stm8s207 调试hx711称重装置,输出结果一直为0
半夏微凉 提问时间:2018-4-28 21:46 /
stm8s207 调试hx711称重装置,输出结果一直为0,大家帮助看一看哪里有错误;16M晶振不分频
code hx711.c
void GPIO_Int(void)
   GPIO_DeInit(GPIOB);
   GPIO_DeInit(GPIOA);
   GPIO_DeInit(GPIOE);
   GPIO_Init(GPIOB, GPIO_PIN_2, GPIO_MODE_OUT_PP_LOW_SLOW);//led2
   GPIO_Init(GPIOB, GPIO_PIN_3, GPIO_MODE_OUT_PP_LOW_SLOW);//led3
   GPIO_Init(GPIOB, GPIO_PIN_7, GPIO_MODE_IN_PU_NO_IT);//k1
   GPIO_Init(GPIOA, GPIO_PIN_6, GPIO_MODE_IN_PU_NO_IT);//k2
   GPIO_Init(GPIOG, GPIO_PIN_0, GPIO_MODE_OUT_PP_LOW_FAST);////HX711_SCK
   GPIO_Init(GPIOG, GPIO_PIN_1, GPIO_MODE_IN_FL_NO_IT);////DT  上拉输入
   GPIO_WriteLow(GPIOE, GPIO_PIN_3);
u32 HX711_Read(void)        //增益128
        unsigned long count;
        unsigned char i;
          GPIO_WriteLow(GPIOG, GPIO_PIN_0); //sck  0
          count=0;
          while(GPIO_ReadInputPin(GPIOG, GPIO_PIN_1));
          for(i=0;i<24;i++)
                  GPIO_WriteHigh(GPIOG, GPIO_PIN_0);
                nop();
                  count=count<<1;
                  if(GPIO_ReadInputPin(GPIOG, GPIO_PIN_1))
                        count++;
                nop();
    count=count^0x800000;//第25个脉冲下降沿来时,转换数据
                nop();
        return(count);
//获取毛皮重量
void Get_Maopi(void)
        Weight_Maopi = HX711_Read();
void Get_Weight(void)
        Weight_Shiwu = HX711_Read();
        Weight_Shiwu = Weight_Shiwu - Weight_Maopi;                //获取净重
        if(Weight_Shiwu >= 0)
                Weight_Shiwu = (unsigned long)((float)Weight_Shiwu/GapValue);         //计算实物的实际重量
        else
                Weight_Shiwu = 0;
main。c
void main(void)
    CLK_DeInit();
    /*判断时钟源,自动切换到HSE*/
    if(CLK_GetSYSCLKSource()!=CLK_SOURCE_HSE)
                   /*使能自动切换,一直等待到切换成功*/
                  while(CLK_ClockSwitchConfig(CLK_SWITCHMODE_AUTO,
                                              CLK_SOURCE_HSE,
                                              DISABLE,CLK_CURRENTCLOCKSTATE_ENABLE)
                          ==ERROR);
    //User_UART3_Init();
    User_UART1_Init();
    GPIO_Int();
   delays();
  /* Infinite loop */
  while (1)
         // Get_Weight();
          nop();
          nop();
       // Weight_Shiwu = HX711_Read();
        Get_Weight();
        Weight_Shiwu = (unsigned long)((float)Weight_Shiwu/430);
        printf("净重量 = %d g\r\n",Weight_Shiwu);
        //printf("净重量 =  g\r\n");
           delays();
赞 收藏 评论8 发布时间:2018-4-28 21:46
8个回答
半夏微凉 回答时间:2018-4-28 21:47:32
GPIO_Init(GPIOG, GPIO_PIN_1, GPIO_MODE_IN_FL_NO_IT);////DT  上拉输入  实际为浮空输入
半夏微凉 回答时间:2018-4-28 21:49:07
净重量 = 0 g
净重量 = 0 g
净重量 = 0 g
净重量 = 0 g
净重量 = 0 g
净重量 = 0 g
净重量 = 0 g
苦☕️ 回答时间:2018-4-29 00:38:34
66666666666666666666666666666666666666
wenyangzeng 回答时间:2018-4-29 07:32:35
如果外部没有上拉电阻,应改成:
GPIO_Init(GPIOG, GPIO_PIN_1, GPIO_MODE_IN_PU_NO_IT);
参与人数 1蝴蝶豆 +3 收起 理由
zero99 + 3
半夏微凉 回答时间:2018-4-29 11:49:15
wenyangzeng 发表于 2018-4-29 07:32
如果外部没有上拉电阻,应改成:
试过了  结果一样   手册建议浮空输入
wenyangzeng 回答时间:2018-4-29 13:30:31
半夏微凉 发表于 2018-4-29 11:49
试过了  结果一样   手册建议浮空输入
那你应该把器件的时序图贴上
半夏微凉 回答时间:2018-4-29 15:12:32
wenyangzeng 发表于 2018-4-29 13:30
那你应该把器件的时序图贴上
解决了
半夏微凉 回答时间:2018-4-29 15:26:06
找到原因  程序没大问题,只是大打印输出时候打印输出无数据。程序是移植32的  32的打印输出程序如下:
        while(1)
                Get_Weight();
                printf("¾»ÖØÁ¿ = %d g\r\n",Weight_Shiwu); //´òÓ¡
                delay_ms(1000);
我是直接复制过来的,因为自己的也printf重定向了,所以一直忽略这个问题。后来参照51的程序慢慢发现的
   //Weight_Shiwu = 5000;
                WeightShiwu[0] = Weight_Shiwu%10000/1000 + 0x30;
                WeightShiwu[1] = Weight_Shiwu%1000/100 + 0x30;
                WeightShiwu[2] = Weight_Shiwu%100/10 + 0x30;
                WeightShiwu[3] = Weight_Shiwu%10 + 0x30;
                WeightShiwu[4] = 'g';
                for(i=0;i<5;i++)
                      UART1_SendData8(WeightShiwu[i]);
                      while(UART1_GetFlagStatus(UART1_FLAG_TXE )==RESET);
                      nop();
参与人数 1蝴蝶豆 +3 收起 理由
zero99 + 3 结贴奖励
