹Ø±ÕÄÖÖÓA
// RTC_GetDateTime(&RTC_DateTimeStructure);
// RTC_AlarmStructure.RTC_AlarmTime.RTC_H12=RTC_H12_AM;
// RTC_AlarmStructure.RTC_AlarmTime.RTC_Hours=RTC_DateTimeStructure.Hour;
// RTC_AlarmStructure.RTC_AlarmTime.RTC_Minutes=RTC_DateTimeStructure.Minute;
//  RTC_AlarmStructure.RTC_AlarmTime.RTC_Seconds=RTC_DateTimeStructure.Second+5;
// if(RTC_AlarmStructure.RTC_AlarmTime.RTC_Seconds >=60)RTC_AlarmStructure.RTC_AlarmTime.RTC_Seconds=0;
  /* Get current time */
  RTC_GetTime(RTC_Format_BIN, &RTC_TimeStructure);
RTC_AlarmStructure.RTC_AlarmTime.RTC_Hours=RTC_TimeStructure.RTC_Hours;
RTC_AlarmStructure.RTC_AlarmTime.RTC_Minutes=RTC_TimeStructure.RTC_Minutes;
RTC_AlarmStructure.RTC_AlarmTime.RTC_Seconds=RTC_TimeStructure.RTC_Seconds+5;
  RTC_AlarmStructure.RTC_AlarmDateWeekDay = 0x31;
  RTC_AlarmStructure.RTC_AlarmDateWeekDaySel = RTC_AlarmDateWeekDaySel_Date;
  RTC_AlarmStructure.RTC_AlarmMask = RTC_AlarmMask_DateWeekDay | RTC_AlarmMask_Minutes |
                                     RTC_AlarmMask_Hours;
//  RTC_AlarmStructure.RTC_AlarmMask =RTC_AlarmMask_Seconds;
// RTC_AlarmSubSecondConfig(RTC_Alarm_A,RTC_TimeStructure.RTC_Seconds+5,RTC_AlarmSubSecondMask_SS14_1);
  RTC_SetAlarm(RTC_Format_BIN, RTC_Alarm_A, &RTC_AlarmStructure);
   /* Clear the Alarm A Pending Bit */
  RTC_ClearITPendingBit(RTC_IT_ALRA);
//Êä³öÉ趨µÄÄÖÖÓ»½ÐÑʱ¼ä
//  RTC_ITConfig(RTC_IT_ALRA, ENABLE);
  /* Enable the alarm */
  RTC_AlarmCmd(RTC_Alarm_A, ENABLE);
   /* EXTI configuration */
  EXTI_ClearITPendingBit(EXTI_Line17);
  EXTI_InitStructure.EXTI_Line = EXTI_Line17;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  /* Enable the RTC Alarm Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = RTC_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPriority=1;
//PWR_BackupAccessCmd(DISABLE);
void  RTC_IRQHandler(void)
  SystemInit();
//   RCC_LSICmd(ENABLE);
// RCC_RTCCLKConfig(RCC_RTCCLKSource_LSI);//ÄÚ²¿
// RCC_RTCCLKCmd(ENABLE);
  LED_Init();
   if (RTC_GetITStatus(RTC_IT_ALRA) != RESET)
//   RTC_GetAlarm(RTC_Format_BIN,RTC_IT_ALRA);
//RTC_AlarmSubSecondConfig(RTC_Alarm_A,RTC_TimeStructure.RTC_Seconds+5,RTC_AlarmSubSecondMask_SS14_1);
赞 收藏 评论7 发布时间:2018-4-28 10:04
7个回答
废鱼 回答时间:2018-4-28 10:46:22
5秒一次中断用wakeup,下面的代码:
  1. EXTI_InitTypeDef EXTI_InitStructure;
  2.
  3.   /* EXTI configuration */
  4.   EXTI_InitStructure.EXTI_Line = EXTI_Line20;
  5.   EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  6.   EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
  7.   EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  8.   EXTI_Init(&EXTI_InitStructure);
  9.
  10.   /* Enable the RTC Wake Interrupt */
  11.         Std_NVIC_SetPriority(RTC_WKUP_IRQn, 0, 0);
  12.   /* Set the RTC Wake */
  13.         RTC_ClearITPendingBit(RTC_IT_WUT);
  14.         RTC_WakeUpCmd(DISABLE);
  15.         RTC_SetWakeUpCounter(5);
  16.         RTC_WakeUpClockConfig(RTC_WakeUpClock_CK_SPRE_16bits);
  17.
  18.   /* Enable WakeUp interrupt */
  19.         RTC_WakeUpCmd(ENABLE);
  20.         RTC_ITConfig(RTC_IT_WUT,ENABLE);
参与人数 1蝴蝶豆 +3 收起 理由
zero99 + 3
qianrushian 回答时间:2018-4-29 13:35:19
f030 没有你说的那些东西啊。
废鱼 回答时间:2018-5-2 09:15:26
不好意思,我看的是STM32F0xx_StdPeriph_Lib_V1.5.0的库文件,里面写了有,但是只有072才支持,如果用alarm的话,应该是当前秒+5即可。超过60的%60一下即可。
冷不丁-357544 回答时间:2020-8-18 10:55:13
楼主找到问题没有?我也碰到了同样的问题
冷不丁-357544 回答时间:2020-9-2 14:11:08
你好,我使用的是STM32F072CBT6,在工程中查询怎么没有RTC_WKUP_IRQn中断,我需要产生一个7分钟的中断的,可以分享一下你的这块详详细的配置代码吗?
废鱼 回答时间:2020-9-2 16:51:23
冷不丁-357544 发表于 2020-9-2 14:11
你好,我使用的是STM32F072CBT6,在工程中查询怎么没有RTC_WKUP_IRQn中断,我需要产生一个7分钟的中断的 ...
您好,这个中断代码是需要自己写的。可以参考官方的例程。
万飞 回答时间:2020-11-21 11:01:35
冷不丁-357544 发表于 2020-8-18 10:55
楼主找到问题没有?我也碰到了同样的问题
你这个问题解决了吗
