故障现象 在netcon下 TCP客户端或服务器端程序均不能正常工作。 硬件平台EVA-407 PHY:DP83848 软件平台:stm32Cubemx LWIP 2.0版 FREERTOS 我在stm32CubeMx 在针脚配置中 选定如下功能 lwip及 freertos 均用默认配置 产生代码并编译后, 自已编写如下用户代码 这是参照以往的官方例程 int main(void) { /* USER CODE BEGIN 1 */ /* USER CODE END 1 */ /* MCU Configuration----------------------------------------------------------*/ /* Reset of all peripherals, Initializes the Flash interface and the Systick. */ HAL_Init(); /* USER CODE BEGIN Init */ /* USER CODE END Init */ /* Configure the system clock */ SystemClock_Config(); /* USER CODE BEGIN SysInit */ /* USER CODE END SysInit */ /* Initialize all configured peripherals */ MX_GPIO_Init(); /* USER CODE BEGIN 2 */ /* init code for LWIP */ MX_LWIP_Init(); /* Initialize tcp echo server */ tcpecho_init(); /* USER CODE END 2 */ /* USER CODE BEGIN RTOS_MUTEX */ /* add mutexes, ... */ /* USER CODE END RTOS_MUTEX */ /* USER CODE BEGIN RTOS_SEMAPHORES */ /* add semaphores, ... */ /* USER CODE END RTOS_SEMAPHORES */ /* USER CODE BEGIN RTOS_TIMERS */ /* start timers, add new ones, ... */ /* USER CODE END RTOS_TIMERS */ /* Create the thread(s) */ /* definition and creation of defaultTask */ osThreadDef(defaultTask, StartDefaultTask, osPriorityNormal, 0, 128); defaultTaskHandle = osThreadCreate(osThread(defaultTask), NULL); /* USER CODE BEGIN RTOS_THREADS */ /* add threads, ... */ /* USER CODE END RTOS_THREADS */ /* USER CODE BEGIN RTOS_QUEUES */ /* add queues, ... */ /* USER CODE END RTOS_QUEUES */ /* Start scheduler */ osKernelStart(); /* We should never get here as control is now taken by the scheduler */ /* Infinite loop */ /* USER CODE BEGIN WHILE */ while (1) { /* USER CODE END WHILE */ /* USER CODE BEGIN 3 */ } /* USER CODE END 3 */ } static void tcpecho_thread(void *arg) { struct netconn *conn, *newconn; err_t err; LWIP_UNUSED_ARG(arg); /* Create a new connection identifier. */ conn = netconn_new(NETCONN_TCP); if (conn!=NULL) { /* Bind connection to well known port number 7. */ err = netconn_bind(conn, NULL, 8080); if (err == ERR_OK) { /* Tell connection to go into listening mode. */ netconn_listen(conn); while (1) { /* Grab new connection. */ err= netconn_accept(conn,&newconn); /* Process the new connection. */ if (newconn) { struct netbuf *buf; void *data; u16_t len; while ((err = netconn_recv(newconn,&buf)) != NULL) { do { netbuf_data(buf, &data, &len); netconn_write(newconn, data, len, NETCONN_COPY); } while (netbuf_next(buf) >= 0); netbuf_delete(buf); } /* Close connection and discard connection identifier. */ netconn_close(newconn); netconn_delete(newconn); } } } else { printf(" can not bind TCP netconn"); } } else { printf("can not create TCP netconn"); } } /*-----------------------------------------------------------------------------------*/ void tcpecho_init(void) { sys_thread_new("tcpecho_thread", tcpecho_thread, NULL, DEFAULT_THREAD_STACKSIZE, tskIDLE_PRIORITY + 3); } 运行后用网络调试助手可以连接上开发板,但数据回送。 如果我将开发板开成TCP的客户端 ,则无法联上服务器。 ping 开发板的92.168.1.10是可以ping通的。 我查不到原因,希望能得到指 导,或都是有stm32Cubemx4.26版本下的tcp客户端和服务器端的例程供参考以便查原因。 |
需要对照一下历程,对比看看问题出在哪里 |
没人回答吗。 |
