stm32l476g-discovery ADC转换LCD显示
bbbone 提问时间:2018-8-31 15:00 /
悬赏5ST金币未解决
想请各位大佬,看看原因出在哪里,怎么修改。(现在LCD上显示00.0,没数字,感觉是ADC转化写错了,并没有转换)
main.c 文件(其中部分代码来自网络,只是学习目的,没有其他目的。)
1.  #include "stm32l4xx.h"
2.  #include "stm32l476g_discovery.h"
3.  #include "adc.h"
4.  #include "dma.h"
5.  #include "stm32l476g_discovery_glass_lcd.h"
6.  #include "stdlib.h"
7.  #include "stdio.h"
8.  //#include "main.h"
9.
10. void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc);
11. /* USER CODE BEGIN 0 */
12. uint32_t uhADCxConvertedValue[1];
13. uint32_t oldvalue[1];
14. unsigned long shijian=0;
15. volatile uint8_t dmaflage=0;
16. ADC_HandleTypeDef hadc1;
17. void SystemClock_Config(void)
18. {
19.   RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
20.   RCC_OscInitTypeDef RCC_OscInitStruct = {0};
21.   // MSI is enabled after System reset, activate PLL withMSI as source
22.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSI;
23.   RCC_OscInitStruct.MSIState = RCC_MSI_ON;
24.   RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_6;
25.   RCC_OscInitStruct.MSICalibrationValue = RCC_MSICALIBRATION_DEFAULT;
26.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
27.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_MSI;
28.   RCC_OscInitStruct.PLL.PLLM = 1;
29.   RCC_OscInitStruct.PLL.PLLN = 40;
30.   RCC_OscInitStruct.PLL.PLLR = 2;
31.   RCC_OscInitStruct.PLL.PLLP = 7;
32.   RCC_OscInitStruct.PLL.PLLQ = 4;
33.   if(HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
34.   {
35.    // Initialization Error
36.    BSP_LED_On(LED_RED);
37.     while(1);
38.   }
39.   // Select PLL as system clock source and configure theHCLK, PCLK1 and PCLK2
40.              //clocks dividers
41.           RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK| RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
42.           RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
43.           RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
44.           RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
45.           RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
46.           if(HAL_RCC_ClockConfig(&RCC_ClkInitStruct,FLASH_LATENCY_4) != HAL_OK)
47.           {
48.             // Initialization Error
49.             while(1);
50.           }
51. }
52.
53. /* USER CODE END 0 */
54. int main(void)
55. {
56.   /* USER CODE BEGIN 1 */
57.   uint16_t ad1=0; //ad2=0;
58.   /* USER CODE END 1 */
59.   /* MCU
60. Configuration----------------------------------------------------------*/
61.   /* Reset of all peripherals, Initializes the Flashinterface and the Systick. */
62.   HAL_Init();
63.   /* Configure the system clock */
64.   SystemClock_Config();
65.   /* Initialize all configured peripherals */
66.   //MX_GPIO_Init();
67.   BSP_LCD_GLASS_Init();
68.   BSP_LED_Init(LED_RED);
69.   BSP_LED_Init(LED_GREEN);
70.   DMA_conf();
71.   ADC1_conf();
72.   /* USER CODE BEGIN 2 */
73. #if DEBUG_ENABLE
74.    debugInit(115200);
75. #endif
76.         int a1,b1,c1;
77.         char a[1];
78.         char b[1];
79.         char c[1];
80.        char d[]="M";
81.        char e[]="P";
82.        char f[]="S";
83.   shijian=HAL_GetTick();
84.   //ADC_Cmd(ADC1,ENABLE);
85.   HAL_ADC_Start_DMA(&hadc1, (uint32_t*)&uhADCxConvertedValue,1);
86.   //ADC_SOFTWARESTARTCONVCMD(ADC1,ENABLE);
87. if(uhADCxConvertedValue!=0){ //printf("HAL_ADC_Start_DMA\r\n");
88.       BSP_LED_On(LED_RED);
89.       HAL_Delay(100);
90.       BSP_LED_On(LED_GREEN);
91.       HAL_Delay(100);
92.       //if(uhADCxConvertedValue[1]==oldvalue[1])
93.       BSP_LED_Off(LED_RED);
94.       HAL_Delay(100);
95.    dmaflage=1;
96.   }
97.   while (1)
98.   {
99.    if(HAL_GetTick()-shijian>=500)
100.        {
101.           if(dmaflage==1)
102.           {
103.             dmaflage=0;
104.             //ad1 = uhADCxConvertedValue[0];
105.             //ad2 = uhADCxConvertedValue[1];
106.             /*printf("ad1=%d,Vad1=%0.2\r\n",ad1,ad1*3.3/4096);//UNIT IS FV
107.             ad1 = (ad1*330)/4096;                //扩大100倍 ,3.3V, 4096=12bit
108.             printf("V100ad1=%d\r\n",ad1);
109.             HAL_ADC_Start_DMA(&hadc1,(uint32_t*)&uhADCxConvertedValue,2);
110.             ad1 = 0;*/
111.             ad1 = (float)uhADCxConvertedValue[0]*330/4069;
112.
113.              a1=(ad1/100 );
114.              b1=(ad1%100/10);
115.              c1=(ad1%100%10/1);
116.                      itoa (a1, a, 10);
117.                      itoa (b1, b, 10);
118.                      itoa (c1, c, 10);
119.             BSP_LCD_GLASS_DisplayChar(a,POINT_OFF,DOUBLEPOINT_OFF,LCD_DIGIT_POSITION_1);
120.             BSP_LCD_GLASS_DisplayChar(b,POINT_ON,DOUBLEPOINT_OFF,LCD_DIGIT_POSITION_2);
121.             BSP_LCD_GLASS_DisplayChar(c,POINT_OFF,DOUBLEPOINT_OFF,LCD_DIGIT_POSITION_3);
122.             BSP_LCD_GLASS_DisplayChar(d,POINT_OFF,DOUBLEPOINT_OFF,LCD_DIGIT_POSITION_4);//M
123.             BSP_LCD_GLASS_DisplayChar(e,POINT_OFF,DOUBLEPOINT_OFF,LCD_DIGIT_POSITION_5);//P
124.             BSP_LCD_GLASS_DisplayChar(f,POINT_OFF,DOUBLEPOINT_OFF,LCD_DIGIT_POSITION_6);//S
125.
126.           }
127.           shijian=HAL_GetTick();
128.         }
129.       }
130.     }
131.
132.     void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc)
133.     {
134.       dmaflage=1;
135.      //--------- HAL_ADC_Stop_DMA(&hadc1);
136.     }
adc.c 文件内容:
3.  #include "adc.h"
4.  #include "stm32l4xx_hal_adc.h"
5.  ADC_HandleTypeDef hadc1;
6.  DMA_HandleTypeDef hdma_adc1;
7.
8.  ADC_ChannelConfTypeDef sConfig;
9.
10. void ADC1_conf(void)
11. {
12.    HAL_Init();// HAL Init
13.   /**Configure the global features of the ADC (Clock,Resolution, Data,Alignment and number of conversion) */
14.   hadc1.Instance = ADC1;
15.   hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV2;
16.   hadc1.Init.Resolution = ADC_RESOLUTION_12B;
17.   hadc1.Init.ScanConvMode = ENABLE;    //upward
18.   hadc1.Init.ContinuousConvMode = ENABLE;
19.   hadc1.Init.DiscontinuousConvMode = DISABLE;
20.   hadc1.Init.ExternalTrigConvEdge = ADC_SOFTWARE_START;    //software trigger
21.   hadc1.Init.ExternalTrigConvEdge  =ADC_EXTERNALTRIGCONVEDGE_RISING;     //rising edge
22.   hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;     //< Data right alignment
23.   hadc1.Init.NbrOfConversion = 2;               /* Thisparameter must be a number between Min_Data = 1 and Max_Data = 16.
24.                                                 Note:This parameter must be modified when no conversion is on going on regular group(ADC disabled,
25.                                                 orADC enabled without continuous mode or external trigger that could launch aconversion). */
26.   hadc1.Init.DMAContinuousRequests = ENABLE;
27.   hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
28.   /**Configure for the selected ADC regular channel itscorresponding rank in the sequencer and its sample time. */
29.   sConfig.Channel = ADC_CHANNEL_5;
30.   sConfig.Rank = 1;
31.   sConfig.SamplingTime = ADC_SAMPLETIME_12CYCLES_5;  //  Sampling time12.5 ADC clock cycles at ADC resolution 12 bits.
32.   HAL_ADC_ConfigChannel(&hadc1,&sConfig);
33.   /**Configure for the selected ADC regular channel itscorresponding rank in the sequencer and its sample time. */
34.   sConfig.Channel = ADC_CHANNEL_3;
35.   sConfig.Rank = 2;
36.   HAL_ADC_ConfigChannel(&hadc1,&sConfig);
37.
38. }
39.
40. void HAL_ADC_MspInit(ADC_HandleTypeDef* hadc)
41. {
42.   GPIO_InitTypeDef GPIO_InitStruct;
43.   if(hadc->Instance==ADC1)
44.   {
45.     /* Peripheral clock enable */
46.     __HAL_RCC_ADC_CLK_ENABLE();
47.     /**ADC1 GPIO Configuration  PA0-WKUP    ------> ADC1_IN5*/
48.     GPIO_InitStruct.Pin = GPIO_PIN_0;         //input port
49.     GPIO_InitStruct.Mode = GPIO_MODE_ANALOG_ADC_CONTROL; //////analog input  MODE  GPIO_MODE_ANALOG;
50.     GPIO_InitStruct.Pull = GPIO_NOPULL;       //no pull
51.     HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
52.     /* Peripheral DMA init*/
53.     hdma_adc1.Instance = DMA1_Channel1;
54.     hdma_adc1.Init.Direction = DMA_PERIPH_TO_MEMORY;
55.     hdma_adc1.Init.PeriphInc = DMA_PINC_DISABLE;
56.     hdma_adc1.Init.MemInc = DMA_MINC_ENABLE;
57.     hdma_adc1.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD;
58.     hdma_adc1.Init.MemDataAlignment = DMA_MDATAALIGN_WORD;
59.     hdma_adc1.Init.Mode = DMA_CIRCULAR;
60.     hdma_adc1.Init.Priority = DMA_PRIORITY_MEDIUM;
61.     HAL_DMA_Init(&hdma_adc1);
62.
63.     __HAL_LINKDMA(hadc,DMA_Handle,hdma_adc1);
64.   }
65. }
66.
67. void HAL_ADC_MspDeInit(ADC_HandleTypeDef* hadc)
68. {
69.   if(hadc->Instance==ADC1)
70.   {
71.     /* Peripheral clock disable */
72.     __HAL_RCC_ADC_CLK_DISABLE();
73.
74.     /**ADC1 GPIO Configuration
75.     PA0-WKUP    ------> ADC1_IN5                  PC14     ------> ADC1_IN3 */
76.     HAL_GPIO_DeInit(GPIOA, GPIO_PIN_0); //PA0      //HAL_GPIO_DeInit(GPIOC, GPIO_PIN_14);//PC14
77.     /* Peripheral DMA DeInit*/
78.     HAL_DMA_DeInit(hadc->DMA_Handle);
79.   }
80. }
dma.c内容:
1.    //#include"stm32l4xx.h"
2.    //#include"stm32l476g_discovery.h"
3.    #include "dma.h"
4.    void DMA_conf(void)
5.    {
6.      /* DMA controller clock enable */
7.      __HAL_RCC_DMA1_CLK_ENABLE();
8.     // __HAL_RCC_DMA2_CLK_ENABLE();
9.      /* NVIC configuration for DMA Input datainterrupt */
10.    //Nested Vectored InterruptController (NVIC)
11.    //set the priority of NVIC
12.    HAL_NVIC_SetPriority(1,5,1);//DMA1_Channel1_IRQn,RCC_IRQn, 0WWDG_IRQn : stm32l476xx.h
13.    HAL_NVIC_EnableIRQ(1);//DMA1_Channel1_IRQn
14.  }
赞 收藏 评论5 发布时间:2018-8-31 15:00
5个回答
yangjiaxu 回答时间:2018-9-3 09:18:16
建议您试试串口输出一下ADC呢,看看有没有正常的值。
馒头弟 回答时间:2018-9-3 10:58:35
单步调试,先确定ADC值正确,然后查看定义的数据类型与LCD显示函数的参数是否匹配。
hjl2832 回答时间:2018-9-3 11:03:30
单步调试,将断点打在关键点位置,查看关键变量是否正常。。。
熊二在深圳 回答时间:2018-9-3 15:29:42
建议使用truestudio的IDE,可以分析出运行过程中的变量
myxiexing 回答时间:2018-9-3 22:13:58
要先区分是哪位分的问题?如果LCD显示的数据可以直接给个ADC数据去显示看看是否正常?正常后可以专心查找ADC问题,这样排除法可能会快一点
