外部中断唤醒停止模式问题
zymwjm 提问时间:2018-6-26 18:24 /
同时配置了四个外部中断用于唤醒,其中一个中断唤醒后,就把其他中断也给唤醒了,比如说用EXTI_Line4唤醒,却同时触发唤醒EXTI_Line0 EXTI_Line1
void RCC_Config(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
        SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOB  , EXTI_PinSource4);
        SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOB  ,EXTI_PinSource3);
        SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOB  ,EXTI_PinSource1);
        SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOB  ,EXTI_PinSource0);
void EXTI_Config(void)
    EXTI_InitTypeDef EXTI_InitStructure;
    //KEY 4
    NVIC_InitStructure.NVIC_IRQChannel = EXTI4_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
          EXTI_InitStructure.EXTI_Line = EXTI_Line4;
    EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
    EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
    EXTI_InitStructure.EXTI_LineCmd = ENABLE;
    EXTI_Init(&EXTI_InitStructure);
          //KEY 3
                NVIC_InitStructure.NVIC_IRQChannel = EXTI3_IRQn;
          EXTI_InitStructure.EXTI_Line = EXTI_Line3;
                //KEY 2
                NVIC_InitStructure.NVIC_IRQChannel = EXTI1_IRQn;
          EXTI_InitStructure.EXTI_Line = EXTI_Line1;
                //KEY 1
                NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn;
          EXTI_InitStructure.EXTI_Line = EXTI_Line0;
void Cma_exti_config(void)
        printf("\r\nCma_exti_config\r\n");
        GpioInit(&cam_key1,PTC_KEY1,PIN_INPUT,PIN_PUSH_PULL,PIN_PULL_UP,0);
        GpioInit(&cam_key2,PTC_KEY2,PIN_INPUT,PIN_PUSH_PULL,PIN_PULL_UP,0);
        GpioInit(&cam_key3,PTC_KEY3,PIN_INPUT,PIN_PUSH_PULL,PIN_PULL_UP,0);
        GpioInit(&cam_key4,PTC_KEY4,PIN_INPUT,PIN_PUSH_PULL,PIN_PULL_UP,0);
        RCC_Config();
        EXTI_Config();
赞 收藏 评论2 发布时间:2018-6-26 18:24
zymwjm 回答时间:2018-6-26 18:29:11
其他处理函数同下
void EXTI4_IRQHandler( void )
    if( EXTI_GetITStatus( EXTI_Line4 ) != RESET )
        EXTI_ClearITPendingBit( EXTI_Line4 );
                                SystemInit();
                                printf("\r\nEXTI4_IRQHandler\r\n");
                printf("\r\nEXTI_GetFlagStatus(EXTI_Line0)=%d\r\n",EXTI_GetFlagStatus(EXTI_Line0));
                                key_flag = true;
大陶 回答时间:2018-6-27 18:33:42
看一下 是不是程序当中有关联其余几个外部中断,或者是硬件电路
参与人数 1蝴蝶豆 +3 收起 理由
zero99 + 3
