关于freertos 的列表和列表项问题
annQian 提问时间:2018-11-19 14:59 /
typedef struct xLIST
listFIRST_LIST_INTEGRITY_CHECK_VALUE    /*< Set to a known value if configUSE_LIST_DATA_INTEGRITY_CHECK_BYTES is set to 1. */
configLIST_VOLATILE UBaseType_t uxNumberOfItems;
ListItem_t * configLIST_VOLATILE pxIndex;   /*< Used to walk through the list.  Points to the last item returned by a call to listGET_OWNER_OF_NEXT_ENTRY (). */
MiniListItem_t xListEnd;       /*< List item that contains the maximum possible item value meaning it is always at the end of the list and is therefore used as a marker. */
listSECOND_LIST_INTEGRITY_CHECK_VALUE    /*< Set to a known value if configUSE_LIST_DATA_INTEGRITY_CHECK_BYTES is set to 1. */
} List_t;
查看上文
#ifndef configLIST_VOLATILE
#define configLIST_VOLATILE
#endif /
configLIST_VOLATILE在这里有什么用,为什么这么定义变量?
收藏 评论3 发布时间:2018-11-19 14:59
3个回答
xiaojie0513 回答时间:2018-11-20 08:13:37
VOLATILE 就是Volatile,在config.h自定义实现的,如果没有就是没有吧,我记得好像是这样子的
︶ㄣ昕锐^^&~ 回答时间:2018-11-20 10:26:02
* To use volatile list structure members then add the following line to
* FreeRTOSConfig.h (without the quotes):
* "#define configLIST_VOLATILE volatile"
list.h里面已经注释很详细了,至于为啥这么定义,查一下volatile的用法就懂了
踮起脚摘苹果 回答时间:2020-2-10 22:19:14
volatile还是防止编译器做优化
意法半导体边缘AI套件
ST - 理想汽车豪华SUV案例
ST意法半导体智能家居案例
STM32 ARM Cortex 32位微控制器
