stm32h7-uboot-uclinux 移植完成部分,分享给大家
stone-363407 发布时间:2018-11-22 15:29
本帖最后由 stone-363407 于 2018-12-7 16:42 编辑 7 L2 t9 w" v( D1 \' B0 k
) s) W( g3 i/ n8 i& z代码地址: http://github.com/huayuguo/uboot-stm32h743_eth
# v/ H# h  Q2 G
, o( ]/ f6 l( x2 p3 o' }* o  F8 O. X/ ~
, H& U3 V! P! r2 r- J: K0 |. M! \, M" i
U-Boot 2018.09-rc2-gc16d658 (Dec 06 2018 - 16:00:30 +0800)
; M  E% T$ s7 w, u: U' d' w) d2 K% ]7 x/ x# z) l
1 p8 F5 [& n- t' s( h
Model: STMicroelectronics STM32H743i-EVAL board. J- N6 z+ n' n& ?( _
DRAM:  32 MiB
1 t5 n2 H: |2 z' J& X" |7 g) l4 R2 lMMC:   STM32 SDMMC2: 0' b3 |! r1 x& p) M1 w
In:    serial@40011000
3 b' [' i- i% J) QOut:   serial@40011000
) P, g2 q* s9 _0 p1 ZErr:   serial@40011000/ p' |1 g4 E7 k  I
Net:   # t4 d3 n; e; m1 z3 b  k4 r9 d7 y
Warning: ethernet@40028000 (eth0) using random MAC address - fe:f8:94:5f:5e:26
- X' D0 W& w' `: R; t" geth0: ethernet@40028000$ V4 S$ p: b4 f
Hit SPACE in 3 seconds to stop autoboot.8 _8 U8 e6 z" J+ d$ u! v5 e
switch to partitions #0, OK$ s6 k1 R* D' u8 H. R  Q
mmc0 is current device
6 o+ V/ v8 Y9 c: M+ y7 }  dScanning mmc 0:1...( z3 Y+ E5 W: X9 U! K
U-Boot > setenv gatewayip 192.168.10.1;setenv ipaddr 192.168.10.22;setenv netmask 255.255.255.0;setenv ethaddr  1a:5a:38:ef:38:d8;, R* R% E9 P0 D0 F  l1 Z) ~- D
U-Boot > env set bootargs "root=/dev/ram console=ttyS0,115200 " ! O0 X- ~8 F- I& s/ Q
U-Boot > tftpboot 61000000 192.168.10.25:uImage;tftpboot 61300000 192.168.10.25:stm32h743i-eval.dtb; + F* F; |  t) p' e3 m
ethernet@40028000 Waiting for PHY auto negotiation to complete. done
: ^% _* z; K4 n  @9 N  AUsing ethernet@40028000 device
6 g$ z: Q8 \- E' i. T- j; {; Q: z+ j7 WTFTP from server 192.168.10.25; our IP address is 192.168.10.227 X- D( n3 H( \" a5 F! f9 `! ^
Filename 'uImage'.
! d& ^+ E: ?" u( JLoad address: 0x61000000% N% {8 I- a! r0 N
Loading: #################################################################% h  V5 k# s% L# A& u
         #################################################################" a1 H2 c8 f2 |# `9 z
         ##########4 L- u& m1 U3 H, N7 ^2 [$ y
         1.4 MiB/s1 G8 h& n- K, o4 l# Q; a: S9 f
done$ K5 }4 C8 T' x( s6 y2 P
Bytes transferred = 2048568 (1f4238 hex)3 y! S0 _& B0 v# m
ethernet@40028000 Waiting for PHY auto negotiation to complete. done0 t  R1 a5 \$ f, q1 M0 C- s" b
  H/ y/ |$ \* G; k+ X7 ]- u2 VTFTP from server 192.168.10.25; our IP address is 192.168.10.222 Q1 C+ ]" l* S% \5 [$ z
Filename 'stm32h743i-eval.dtb'.
1 M4 w8 {$ e9 {& mLoad address: 0x61300000
1 O3 ]# l7 `. X5 r! M. NLoading: #7 w! C5 @; ?$ C- _
         999 KiB/s
- q4 ]* c( z) N5 W' r  Vdone
1 \, @# m0 G0 dBytes transferred = 5115 (13fb hex)* l7 u* ?( q2 W" r: H
U-Boot > bootm 61000000 - 61300000 2 H1 s2 @0 D. {- V# U
## Booting kernel from Legacy Image at 61000000 .../ `* ~) {5 T( o: _1 @, I0 z
   Image Name:   linux7 O, Q* z- Y, y% F" P0 A* \
   Image Type:   ARM Linux Kernel Image (uncompressed)
: q; h2 r% N5 p+ u   Data Size:    2048504 Bytes = 2 MiB
3 `3 Y: m; B1 V( Y' Z. z) L9 o0 H   Load Address: 61000000- s: g& {# \! V: j
   Entry Point:  61000000& \2 M( c, Y# x* f
   Verifying Checksum ... OK2 M3 a0 O9 F4 b7 ^6 x; x4 x
## Flattened Device Tree blob at 61300000
4 s4 l7 J" S7 L3 z   Booting using the fdt blob at 0x61300000
) D0 F+ R. p1 m( g  X7 j/ z   Loading Kernel Image ... OK
9 i' W5 U% W, ^8 d   Using Device Tree in place at 61300000, end 613043fa* M, e* i! B# l$ ^) v1 x' ]
' h/ w# @% r8 l/ ]: E( o5 |" o' A
6 S, j3 X7 u9 N. y
Starting kernel ...; l3 \# }$ T" }; h' z* w
" k3 r$ H4 ^5 }0 R; e5 _
/ Q" W* s  [! l/ h- }
[    0.000000] Booting Linux on physical CPU 0x0* t  q5 b; A% C' H# r3 A. x
[    0.000000] Linux version 4.15.2-gb37c1e299-dirty (xiao@xd) (gcc version 6.3.1 20170620 (15:6.3.1+svn253039-1build1)) #134 PREEMPT Fri Dec 7 13:45:02 CST 2018
+ B) x# o. {2 q8 k, t( K[    0.000000] CPU: ARMv7-M [411fc271] revision 1 (ARMv7M), cr=00000000
, |* {. Z- U2 A8 u  w7 H) O  E[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
! V- [8 x) B  x: `& N  h[    0.000000] OF: fdt: Machine model: STMicroelectronics STM32H743i-EVAL board
% l; v! z& }$ Y[    0.000000] Reserved memory: created DMA memory pool at 0x61000000, size 2 MiB0 i- ?6 b+ t8 b% e1 |1 P6 W' k+ Y
[    0.000000] OF: reserved mem: initialized node linux,dma, compatible id shared-dma-pool  n1 y- M0 E# o' ]0 ~' h! \# Q
[    0.000000] Ignoring RAM after 0x61000000, memory at 0x61200000 ignored2 ~; ~$ Y8 h! ^& e, c! I
[    0.000000] Using ARMv7 PMSA Compliant MPU. Region independence: No, Used 2 of 16 regions
' O  m/ d* d2 G* ]6 T1 z[    0.000000] On node 0 totalpages: 4096
+ O; p( k" y( r, C' q: r# ^[    0.000000]   Normal zone: 32 pages used for memmap. a8 t1 C% W" J; }) `1 j1 N
[    0.000000]   Normal zone: 0 pages reserved
8 t- r3 b1 ^; h  r8 h[    0.000000]   Normal zone: 4096 pages, LIFO batch:02 T& F8 |1 G; i0 i+ o
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768- [9 L& h! s2 b6 H) @, ~
[    0.000000] pcpu-alloc: [0] 0 $ G$ ?. x* l3 S; ^+ W" m" g
[    0.000000] Built 1 zonelists, mobility grouping off.  Total pages: 4064: k/ j; u6 C9 ^; B) q# U# @
[    0.000000] Kernel command line: root=/dev/ram console=ttyS0,115200 ' I* p( f2 Y0 |+ D! {! F$ {
[    0.000000] Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
' v) {) E% ^/ `  M# g! b[    0.000000] Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
0 Z- K# I% e" p5 B/ Y) o4 Z. k! A[    0.000000] Memory: 13080K/16384K available (1596K kernel code, 154K rwdata, 496K rodata, 632K init, 130K bss, 3304K reserved, 0K cma-reserved)
, X% w: e; y. U1 x# e[    0.000000] Virtual kernel memory layout:1 m. @0 B* Q" P8 d, Z& {+ w( g0 f& F
[    0.000000]     vector  : 0x00000000 - 0x00001000   (   4 kB)
1 J" L% G" m$ Q[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)" J+ G3 A7 H, e( `1 {
[    0.000000]     vmalloc : 0x00000000 - 0xffffffff   (4095 MB)9 @. p  J0 u: a5 }& `6 n
[    0.000000]     lowmem  : 0x60000000 - 0x61000000   (  16 MB), s1 I) U: Z0 J, q
[    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (1597 kB)- G2 f" s& F3 g
[    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   ( 632 kB)/ q4 L3 A& ?" i8 F/ @  {" W6 j
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 155 kB)
7 u2 Q8 ^: `8 S, i/ x  |1 k[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 131 kB)! z" J) z. y* t3 ?. K( d" p, B4 p
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
" [' {5 e6 ]% n, D- |* U0 v1 _[    0.000000] Preemptible hierarchical RCU implementation.) Z2 h* a' q. c/ D6 p( M+ e" |
[    0.000000]  Tasks RCU enabled.2 Q  M8 M$ X2 X$ {# m
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16* w2 Q) j; j: E1 s0 a! M1 `
[    0.000000] clocksource: arm_system_timer: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 18664651 ns
6 B6 e9 t3 F% N1 w) B: T* k[    0.000000] ARM System timer initialized as clocksource5 W' L' l6 u/ H+ Y7 Z% s# H( P
[    0.000000] /soc/timer@40000c00: STM32 clockevent driver initialized (32 bits)- Y7 ]# D# Z4 p% N3 h! q* P
[    0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 21474836475000000ns5 \, [9 _9 p4 x1 l4 t
[    0.010000] Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216)- c. @  T$ l: J. e; \$ h- B6 }
[    0.100000] pid_max: default: 4096 minimum: 301
3 M( m: S( p+ {: j5 ^- b. y5 L& g* D[    0.100000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)( u6 Y& c. I8 Q& ]
[    0.100000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
4 {& P1 a% G( Z9 R2 d/ V[    0.100000] Hierarchical SRCU implementation." Z+ S8 n: u: l, t& u
[    0.100000] devtmpfs: initialized% `: v% }  A# v. t. a( p, }; i) t
[    0.110000] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
  h+ F8 d+ S: N6 M2 e[    0.110000] pinctrl core: initialized pinctrl subsystem5 j* E, @  L1 ^( f
[    0.110000] DMA: default coherent area is set
1 m0 f: J) m' Q+ f( N" ]0 z[    0.110000] random: get_random_u32 called from bucket_table_alloc+0xc9/0xf4 with crng_init=0
- I5 n" {2 ]' N1 a+ ^5 t+ J1 m[    0.110000] NET: Registered protocol family 16
0 Y. a! k7 O! }5 ]1 l4 R. G; l; L[    0.120000] cpuidle: using governor ladder
( [3 }2 a! i% G2 j4 b( k. H[    0.120000] cpuidle: using governor menu
+ w/ w5 Y( t- n9 m& O5 A[    0.130000] stm32h743-pinctrl soc:pin-controller: GPIOA bank added$ m, R( V5 w+ Y# A0 l
[    0.130000] stm32h743-pinctrl soc:pin-controller: GPIOB bank added& K% Y0 R- M& f$ t
[    0.130000] stm32h743-pinctrl soc:pin-controller: GPIOC bank added
2 I6 y  R' Y( v4 ]9 \[    0.130000] stm32h743-pinctrl soc:pin-controller: GPIOD bank added  a) [" L. o7 w- N1 c8 R
[    0.130000] stm32h743-pinctrl soc:pin-controller: GPIOE bank added+ @) J+ b1 O! n. e$ ]; C( }
[    0.130000] stm32h743-pinctrl soc:pin-controller: GPIOF bank added
- F, p+ `5 _6 H! b# X) t[    0.140000] stm32h743-pinctrl soc:pin-controller: GPIOG bank added! i8 Q* E; g! G% x
[    0.140000] stm32h743-pinctrl soc:pin-controller: GPIOH bank added& l) C7 V" a9 F/ ]6 X$ `, u
[    0.140000] stm32h743-pinctrl soc:pin-controller: GPIOI bank added
8 M" b. r4 C2 _3 O[    0.140000] stm32h743-pinctrl soc:pin-controller: GPIOJ bank added
: g0 ?/ G. e8 c* x[    0.140000] stm32h743-pinctrl soc:pin-controller: GPIOK bank added% }: i& X5 S- H
[    0.140000] stm32h743-pinctrl soc:pin-controller: Pinctrl STM32 initialized
+ O" t* _2 `4 S5 T9 n0 \: G8 B* r1 }[    0.160000] pps_core: LinuxPPS API ver. 1 registered" `- k  [+ m+ W) M
[    0.160000] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>7 R6 \; L) T( I" m7 Y" E: A' w
[    0.160000] PTP clock support registered# i6 r& }* `" C0 r1 R( C& g. r5 l
[    0.160000] clocksource: Switched to clocksource arm_system_timer
$ x, I% t1 ^; R: _. Q' T" `& u[    0.170000] NET: Registered protocol family 2
6 ^7 P# x( N; T* y: W+ w[    0.170000] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
" F  Y' c9 k# v4 f* B  T6 _[    0.170000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
- Q) }9 k* C5 [( h% k1 _[    0.170000] TCP: Hash tables configured (established 1024 bind 1024), ]$ x9 M* M: M) O" I
[    0.170000] UDP hash table entries: 256 (order: 0, 4096 bytes). L( {3 G2 t4 F$ K8 ^; L( b( o, d
[    0.170000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
* E7 q) b1 Q  ^) N7 P[    0.170000] NET: Registered protocol family 11 ~5 O  R9 v. g4 L( n/ q" K! W
[    0.360000] workingset: timestamp_bits=30 max_order=12 bucket_order=01 ?) K5 l8 u9 R+ m2 X0 l" S
[    0.380000] random: fast init done
  N7 h/ E7 n; o[    0.400000] io scheduler noop registered1 C4 a, A# g; n
[    0.400000] io scheduler deadline registered- |3 T# W' @- k, t1 w* J( E( i! g
[    0.400000] io scheduler cfq registered (default)# I2 N% a0 s1 X0 w' H$ p
[    0.400000] io scheduler mq-deadline registered$ B" y0 q( b$ W4 ~; }: I4 _1 |
[    0.400000] io scheduler kyber registered
# e: T: v4 D1 P. v2 n[    0.400000] STM32 USART driver initialized
, X# l- S% q+ B# G; w  G) o0 y[    0.400000] 40011000.serial: ttyS0 at MMIO 0x40011000 (irq = 17, base_baud = 12500000) is a stm32-usart0 }$ G; Q( B2 R9 [
[    0.850000] console [ttyS0] enabled
& S: x+ x8 \1 l; j7 d[    0.850000] stm32-usart 40011000.serial: rx dma alloc failed8 ]0 P! ?: K9 u* f0 [4 g
[    0.860000] stm32-usart 40011000.serial: interrupt mode used for rx (no dma)
9 \8 X/ y0 P# C7 W6 L; ~; f& B[    0.870000] stm32-usart 40011000.serial: tx dma alloc failed
: m6 M2 f- R) g8 C& W[    0.870000] stm32-usart 40011000.serial: interrupt mode used for tx (no dma)/ d! S$ s2 @, `( L: u4 y+ `
[    0.880000] libphy: Fixed MDIO Bus: probed8 B, p3 v/ B" d. U
[    0.890000] tun: Universal TUN/TAP device driver, 1.66 [8 e, E) U9 [* L4 x* Y( g) [
[    0.890000] stm32-dwmac 40028000.ethernet: Found phy-handle subnode4 q7 R) h% ]( f) ~( W
[    0.900000] stm32-dwmac 40028000.ethernet: Found MDIO subnode! i5 {" X- @: v+ R7 g
[    0.910000] stm32-dwmac 40028000.ethernet: use snps,dwmac-4.00..+ E6 R! g1 I, c- x
[    0.910000] stm32-dwmac 40028000.ethernet: PTP uses main clock0 F/ m' m: j" P. l2 D/ ?
[    0.910000] stm32-dwmac 40028000.ethernet: no reset control found
! a% b% S' r/ i$ u4 M[    0.930000] stmmac - user ID: 0x30, Synopsys ID: 0x41  }( x) ^1 F9 o3 T# }2 n& z* W
[    0.930000] stm32-dwmac 40028000.ethernet: DMA HW capability register supported
- \0 @2 p0 {2 e) Z5 F& T[    0.930000] stm32-dwmac 40028000.ethernet: RX Checksum Offload Engine supported9 e6 H# r0 i6 H9 _1 R
[    0.950000] stm32-dwmac 40028000.ethernet: TX Checksum insertion supported# {( M+ w2 q9 h9 F% i  a8 Y4 O
[    0.950000] stm32-dwmac 40028000.ethernet: Wake-Up On Lan supported( U4 ]' ?" |0 t1 {' f
[    0.950000] stm32-dwmac 40028000.ethernet: TSO supported5 S, b+ g3 u" j% q
[    0.970000] stm32-dwmac 40028000.ethernet: Enable RX Mitigation via HW Watchdog Timer
- o) Y3 V( V) q; k- H[    0.970000] stmmac_mdio_reset : reset gpio direction num=28
! m0 {4 l1 z, Z: I7 e# N5 q[    1.080000] libphy: stmmac: probed
7 k* @* R$ A( E2 ^# W[    1.090000] stm32-dwmac 40028000.ethernet: register the MDIO bus& l3 O  h* Y* Z- f: V
[    1.100000] u32 classifier
# c) |% `- X! u* j& d3 G8 ~6 d$ {[    1.100000] Initializing XFRM netlink socket; ^. u, h1 ?) ^; [& ]
[    1.110000] NET: Registered protocol family 17
+ _! Z* w* {2 g7 d% b# x4 W; G4 \+ i  I[    1.110000] NET: Registered protocol family 15. ^" J9 ^1 k5 d& r
[    1.110000] 8021q: 802.1Q VLAN Support v1.8! [& t1 C6 T! Z8 F  I
[    1.120000] Key type dns_resolver registered8 b0 W, }" z+ D7 _9 F
[    1.130000] Freeing unused kernel memory: 632K. t% B5 K9 [* e, O
[    1.140000] This architecture does not have kernel memory protection.
1 u. f5 d( W, P- y/ wcan't run '/sbin/swapon': No such file or directory* s% B- q/ |5 V' ^# v- d
Initializing random number generator... done.
1 L* p: p9 ]# G# }Jan  1 00:00:01 login[59]: root login on 'console'. C) A4 F& N: y! B
' ]' _& G0 L9 x2 c
赞 收藏 5 评论16 发布时间:2018-11-22 15:29
16个回答
stone-363407 回答时间:2018-12-7 16:08:07
1 t$ r) A/ z- M8 \' S( b- X" n
7 g2 k4 O+ ?" `0 B% Lcpu 400Mhz  sdram 100mhz  cas=2 4 _& B. d7 w. u9 ]* M8 d& e" ]7 {
测试软件:iperf3 / M& w: n' _" r- N* X  @. L
系统跑了25个线程测试速度如下。。。。没有原子裸奔的那个快............
0 B6 H% ^, A4 C  B5 N65.8 Mbits/sec
0 o+ l5 b7 b% \. ^& E: ~4 c
~ # cat /proc/cpuinfo # b8 \  A3 d. x- @* J
processor       : 0
# D& r. A% K" }7 _5 c, X8 gmodel name      : ARMv7-M rev 1 (v7ml)
  u: l4 m0 T; M8 HBogoMIPS        : 795.44
0 d+ T0 c- e; b$ ~8 C: FFeatures        : half thumb fastmult edsp idivt
8 A* a8 F- X: L! l( \CPU implementer : 0x413 h3 ~" M, I: d$ N9 j
CPU architecture: 7M& m3 ^5 h5 r) G9 j# H
CPU variant     : 0x1
5 c4 Q2 j  D, s) t: |0 p6 L, rCPU part        : 0xc27# s( d5 q8 f2 F- b- N
CPU revision    : 1
( U7 R5 Y( e# S: Z& j$ O$ Y) W3 c: A! N+ h
Hardware        : STM32 (Device Tree Support). r8 Z" L! A! ~7 @5 Y
Revision        : 0000
. G5 c3 W$ w3 R0 X# fSerial          : 0000000000000000
% \3 {' i' \% P" x% \~ # iperf3 -c 192.168.10.26
1 F4 K0 O# f2 Z9 I/ G' y5 p; x6 K0 dConnecting to host 192.168.10.26, port 52012 B7 E# B& C& b  @6 r/ E) W
[  4] local 192.168.10.22 port 41328 connected to 192.168.10.26 port 5201
8 [; s3 \6 P: r* ?1 o! l  _  Y9 `[ ID] Interval           Transfer     Bandwidth       Retr  Cwnd8 o- d% H4 F8 r4 f1 j
[  4]   0.00-1.01   sec  7.57 MBytes  63.0 Mbits/sec    0    173 KBytes       - q/ v" j4 ?8 P3 r6 ]
[  4]   1.01-2.03   sec  8.22 MBytes  67.3 Mbits/sec    0    181 KBytes       $ w7 b3 c8 c2 Y9 n/ _; L
[  4]   2.03-3.15   sec  8.75 MBytes  66.0 Mbits/sec    0    181 KBytes       * b7 ~2 n  j3 y: W" Y8 b+ t
[  4]   3.15-4.04   sec  6.90 MBytes  65.0 Mbits/sec    0    181 KBytes       # O3 Z# `" K" g8 J# E1 e
[  4]   4.04-5.15   sec  8.70 MBytes  65.4 Mbits/sec    0    181 KBytes       7 L1 E/ G$ z5 p, ]' B  s: b3 `
[  4]   5.15-6.10   sec  7.40 MBytes  65.5 Mbits/sec    0    181 KBytes
) C' Y2 }  t& e2 H" N1 Y[  4]   6.10-7.01   sec  7.37 MBytes  67.7 Mbits/sec    0    191 KBytes
8 f' w+ L# N0 |% v5 o& L2 n0 |3 p[  4]   7.01-8.16   sec  8.95 MBytes  65.6 Mbits/sec    0    191 KBytes         m0 `9 Y6 ~1 x; M; c
[  4]   8.16-9.02   sec  6.86 MBytes  66.5 Mbits/sec    0    191 KBytes
2 Q8 N1 ?0 y$ o* x* S& q[  4]   9.02-10.13  sec  8.73 MBytes  65.9 Mbits/sec    0    191 KBytes       4 ?( F. _: [/ _! B! O, Q2 M  X  R
! r- u5 ^! v% f& _; f) ]. l) \# i[ ID] Interval           Transfer     Bandwidth       Retr
; A/ ^- R! e5 T* B4 `# z[  4]   0.00-10.13  sec  79.4 MBytes  65.8 Mbits/sec    0             sender* ^2 p; v5 c3 i% ?9 q; M' ?
[  4]   0.00-10.13  sec  79.4 MBytes  65.8 Mbits/sec                  receiver
  v) g6 Q# I3 E. f) {4 J7 r; |+ |6 C  q
iperf Done.! d& L' X" v; |' m
~ # ps( a4 l' J% Q. Q* U+ u
  PID USER       VSZ STAT COMMAND
  ?3 ^6 S* }$ @. ?    1 root       400 S    init8 ]6 E, W6 M1 I( c
    2 root         0 SW   [kthreadd]/ {/ `% y: z# K1 D/ _! G* w% F
    4 root         0 IW<  [kworker/0:0H]# s- \9 ?+ ]: n/ O  ]& d
    6 root         0 IW<  [mm_percpu_wq]6 B4 U+ H3 q( D8 J6 }
    7 root         0 SW   [ksoftirqd/0]- S+ K! K! n" Q1 X+ L
    8 root         0 IW   [rcu_preempt]
, R4 g9 u; }3 o/ \    9 root         0 IW   [rcu_sched]
& C5 C) i( p5 @( v) u1 ^   10 root         0 IW   [rcu_bh]% n6 ~0 G2 U4 O+ a* J' @, C7 i7 l" S; X
   11 root         0 SW   [kdevtmpfs]- U' V1 y! \# M5 c8 E# t. t6 {
   12 root         0 SW   [rcu_tasks_kthre]: o% I2 I- C. j1 a4 c5 o8 \
   14 root         0 IW<  [writeback]
( j9 S. I0 `1 |9 l5 \   15 root         0 IW<  [crypto]9 \' ^! E  G  l( x. ~) e3 E# q( T) u
   16 root         0 IW<  [kblockd]5 U1 M/ U; N; b
   17 root         0 IW<  [watchdogd]5 A+ |- T* j. j$ v1 n: V
   18 root         0 SW   [kswapd0]
  Y/ o; L+ Q, h3 z2 s& |8 j   41 root         0 SW   [irq/17-40011000]
# |1 E9 U3 |; x   59 root       420 S    -sh( c( S6 ]+ x8 ]4 |# [; K% D# ~
   60 root         0 IW   [kworker/u2:1]# n' {, b- c6 h* x% D3 i
   61 root         0 IW   [kworker/u2:2]
. k+ }) |/ @0 A# ^   64 root         0 IW   [kworker/0:2]
, D# M. f  h. t$ _   65 root         0 IW   [kworker/0:3]  T* t" I! z# w2 p$ V/ h
   71 root         0 IW   [kworker/0:0]6 i7 x8 `: d7 R: p" L
   75 root       396 R    ps
yhangzzz 回答时间:2019-3-7 20:20:51
" ], R) s, y( b
" a" B1 T( x# ]5 y9 h# r6 O4 V; ]% |- n楼主,您好,看了您的贴子,手头正好有一块stm32f746-disco 的板子,按照您的思路,移植了uboot2016.09,移植了uboot eth驱动,因为没有移植MMC驱动,就打算把linux内核加载在SDRAM上,再从SDRAM启动内核;使用的是linux4.19.24默认的stm32配置,但是现在一直卡在“Starting kernel ...”,内核应该是没有起来;不知道您调试过程中是否遇到这个问题。附上打印的信息:. l3 W# _/ {" _2 j3 p2 s# A
. G' {' r/ X. x" u7 v
U-Boot 2016.09-g83ec55b-dirty (Feb 22 2019 - 18:30:58 +0800)8 U: c; R. U0 R3 W' L; }: f0 ^
4 r" T5 L: t' ?! C" K; X+ t: B/ v# nDRAM:  8 MiB+ U0 X7 M5 E! M, n1 B% p  q
WARNING: Caches not enabled9 a5 a+ b& g, G+ d- Q; a
Flash: 1 MiB! z9 `: L  l" m+ n* x. g0 B
Using default environment
& k3 x1 G# ~0 k9 `: `3 v9 B( d3 f0 `0 W& W" n
In:    serial_stm32x7
% g1 v+ d8 j6 E/ D! sOut:   serial_stm32x7
& e" W/ a5 k+ G& @7 s  FErr:   serial_stm32x7+ \* e8 K1 ?' B( L) n" `. G
Net:
* a! y$ p7 `3 W1 _4 Q( y6 D( istm32 eth probe start; ^; s: @1 X5 t- m3 p
stm32 eth probe end$ g9 R5 w, x, d
stm32_read_rom_hwaddr! |! l4 f# J9 Y- Z
" I7 o" E5 c* `; |( B* k
Warning: eth_stm32_eth using MAC address from ROM5 f3 ]# d2 [7 C8 I
eth0: eth_stm32_eth9 n" k: P/ ]4 ?. z
stm32_write_hwaddr* Z4 U7 y' s. ^. t* b6 w
6 f6 g8 d, a- a" A8 P( z
. D/ m6 ?6 B# t* F1 z8 y( d  vU-Boot > set ipaddr 10.0.0.2
# ^4 l! r# ?- h0 `. dU-Boot > set serverip 10.0.0.6
2 A) A; d" v, Q6 o+ Z" `4 C2 lU-Boot > tftp c0400000 uImage.bin
3 f, o5 r5 s/ w3 R2 n+ r7 h& j9 f) i2 m! o$ |1 o% S
stm32_eth_stop start
, O2 w# q6 H" Y3 ^% Kstm32_eth_stop end/ f& `, @3 ^! r+ k$ F6 K. a6 R
+ ^: f* k& h- u4 C4 f
stm32_eth_start start6 H& [8 ~$ U, k3 A+ O
stm32_eth_start end6 x8 p. k6 B! |. C3 `, M! |. c
Using eth_stm32_eth device
0 I: }! G+ `2 S8 _/ A% [TFTP from server 10.0.0.6; our IP address is 10.0.0.2
' j* f3 q7 y7 R9 R& x$ KFilename 'uImage.bin'.0 Q7 C5 E' q  E  v, E* T/ M: n
Load address: 0xc0400000( r) h5 Y8 h/ ~4 R7 T6 Z* ?; ]9 I: U  ^
Loading: #################################################################' {% G( R/ w+ v* d
  k! H4 \# A4 n  \. G8 ?         2 MiB/s
3 K! |4 p7 V% V2 q3 ]' M3 E' ~done
' [: d7 X) _  I1 q) R3 H+ z% bBytes transferred = 1337888 (146a20 hex)
5 M3 v. I: B& P! g- b- Q; q+ v* v* {6 l6 ?9 j
stm32_eth_stop start: `9 r3 g( Z) x
stm32_eth_stop end- L  p4 Q! Z* N2 H
U-Boot > tftp c0600000 discodtb.bin8 {4 _* ^) L5 W& y+ R
# e2 B% k9 u  K6 j1 [
8 d5 d: d3 G, y9 Z3 Wstm32_eth_stop end
! I/ g1 o7 m9 ?0 k  v, Y9 U& {9 H1 I7 F2 j
stm32_eth_start start& ^' M3 ]: i: j( z
stm32_eth_start end
3 W+ d7 y% [4 FUsing eth_stm32_eth device
! b0 }$ J- [. D$ F0 n: E3 DTFTP from server 10.0.0.6; our IP address is 10.0.0.22 j3 o& Y4 `" R& Q$ g( r
Filename 'discodtb.bin'.' `( s. `2 {! B" {" g
Load address: 0xc0600000
- m0 \$ ]: r( R7 L1 ALoading: ##' x8 c0 w1 I3 z5 H0 T0 P
         966.8 KiB/s
% b/ n3 ]6 Z- Y6 \0 |/ Wdone
& C9 z& |# W; N0 ^$ o6 V% _- PBytes transferred = 14858 (3a0a hex)
' _1 G2 j( V: [/ B5 I, O6 c& ^* X, m! k7 x% n$ v( ^9 x
stm32_eth_stop start  A. x# e: s7 ^
stm32_eth_stop end
# i  \$ m$ V8 o  @. P% W; h5 P; uU-Boot > bootm c0400000 - c0600000" G3 R( I' b: H  F4 z
## Booting kernel from Legacy Image at c0400000 ...; Z* p2 b, n1 _& X. S- {& M+ r
   Image Name:   Linux-4.19.24
$ m$ `% M7 ~  o   Image Type:   ARM Linux Kernel Image (uncompressed)
" \9 U. e$ C4 h7 v2 S8 B   Data Size:    1337824 Bytes = 1.3 MiB
/ r# l7 W# I& F( J) J8 z   Load Address: c0008000
& @4 n& D# z  X8 w; \) O: s& O   Entry Point:  c0008000
0 |2 Z% |7 v( K; m- m   Verifying Checksum ... OK
2 D2 z8 g  \) K0 _## Flattened Device Tree blob at c0600000( i7 @+ D% T" c
   Booting using the fdt blob at 0xc0600000
! Z2 N6 K2 `0 h* u   Loading Kernel Image ... OK! _0 y% {! B. H1 ]9 ^1 @5 F) G
   Loading Device Tree to c07c7000, end c07cda09 ... OK" d* w# q5 B7 {4 l/ {5 |6 D8 a
" n$ _% c* O, n
Starting kernel ...
: [( Q# N. W0 `" [$ S$ L
6 P, h7 ?; I4 s% b6 |$ G% h$ k
stone-363407 回答时间:2018-11-25 11:03:43
eth 刚刚测试完成,只移植了UBOOT下的eth" X3 ]: n& U, K& f+ |( G
' `# N; B/ B5 y& |; o5 v7 Q) T6 ?
U-Boot 2018.09-rc2-g36b739b (Nov 25 2018 - 10:45:48 +0800)- I, c, W. E/ L2 [9 j" Z
) b) D, e; ^/ @$ Q" IModel: STMicroelectronics STM32H743i-EVAL board7 t0 u2 d% |; M5 w( S9 L# u
DRAM:  32 MiB
& B7 ^0 D- I. ^  B; v+ m8 [MMC:   STM32 SDMMC2: 0
8 O5 R; e% j) p, BIn:    serial@400110003 Q/ l7 I' e9 ]/ ^4 |* I/ Z. X
Out:   serial@40011000( I3 u- F) J. K' M
7 C5 c1 c: d- eNet:
" {, T( }2 G: ]Warning: ethernet@40028000 (eth0) using random MAC address - b6:1d:0e:15:99:e3
8 M: J3 B6 R! k" J- Ieth0: ethernet@40028000# s; B& ]9 X( r/ r# F" V
Hit SPACE in 3 seconds to stop autoboot.0 F# b+ m1 w3 j' Q, D2 W
Card did not respond to voltage select!3 A1 u- L# p: z6 a. E. `& }  H7 [
U-Boot > tftpboot 0x60001000 192.168.1.103:u-boot.bin / |7 ^5 }: l6 N$ \" r
ethernet@40028000 Waiting for PHY auto negotiation to complete... done
4 ]8 `" M' T" H- Y# \1 S*** ERROR: `ipaddr' not set# s( Z# `7 C% [2 I9 ^0 T: t
U-Boot > set ipaddr 192.168.1.101;set serverip 192.168.1.1;set ethaddr d6:54:97:9f:9a:90;
& E0 v8 l8 q3 m; ^9 w# y/ o: MU-Boot > tftpboot 0x60001000 192.168.1.103:u-boot.bin 8 u+ {  o- Y: s# `9 ~- c" q; \
7 W, D" E! b1 B7 y8 d, YUsing ethernet@40028000 device
( S6 p* V- x, _- MTFTP from server 192.168.1.103; our IP address is 192.168.1.1017 L, i7 X( t' h
Filename 'u-boot.bin'.
3 Y( [- U8 \7 X$ r4 cLoad address: 0x60001000
, e! q! X2 L' K9 B  ]Loading: ##################6 e! o% P! F4 R7 Q+ D/ _* b
         1.8 MiB/s
8 @7 n% N) U4 Q( M8 Sdone+ v9 O/ z& A, i$ d% U
Bytes transferred = 257336 (3ed38 hex)
* i: U3 ^% r9 ^) C% ]2 IU-Boot > cmp.b 60001000 8000000 3ed38 * }- @6 {2 j9 r( g" G
Total of 257336 byte(s) were the same! c6 L  N- L6 \4 ]& X- [& Z# V
* T. f/ V  F6 k1 }! J  Y/ C接下来看看kernel 咋能。0 z* ?9 m- X3 ?" a
; n! ~. s: v- e/ y" }# `) [6 p/ ]
说下eth dma 最大的注意事项,就是cache dma  ram  一致性,  卡了好个晚上,对于这个一致性,没有多少经验,希望大家给点经验指导下。
mzy2364 回答时间:2018-11-22 15:43:47
赞,这个厉害
andey 回答时间:2018-11-22 16:45:58
stone-363407 回答时间:2018-12-7 16:12:46
另外附上 uboot 下SD卡的速度
; R# o4 H, e9 x* d, C( b) K' S% i6 u+ o" i6 z& c6 K
1 Z9 [9 z+ K$ F8 ]+ V$ x- @- rmmc0 is current device
: _! `0 Z0 E  Y; t4 W: `) X2 PScanning mmc 0:1...
4 A, E) a" L7 z# dU-Boot > fatload mmc 0 60008000 uImage;fatload mmc 0 60800000 stm32h743i-eval.dtb - d! ]* d* P3 l1 T% r7 E( F  I
1926672 bytes read in 19 ms (96.7 MiB/s)
' }# ^9 K1 S$ `2 W# F2 G9370 bytes read in 2 ms (4.5 MiB/s)
# V+ |8 a) M  T; U, T# D0 ZU-Boot >
STMWoodData 回答时间:2018-12-7 16:25:35
stone-363407 回答时间:2018-12-19 14:42:14
6#数据因为timer 不对所以数据不对 抱歉!!!
3111272 回答时间:2019-3-8 08:58:55
厉害厉害
stone-363407 回答时间:2019-3-12 21:14:54
yhangzzz 发表于 2019-3-7 20:20
! x2 J; F8 h, h7 D' W楼主,您好,看了您的贴子,手头正好有一块stm32f746-disco 的板子,按照您的思路,移植了uboot2016.09,移 ...
# {- D; R0 Q) _& ]请查看串口定义部分 高版本内核串口的定义不一样 ttys0 具体看下驱动代码
stone-363407 回答时间:2019-3-12 21:53:59
本帖最后由 stone-363407 于 2019-3-12 21:57 编辑 6 a& d. i0 Y: D( q" E8 L: k
yhangzzz 发表于 2019-3-7 20:200 F) y1 M+ X: h- W+ P
! y, M% e1 h" h7 ^& \看下这个如果你用的内核版本是这样. _4 Q' Y  O. d% V5 {$ M$ `2 n; `, W& y
git\linux-4.19.9\drivers\tty\serial\stm32-usart.h
# i  g) X7 T, u3 S/ _! z4 l# S. z2 l. ]3 D) D
#define _SERIAL_NAME "ttySTM"
0 A( j$ d. i4 m* e! \5 o3 [把这个    U-Boot > env set bootargs "root=/dev/ram console=ttyS0,115200 "
( K3 d7 d4 g3 x
; q+ f& ^, U' u# ]' d
  E8 y0 j& ~% z) b% _
改成这个
  @" b3 s0 Z- }0 y: `5 k! ^+ @3 C5 ?8 V
2 D+ I% }: Z) g4 m2 G! S* m+ a$ b
env set bootargs "root=/dev/ram console=ttySTM,115200 "
- @6 |& f0 r" d6 B# M8 T1 ~. M, O- |8 V8 K$ `7 I: m- x$ e. R
/ w+ Q6 F. E4 {* C- l5 p5 W
- X& U8 ~5 Y5 O9 p/ ^- U' u; M+ I
这个STM工程师比较那个,我也被坑了,各种分析,内存BUFF分析 等等 我就像骂一句 mmp' \6 {( `3 W- Z! ^( L% n; P5 O
stary666 回答时间:2019-3-12 22:18:05
太牛了,,,,,,
yhangzzz 回答时间:2019-3-15 09:01:25
stone-363407 发表于 2019-3-12 21:53
" j8 \# g- p0 s" ^看下这个如果你用的内核版本是这样$ L8 v2 Y% a0 g( K$ E8 `8 a
% a5 W7 _5 E6 G- B* C% Q! A
谢楼主啊,我回头试一下
yhangzzz 回答时间:2019-3-15 11:25:50
% O) f2 A- P# Z( p看下这个如果你用的内核版本是这样
* m/ ]; ~( z+ e. S: q6 B: b1 lgit\linux-4.19.9\drivers\tty\serial\stm32-usart.h
: |8 Z, C* f3 t8 g楼主您好,linux内核确实是你说的那样,但是改了uboot的bootargs后,仍然不能在启动内核后打印信息。。。stm的工程师看来是只管写不管有没有用啊。。。
12下一页
