怎么利用配置DFSDM滤波器只采集特定频率范围内的音频信号
meng3983 提问时间:2018-11-30 16:47 /
只想采集20-2000Hz以内的音频信号改怎么配置DFSDM,配置44.1K代码如下:
void DFSDM_Init(void)
  /* Initialize channel 2 */
  __HAL_DFSDM_CHANNEL_RESET_HANDLE_STATE(&DfsdmChannelHandle);
  DfsdmChannelHandle.Instance                      = DFSDM1_Channel2;
  DfsdmChannelHandle.Init.OutputClock.Activation   = ENABLE;
  DfsdmChannelHandle.Init.OutputClock.Selection    = DFSDM_CHANNEL_OUTPUT_CLOCK_AUDIO;
  DfsdmChannelHandle.Init.OutputClock.Divider      = 4; /* 11.294MHz/4 = 2.82MHz */
  DfsdmChannelHandle.Init.Input.Multiplexer        = DFSDM_CHANNEL_EXTERNAL_INPUTS;
  DfsdmChannelHandle.Init.Input.DataPacking        = DFSDM_CHANNEL_STANDARD_MODE; /* N.U. */
  DfsdmChannelHandle.Init.Input.Pins               = DFSDM_CHANNEL_SAME_CHANNEL_PINS;
  DfsdmChannelHandle.Init.SerialInterface.Type     = DFSDM_CHANNEL_SPI_RISING;
  DfsdmChannelHandle.Init.SerialInterface.SpiClock = DFSDM_CHANNEL_SPI_CLOCK_INTERNAL;
  DfsdmChannelHandle.Init.Awd.FilterOrder          = DFSDM_CHANNEL_FASTSINC_ORDER; /* N.U. */
  DfsdmChannelHandle.Init.Awd.Oversampling         = 10; /* N.U. */
  DfsdmChannelHandle.Init.Offset                   = 0;
  DfsdmChannelHandle.Init.RightBitShift            =0;
  if(HAL_OK != HAL_DFSDM_ChannelInit(&DfsdmChannelHandle))
    Error_Handler();
  /* Initialize filter 0 */
  __HAL_DFSDM_FILTER_RESET_HANDLE_STATE(&DfsdmFilterHandle);
  DfsdmFilterHandle.Instance                          = DFSDM1_Filter0;
  DfsdmFilterHandle.Init.RegularParam.Trigger         = DFSDM_FILTER_SW_TRIGGER;
  DfsdmFilterHandle.Init.RegularParam.FastMode        = ENABLE;
  DfsdmFilterHandle.Init.RegularParam.DmaMode         = ENABLE;
  DfsdmFilterHandle.Init.InjectedParam.Trigger        = DFSDM_FILTER_SW_TRIGGER; /* N.U. */
  DfsdmFilterHandle.Init.InjectedParam.ScanMode       = ENABLE; /* N.U. */
  DfsdmFilterHandle.Init.InjectedParam.DmaMode        = DISABLE; /* N.U. */
  DfsdmFilterHandle.Init.InjectedParam.ExtTrigger     = DFSDM_FILTER_EXT_TRIG_TIM1_TRGO; /* N.U. */
  DfsdmFilterHandle.Init.InjectedParam.ExtTriggerEdge = DFSDM_FILTER_EXT_TRIG_RISING_EDGE; /* N.U. */
  DfsdmFilterHandle.Init.FilterParam.SincOrder        =DFSDM_FILTER_SINC3_ORDER;
  DfsdmFilterHandle.Init.FilterParam.Oversampling     = 64; /* 11.294MHz/(4*64) = 44.1KHz */
  DfsdmFilterHandle.Init.FilterParam.IntOversampling  = 1;
  if(HAL_OK != HAL_DFSDM_FilterInit(&DfsdmFilterHandle))
    Error_Handler();
  /* Configure regular channel and continuous mode for filter 0 */
  if(HAL_OK != HAL_DFSDM_FilterConfigRegChannel(&DfsdmFilterHandle, DFSDM_CHANNEL_2, DFSDM_CONTINUOUS_CONV_ON))
    Error_Handler();
参与人数 1 ST金币 +20 收起 理由
STMCU + 20
赞 收藏 1 评论4 发布时间:2018-11-30 16:47
4个回答
meng3983 回答时间:2018-12-3 14:11:41
没人玩过吗
tanic 回答时间:2018-12-5 09:32:22
这是个新东西,楼主可以研究研究,在写个教程
cruelfox 回答时间:2018-12-5 10:49:21
接的数字麦克风么?
不能把 DFSDM 的输出时钟降那么低,否则数字麦克风可能不工作。你想限制带宽的话,DFSDM 采进来降采样之后(比如CKOUT 3.072MHz, 64倍降采样到48kHz PCM),再自己用软件做FIR低通,再做降采样。
xmshao 回答时间:2018-12-5 16:56:03
感觉你就是想做个带通滤波器(20~2000Hz),你可以通过软件滤波,或者外部添加带通滤波实现。
