想问一下 我对这段代码总结的功能对不对; 电脑通过串口助手发送数据给单片机 单片机接收数据进入接收数据串口中断 读取DR寄存器中接收到的数据 再通过串口回写给电脑 以下是程序代码: 文件:mian.c //功能:串口初始化、打开定时器中断,然后一直接收数据状态就好了。发送在中断中实现。 #include "stm32f10x.h" #include "usart.h" u8 USART_rx_data; int main(void) { RCC_Configuration(); //系统时钟配置 GPIO_Configuration(); //端口初始化 NVIC_Configuration(); //中断源配置 USART_Configuration(); //串口1初始化 Time_Init(); //定时器初始化 #ifdef DEBUG debug(); #endif TIM_Cmd(TIM3,ENABLE); while(1) { } } 文件:usart.c #include "stm32f10x.h" #include "stdio.h" #include "usart.h" unsigned char auchCRCHi [256] ={ 0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41,0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40, 0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40,0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41, 0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40,0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41, 0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41,0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40, 0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40,0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41, 0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41,0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40, 0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41,0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40, 0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40,0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41, 0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40,0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41, 0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41,0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40, 0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41,0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40, 0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40,0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41, 0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41,0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40, 0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40,0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41, 0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40,0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41, 0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41,0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40}; unsigned char auchCRCLo [256] ={ 0x00,0xC0,0xC1,0x01,0xC3,0x03,0x02,0xC2,0xC6,0x06,0x07,0xC7,0x05,0xC5,0xC4,0x04, 0xCC,0x0C,0x0D,0xCD,0x0F,0xCF,0xCE,0x0E,0x0A,0xCA,0xCB,0x0B,0xC9,0x09,0x08,0xC8, 0xD8,0x18,0x19,0xD9,0x1B,0xDB,0xDA,0x1A,0x1E,0xDE,0xDF,0x1F,0xDD,0x1D,0x1C,0xDC, 0x14,0xD4,0xD5,0x15,0xD7,0x17,0x16,0xD6,0xD2,0x12,0x13,0xD3,0x11,0xD1,0xD0,0x10, 0xF0,0x30,0x31,0xF1,0x33,0xF3,0xF2,0x32,0x36,0xF6,0xF7,0x37,0xF5,0x35,0x34,0xF4, 0x3C,0xFC,0xFD,0x3D,0xFF,0x3F,0x3E,0xFE,0xFA,0x3A,0x3B,0xFB,0x39,0xF9,0xF8,0x38, 0x28,0xE8,0xE9,0x29,0xEB,0x2B,0x2A,0xEA,0xEE,0x2E,0x2F,0xEF,0x2D,0xED,0xEC,0x2C, 0xE4,0x24,0x25,0xE5,0x27,0xE7,0xE6,0x26,0x22,0xE2,0xE3,0x23,0xE1,0x21,0x20,0xE0, 0xA0,0x60,0x61,0xA1,0x63,0xA3,0xA2,0x62,0x66,0xA6,0xA7,0x67,0xA5,0x65,0x64,0xA4, 0x6C,0xAC,0xAD,0x6D,0xAF,0x6F,0x6E,0xAE,0xAA,0x6A,0x6B,0xAB,0x69,0xA9,0xA8,0x68, 0x78,0xB8,0xB9,0x79,0xBB,0x7B,0x7A,0xBA,0xBE,0x7E,0x7F,0xBF,0x7D,0xBD,0xBC,0x7C, 0xB4,0x74,0x75,0xB5,0x77,0xB7,0xB6,0x76,0x72,0xB2,0xB3,0x73,0xB1,0x71,0x70,0xB0, 0x50,0x90,0x91,0x51,0x93,0x53,0x52,0x92,0x96,0x56,0x57,0x97,0x55,0x95,0x94,0x54, 0x9C,0x5C,0x5D,0x9D,0x5F,0x9F,0x9E,0x5E,0x5A,0x9A,0x9B,0x5B,0x99,0x59,0x58,0x98, 0x88,0x48,0x49,0x89,0x4B,0x8B,0x8A,0x4A,0x4E,0x8E,0x8F,0x4F,0x8D,0x4D,0x4C,0x8C, 0x44,0x84,0x85,0x45,0x87,0x47,0x46,0x86,0x82,0x42,0x43,0x83,0x41,0x81,0x80,0x40}; unsigned short CRC16(unsigned char* puchMsg, unsigned short usDataLen) { unsigned char uchCRCHi = 0xFF ; unsigned char uchCRCLo = 0xFF ; unsigned char uIndex ; while (usDataLen--) { uIndex = uchCRCHi^*puchMsg++; uchCRCHi = uchCRCLo^auchCRCHi[uIndex]; uchCRCLo = auchCRCLo[uIndex]; } return (uchCRCHi << 8 | uchCRCLo) ; } void RCC_Configuration(void) { ErrorStatus HSEStartUpStatus; //枚举变量,定义高速时钟的启动状态 RCC_DeInit(); //RCC系统重置,用于Debug目的 RCC_HSEConfig(RCC_HSE_ON); //使能高速时钟源HSE HSEStartUpStatus = RCC_WaitForHSEStartUp(); //等待HSE稳定 if(HSEStartUpStatus == SUCCESS) { FLASH_SetLatency(FLASH_Latency_2); FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); RCC_HCLKConfig(RCC_SYSCLK_Div1); // HCLK = SYSCLK RCC_PCLK2Config(RCC_HCLK_Div1); // PCLK2 = HCLK RCC_PCLK1Config(RCC_HCLK_Div2); ///PCLK1 = HCLK/2 RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9); RCC_PLLCmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET){} RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); while(RCC_GetSYSCLKSource() != 0x08){} } RCC_APB2PeriphClockCmd( RCC_APB2Periph_USART1 |RCC_APB2Periph_GPIOA |RCC_APB2Periph_AFIO |RCC_APB2Periph_GPIOB , ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); } //------------------------------------------------------------------ //函数名:void GPIO_Configuration() //输入参数:null //返回参数:null //说明:GPIO初始化函数 //------------------------------------------------------------------ void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; //GPIO初始化结构体声明 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //USART1 TX GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); //A端口 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //USART1 RX GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //复用浮空输入 GPIO_Init(GPIOA, &GPIO_InitStructure); //A端口 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); } //------------------------------------------------------------------ //函数名:void NVIC_Configuration() //输入参数:null //返回参数:null //说明:NVIC初始化函数 //------------------------------------------------------------------ void NVIC_Configuration(void) { NVIC_InitTypeDef NVIC_InitStructure; //NVIC初始化结构体声明 #ifdef VECT_TAB_RAM NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0); //如果程序在RAM中调试那么定义中断向量表在RAM中否则在Flash中 #else NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0); #endif NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //设置串口1中断 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //抢占优先级 0 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //子优先级为0 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //使能 NVIC_Init(&NVIC_InitStructure); NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn; //设置定时器3全局中断 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; //抢占优先级 1 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //子优先级为0 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //使能 NVIC_Init(&NVIC_InitStructure); } //------------------------------------------------------------------ //函数名:void USART_Configuration() //输入参数:null //返回参数:null //说明:串口初始化函数 //------------------------------------------------------------------ void USART_Configuration(void){ USART_InitTypeDef USART_InitStructure; //串口初始化结构体声明 USART_ClockInitTypeDef USART_ClockInitStruct; USART_InitStructure.USART_BaudRate = 115200; //设置波特率为115200bps USART_InitStructure.USART_WordLength = USART_WordLength_8b; //数据位8位 USART_InitStructure.USART_StopBits = USART_StopBits_1; //停止位1位 USART_InitStructure.USART_Parity = USART_Parity_No; //无校验位 USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None; //无硬件流控 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //接受和发送模式都打开 USART_ClockInitStruct.USART_Clock=USART_Clock_Disable; //串口时钟禁止 USART_ClockInitStruct.USART_CPOL=USART_CPOL_Low; //数据低电平有效 USART_ClockInitStruct.USART_CPHA=USART_CPHA_2Edge; //配置CPHA使数据在第2个边沿的时候被捕获 USART_ClockInitStruct.USART_LastBit=USART_LastBit_Disable; // 禁用最后一位,使对应的时钟脉冲不会再输出到SCLK引脚 USART_ClockInit(USART1, &USART_ClockInitStruct);//配置USART与时钟相关的设置 USART_Init(USART1, &USART_InitStructure); //配置串口参数函数 USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); //使能接收中断 //USART_ITConfig(USART1, USART_IT_TXE, ENABLE); //使能发送缓冲空中断 //USART_ITConfig(USART1, USART_IT_TC, ENABLE); //使能发送完成中断 USART_ClearFlag(USART1,USART_FLAG_TC); //清除发送完成标志位 USART_Cmd(USART1, ENABLE); //使能串口1 } //------------------------------------------------------------------ //函数名:void Time_Init() //输入参数:null //返回参数:null //说明:定时器初始化函数 //------------------------------------------------------------------ void Time_Init(void) { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_DeInit(TIM3); //复位TIM3定时器 TIM_TimeBaseStructure.TIM_Period =7999; //设置自动重装载寄存器锁存值,1ms溢出 TIM_TimeBaseStructure.TIM_Prescaler = 8; //9分频 TIM_TimeBaseStructure.TIM_ClockDivision = 0x0; //时钟分频因子 TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //计数器向上计数模式 TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStructure); //写TIM3各寄存器参数 TIM_ClearFlag(TIM3,TIM_FLAG_Update); TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE); } 文件:usart.h #ifndef _USART_H #define _USART_H #include #include "stm32f10x.h" void RCC_Configuration(void); //声明RCC初始化函数 void GPIO_Configuration(void); //声明GPIO初始化函数 void NVIC_Configuration(void); //声明NVIC初始化函数 void USART_Configuration(void); //声明串口初始化函数 void Time_Init(void); //声明定时器初始化函数 unsigned short CRC16(unsigned char* puchMsg, unsigned short usDataLen); #endif 文件:stm32f103x_it.c //需要设置串口接收中断和定时器3中断,中断时间为1ms //------------------------------------------------------------------ //函数名:void USART1_IRQHandler(void) //输入参数:null //返回参数:null //说明:串口接收中断服务 //------------------------------------------------------------------ void USART1_IRQHandler(void) { if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) //判断读寄存器是否非空 { // GPIO_SetBits(GPIOB,GPIO_Pin_6); rx_data[RbufCounter++]=USART_ReceiveData(USART1);//接收字节到接收缓冲区 if(USART_Rsv_Status==0) { if(RbufCounter>1) { if(rx_data[0]==0xA5&&rx_data[1]==0x5A) //当接收到的数据帧头两个字节同时为0xA5和0x5A时 { USART_Rsv_Status=1; // USART_SendData(USART1, rx_data[0]); } else { rx_data[0]=rx_data[1]; RbufCounter=1; } } } else { USART_1ms_Cnt=0; } } } //------------------------------------------------------------------ //函数名:void TIM2_IRQHandler(void) //输入参数:null //返回参数:null //说明:定时器2中断服务 //------------------------------------------------------------------ void TIM2_IRQHandler(void) { } //------------------------------------------------------------------ //函数名:void TIM3_IRQHandler(void) //输入参数:null //返回参数:null //说明:定时器3中断服务 //------------------------------------------------------------------ void TIM3_IRQHandler(void) { if(TIM_GetITStatus(TIM3,TIM_IT_Update)!=RESET)//判断是否为定时器3溢出中断 { GPIO_SetBits(GPIOB,GPIO_Pin_6); TIM_ClearITPendingBit(TIM3, TIM_IT_Update); //清中断标记 if(USART_Rsv_Status==1) USART_1ms_Cnt++; if(USART_1ms_Cnt>5) { // USART_SendData(USART1,0xAA); USART_Rsv_Status=0; //连续计数超过5次对USART_Rsv_Status置0,继续等待接收 USART_1ms_Cnt=0; //当USART_1ms_Cnt>5时对USART_1ms_Cnt重新清零 if(RbufCounter==(u16)rx_data[4]+7) //检验数据的完整性 { int i; //定义循环变量 int j; data_length=rx_data[4]; for(i=0;i { data=rx_data; } CRC_data_Hi=rx_data[RbufCounter-1]; CRC_data_Lo=rx_data[RbufCounter-2]; CRC_data=CRC16((unsigned char*)data,data_length+5); CRC_data_Hi1=CRC_data>>8; CRC_data_Lo1=CRC_data&0x00ff; if(CRC_data_Hi==(u8)CRC_data_Hi1 && CRC_data_Lo==CRC_data_Lo1) { for(j=0;rx_data[j]!='\0';j++)//循环逐字输出,到结束字'\0' { USART_SendData(USART1, rx_data[j]); //发送字符 |
楼主自己下载到板子上试试,Debug就知道了。
在watch看 自己发给自己
2只处理5A A5 开头的报文
这个不是,其他的,我看不下去了,,这么长,其他人接力..
