MotorControl Workbench 5生成的文件是空文件???
goodzeng 提问时间:2018-6-25 17:22 /
  * File Name          :
  * Description        :
  * This notice applies to any and all portions of this file
  * that are not between comment pairs USER CODE BEGIN and
  * USER CODE END. Other portions of this file, whether
  * inserted by the user or by software development tools
  * are owned by their respective copyright owners.
  * Copyright (c) 2018 STMicroelectronics International N.V.
  * All rights reserved.
  * Redistribution and use in source and binary forms, with or without
  * modification, are permitted, provided that the following conditions are met:
  * 1. Redistribution of source code must retain the above copyright notice,
  *    this list of conditions and the following disclaimer.
  * 2. Redistributions in binary form must reproduce the above copyright notice,
  *    this list of conditions and the following disclaimer in the documentation
  *    and/or other materials provided with the distribution.
  * 3. Neither the name of STMicroelectronics nor the names of other
  *    contributors to this software may be used to endorse or promote products
  *    derived from this software without specific written permission.
  * 4. This software, including modifications and/or derivative works of this
  *    software, must execute solely and exclusively on microcontroller or
  *    microprocessor devices manufactured by or for STMicroelectronics.
  * 5. Redistribution and use of this software other than as permitted under
  *    this license is void and will automatically terminate your rights under
  *    this license.
  * THIS SOFTWARE IS PROVIDED BY STMICROELECTRONICS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS, IMPLIED OR STATUTORY WARRANTIES, INCLUDING, BUT NOT
  * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
  * PARTICULAR PURPOSE AND NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY
  * RIGHTS ARE DISCLAIMED TO THE FULLEST EXTENT PERMITTED BY LAW. IN NO EVENT
  * SHALL STMICROELECTRONICS OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
  * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
  * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,
  * OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
  * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
  * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
  * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
这是mc_api.c文件  是空白的 怎么回事?安装路径和生成路径都是英文名?这是什么原因??
收藏 评论3 发布时间:2018-6-25 17:22
3个回答
博天一浪 回答时间:2018-6-27 16:06:24
cubemx 的hal库默认存放位置不要更改,保持默认C:\Users\Administrator\STM32Cube\Repository
参与人数 1蝴蝶豆 +3 收起 理由
zero99 + 3
goodzeng 回答时间:2018-6-28 09:53:47
谢谢。。解决了  你说的太对了。。
参与人数 1蝴蝶豆 +1 收起 理由
zero99 + 1 结贴奖励
wujialing4000 回答时间:2020-2-8 20:07:40
goodzeng 发表于 2018-6-28 09:53
谢谢。。解决了  你说的太对了。。
你好,请问你最后怎么解决的呢?我也是放回到原来默认目录下去,但是还是一样的空文件。
意法半导体边缘AI套件
ST - 理想汽车豪华SUV案例
ST意法半导体智能家居案例
STM32 ARM Cortex 32位微控制器
