Load "..\\OBJ\\Template.axf" * JLink Info: Reset: Halt core after reset via DEMCR.VC_CORERESET. * JLink Info: Reset: Reset device via AIRCR.SYSRESETREQ. WS 1, `mem1base WS 1, `mem2base WS 1, `mem3base WS 2, `paddr_8 WS 2, `paddr_16 WS 2, `paddr_32 **JLink Warning: T-bit of XPSR is 0 but should be 1. Changed to 1. ***JLink Error: Can not read register 33 (FPS0) while CPU is running ***JLink Error: Can not read register 34 (FPS1) while CPU is running ***JLink Error: Can not read register 35 (FPS2) while CPU is running ***JLink Error: Can not read register 36 (FPS3) while CPU is running ***JLink Error: Can not read register 37 (FPS4) while CPU is running ***JLink Error: Can not read register 38 (FPS5) while CPU is running ***JLink Error: Can not read register 39 (FPS6) while CPU is running ***JLink Error: Can not read register 40 (FPS7) while CPU is running ***JLink Error: Can not read register 41 (FPS8) while CPU is running ***JLink Error: Can not read register 42 (FPS9) while CPU is running ***JLink Error: Can not read register 43 (FPS10) while CPU is running ***JLink Error: Can not read register 44 (FPS11) while CPU is running ***JLink Error: Can not read register 45 (FPS12) while CPU is running ***JLink Error: Can not read register 46 (FPS13) while CPU is running ***JLink Error: Can not read register 47 (FPS14) while CPU is running ***JLink Error: Can not read register 48 (FPS15) while CPU is running ***JLink Error: Can not read register 49 (FPS16) while CPU is running ***JLink Error: Can not read register 50 (FPS17) while CPU is running ***JLink Error: Can not read register 51 (FPS18) while CPU is running ***JLink Error: Can not read register 52 (FPS19) while CPU is running ***JLink Error: Can not read register 53 (FPS20) while CPU is running ***JLink Error: Can not read register 54 (FPS21) while CPU is running ***JLink Error: Can not read register 55 (FPS22) while CPU is running ***JLink Error: Can not read register 56 (FPS23) while CPU is running ***JLink Error: Can not read register 57 (FPS24) while CPU is running ***JLink Error: Can not read register 58 (FPS25) while CPU is running ***JLink Error: Can not read register 59 (FPS26) while CPU is running ***JLink Error: Can not read register 60 (FPS27) while CPU is running ***JLink Error: Can not read register 61 (FPS28) while CPU is running ***JLink Error: Can not read register 62 (FPS29) while CPU is running ***JLink Error: Can not read register 63 (FPS30) while CPU is running ***JLink Error: Can not read register 64 (FPS31) while CPU is running 请问这是什么问题? |
