最近在移植 niche stack 网络协议栈,用的操作系统是 ucos ii ,硬件平台是 NUCLEO H743ZI遇到了一些问题请教一下各位。 现象:用ATKKPING 做PING测试。按下复位键单片机开始运行,PING时间<1ms,过了一会就会PING不通,或者PING延时非常高。以上是在我去掉 FTP 、TELNET、 PINGAPP 等一些无关任务后做的测试。附件是我用 SYSTEM VIEW 抓到的数据。 我也移植到了FREERTOS下但是也遇到了相似问题,所以回到Ucos 下。 下面是我的的 时钟、 MPU、 ETHDSC、接收 发送、 关键代码。 时钟: void BSP_ClkInit (void) { RCC_ClkInitTypeDef RCC_ClkInit; RCC_OscInitTypeDef RCC_OscInit; RCC_PeriphCLKInitTypeDefPeriphClkInitStruct; PWR->CR3 &= ~PWR_CR3_SCUEN; /* Supplyconfiguration updated locked. */ __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1); /* See Note 2. */ while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)){ ; } /* Enable D2 domainSRAM3 Clock (0x30040000 AXI)*/ __HAL_RCC_D2SRAM3_CLK_ENABLE(); /* Enable D2 domainSRAM2 Clock (0x30020000 AXI)*/ __HAL_RCC_D2SRAM2_CLK_ENABLE(); /* Enable HSE Osc and activate PLL with HSE as source */ RCC_OscInit.OscillatorType =RCC_OSCILLATORTYPE_HSE; /* HSE = 8MHz */ RCC_OscInit.HSEState = RCC_HSE_BYPASS; RCC_OscInit.HSIState = RCC_HSI_OFF; RCC_OscInit.CSIState = RCC_CSI_OFF; RCC_OscInit.PLL.PLLState = RCC_PLL_ON; RCC_OscInit.PLL.PLLSource = RCC_PLLSOURCE_HSE; RCC_OscInit.PLL.PLLM = 4u; /*f(REF_CK) = HSE / PLLM = 2MHz */ RCC_OscInit.PLL.PLLN = 400u; /* f(VCO clock)= f(REF_CK) * PLLN = 800MHz */ RCC_OscInit.PLL.PLLP = 2u; /* PLL(PCLK) = f(VCO clock) / PLLR =400MHz */ RCC_OscInit.PLL.PLLR = 2u; /* PLL(RCLK) = f(VCO clock) / PLLR =400MHz */ RCC_OscInit.PLL.PLLQ = 4u; /* PLL(QCLK) = f(VCO clock) / PLLQ =200MHz */ RCC_OscInit.PLL.PLLVCOSEL = RCC_PLL1VCOWIDE; RCC_OscInit.PLL.PLLRGE =RCC_PLL1VCIRANGE_2; if (HAL_RCC_OscConfig(&RCC_OscInit) != HAL_OK) { while(1u); /* STOP iferror */ } /* ----- CFG SYSCLK SOURCE AND BUS CLOCK DIVIDERS ----- */ RCC_ClkInit.ClockType =(RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_D1PCLK1 | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2 | RCC_CLOCKTYPE_D3PCLK1); RCC_ClkInit.SYSCLKSource =RCC_SYSCLKSOURCE_PLLCLK; /* Select PLL assystem clock source. */ RCC_ClkInit.SYSCLKDivider =RCC_SYSCLK_DIV1; /* SYSCLK = PLL(P CLK) = 400MHz */ RCC_ClkInit.AHBCLKDivider =RCC_HCLK_DIV2; /* HCLK = AHBxCLK = SYSCLK / AHBPRES(2) =200MHz. */ RCC_ClkInit.APB3CLKDivider =RCC_APB3_DIV2; /* APB3CLK =AHB3CLK / APB3DIV(2) =100MHz. */ RCC_ClkInit.APB1CLKDivider =RCC_APB1_DIV2; /* APB1CLK =AHB1CLK / APB1DIV(2) =100MHz. */ RCC_ClkInit.APB2CLKDivider =RCC_APB2_DIV2; /* APB2CLK =AHB2CLK / APB2DIV(2) =100MHz. */ RCC_ClkInit.APB4CLKDivider =RCC_APB4_DIV2; /* APB2CLK =AHB4CLK / APB4DIV(2) =100MHz. */ if (HAL_RCC_ClockConfig(&RCC_ClkInit,FLASH_LATENCY_4) != HAL_OK) { while(1u); /* STOP iferror */ } PeriphClkInitStruct.PeriphClockSelection =RCC_PERIPHCLK_USART3; PeriphClkInitStruct.Usart234578ClockSelection =RCC_USART234578CLKSOURCE_D2PCLK1; if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct)!= HAL_OK) { while(1u); /* STOP iferror */ } __HAL_RCC_CSI_ENABLE(); /* activate CSI clkmondatory for I/O Compensation Cell */ __HAL_RCC_SYSCFG_CLK_ENABLE(); /* Enable SYSCFGclk mondatory for I/O Compensation Cell*/ HAL_EnableCompensationCell(); /* Enables theI/O Compensation Cell */ } MPU: /** * @brief Configure the MPU attributes * @param None * @retval None */ static void MPU_Config(void) { MPU_Region_InitTypeDef MPU_InitStruct; /* Disable the MPU */ HAL_MPU_Disable(); /* Configure the MPU attributes asDevice not cacheable for ETH DMA descriptors */ MPU_InitStruct.Enable =MPU_REGION_ENABLE; //区域使能/禁止 MPU_InitStruct.BaseAddress = 0x30040000; //配置区域基地址 MPU_InitStruct.Size =MPU_REGION_SIZE_256B; //区域容量 MPU_InitStruct.AccessPermission =MPU_REGION_FULL_ACCESS; //设置访问权限 MPU_InitStruct.IsBufferable =MPU_ACCESS_BUFFERABLE; //禁止/允许缓冲 MPU_InitStruct.IsCacheable =MPU_ACCESS_NOT_CACHEABLE; //禁止/允许缓存 MPU_InitStruct.IsShareable =MPU_ACCESS_NOT_SHAREABLE; //禁止/允许共享 MPU_InitStruct.Number = MPU_REGION_NUMBER0; //区域编号 MPU_InitStruct.TypeExtField =MPU_TEX_LEVEL0; //类型扩展级别 MPU_InitStruct.SubRegionDisable = 0x00; //子 region 除能位段设置 MPU_InitStruct.DisableExec =MPU_INSTRUCTION_ACCESS_ENABLE; //允许/禁止取指 HAL_MPU_ConfigRegion(&MPU_InitStruct); /* Configure the MPU attributes asCacheable write through */ MPU_InitStruct.Enable =MPU_REGION_ENABLE; //区域使能/禁止 MPU_InitStruct.BaseAddress = 0x30020000; //配置区域基地址 MPU_InitStruct.Size =MPU_REGION_SIZE_128KB; //区域容量 MPU_InitStruct.AccessPermission =MPU_REGION_FULL_ACCESS; //设置访问权限 MPU_InitStruct.IsBufferable =MPU_ACCESS_NOT_BUFFERABLE; //禁止/允许缓冲 MPU_InitStruct.IsCacheable =MPU_ACCESS_CACHEABLE; //禁止/允许缓存 MPU_InitStruct.IsShareable =MPU_ACCESS_NOT_SHAREABLE; //禁止/允许共享 MPU_InitStruct.Number =MPU_REGION_NUMBER1; //区域编号 MPU_InitStruct.TypeExtField =MPU_TEX_LEVEL0; //类型扩展级别 MPU_InitStruct.SubRegionDisable = 0x00; //子 region 除能位段设置 MPU_InitStruct.DisableExec =MPU_INSTRUCTION_ACCESS_ENABLE; //允许/禁止取指 HAL_MPU_ConfigRegion(&MPU_InitStruct); /* Enable the MPU */ HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT); } ETH DSC #pragma location=0x30040000 ETH_DMADescTypeDef DMARxDscrTab[ETH_RX_DESC_CNT]; /* Ethernet RxDMA Descriptors */ #pragma location=0x30040060 ETH_DMADescTypeDef DMATxDscrTab[ETH_TX_DESC_CNT]; /* Ethernet TxDMA Descriptors */ #pragma location=0x30040200 uint8_tRx_Buff[ETH_RX_DESC_CNT][ETH_RX_BUFFER_SIZE]; /* Ethernet ReceiveBuffers */ RX void EthifTask (void *p_arg) { (void)p_arg; ETH_BufferTypeDef RxBuff; uint32_t framelength = 0; CPU_INT08U err; for (;;) { OSSemPend(RxPktSemaphore, 0, &err); if ((err != OS_NONE_ERR)&& (err != OS_SEM_TIMEOUT)) dtrap(); if (HAL_ETH_GetRxDataBuffer(&EthHandle, &RxBuff) == HAL_OK) { HAL_ETH_GetRxDataLength(&EthHandle, &framelength); /* Invalidate datacache for ETH Rx Buffers */ SCB_InvalidateDCache_by_Addr((uint32_t *)Rx_Buff,(ETH_RX_DESC_CNT * ETH_RX_BUFFER_SIZE)); if (current_pbuf_idx <(ETH_RX_DESC_CNT - 1)) { current_pbuf_idx++; } else { current_pbuf_idx = 0; } } #ifdef ALT_INICHE #ifdef SYSTEM_VIEW SEGGER_SYSVIEW_PrintfHostEx("ETH Rcv RxPkt",SEGGER_SYSVIEW_LOG); #endif input_ippkt(RxBuff.buffer, framelength); #endif /* Build Rxdescriptor to be ready for next data reception */ HAL_ETH_BuildRxDescriptors(&EthHandle); } } TX int8_t ETH_SendTxPkt(uint8_t *buffer, uint32_t len) { int8_t errval = HAL_OK; ETH_BufferTypeDef *Txbuffer = NULL; memset(Txbuffer, 0, sizeof(ETH_BufferTypeDef)); Txbuffer->buffer = buffer; Txbuffer->len = len; Txbuffer->next = NULL; TxConfig.Length = len; TxConfig.TxBuffer = Txbuffer; #ifdef SYSTEM_VIEW SEGGER_SYSVIEW_PrintfHostEx("ETH SendTx Pkt",SEGGER_SYSVIEW_LOG); #endif errval = HAL_ETH_Transmit(&EthHandle, &TxConfig, 0); return errval; } |
ETH RCV.zip
下载199.37 KB, 下载次数: 3, 下载积分: ST金币 -1
system view
