HAL_SPI_TransmitReceive_DMA程序一直复位
yllqabz 提问时间:2019-2-28 11:37 /
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* Configure the system clock */
  SystemClock_Config();
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_ADC1_Init();
  MX_IWDG_Init();
  MX_SPI2_Init();
  MX_TIM1_Init();
  MX_TIM2_Init();
  MX_USART1_UART_Init();
  /* USER CODE BEGIN 2 */
  HAL_IWDG_Start(&hiwdg);
  GpioInit();
  HAL_ADCEx_Calibration_Start(&hadc1);
  HAL_ADC_Start_DMA(&hadc1, (uint32_t*)&ADC_Value, AD_COUNT);
  HAL_ADC_Start(&hadc1);
  HAL_TIMEx_OCN_Start_IT(&htim1, TIM_CHANNEL_3);
  TIM1->CCR3 = 900;
  HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_1);
  HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_2);
  HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_3);
  HAL_SPI_TransmitReceive_DMA(&hspi2, (uint8_t*)&spi_tx_buf, (uint8_t*)&spi_rx_buf, 4);
void MX_SPI2_Init(void)
  hspi2.Instance = SPI2;
  hspi2.Init.Mode = SPI_MODE_MASTER;
  hspi2.Init.Direction = SPI_DIRECTION_2LINES;
  hspi2.Init.DataSize = SPI_DATASIZE_16BIT;
  hspi2.Init.CLKPolarity = SPI_POLARITY_LOW;
  hspi2.Init.CLKPhase = SPI_PHASE_1EDGE;
  hspi2.Init.NSS = SPI_NSS_HARD_OUTPUT;
  hspi2.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_2;
  hspi2.Init.FirstBit = SPI_FIRSTBIT_MSB;
  hspi2.Init.TIMode = SPI_TIMODE_DISABLE;
  hspi2.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
  hspi2.Init.CRCPolynomial = 10;
  if (HAL_SPI_Init(&hspi2) != HAL_OK)
    Error_Handler();
void HAL_SPI_MspDeInit(SPI_HandleTypeDef* spiHandle)
  if(spiHandle->Instance==SPI2)
  /* USER CODE BEGIN SPI2_MspDeInit 0 */
  /* USER CODE END SPI2_MspDeInit 0 */
    /* Peripheral clock disable */
    __HAL_RCC_SPI2_CLK_DISABLE();
    /**SPI2 GPIO Configuration
    PB12     ------> SPI2_NSS
    PB13     ------> SPI2_SCK
    PB14     ------> SPI2_MISO
    PB15     ------> SPI2_MOSI
    HAL_GPIO_DeInit(GPIOB, GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15);
    /* Peripheral DMA DeInit*/
    HAL_DMA_DeInit(spiHandle->hdmarx);
    HAL_DMA_DeInit(spiHandle->hdmatx);
  /* USER CODE BEGIN SPI2_MspDeInit 1 */
  /* USER CODE END SPI2_MspDeInit 1 */
void HAL_SPI_MspInit(SPI_HandleTypeDef* spiHandle)
  GPIO_InitTypeDef GPIO_InitStruct;
  /* USER CODE BEGIN SPI2_MspInit 0 */
  /* USER CODE END SPI2_MspInit 0 */
    /* Peripheral clock enable */
    __HAL_RCC_SPI2_CLK_ENABLE();
    GPIO_InitStruct.Pin = GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_15;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = GPIO_PIN_14;
    GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    hdma_spi2_rx.Instance = DMA1_Channel4;
    hdma_spi2_rx.Init.Direction = DMA_PERIPH_TO_MEMORY;
    hdma_spi2_rx.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_spi2_rx.Init.MemInc = DMA_MINC_ENABLE;
    hdma_spi2_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
    hdma_spi2_rx.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
    hdma_spi2_rx.Init.Mode = DMA_CIRCULAR;
    hdma_spi2_rx.Init.Priority = DMA_PRIORITY_LOW;
    if (HAL_DMA_Init(&hdma_spi2_rx) != HAL_OK)
      Error_Handler();
    __HAL_LINKDMA(spiHandle,hdmarx,hdma_spi2_rx);
hdma_spi2_tx.Instance = DMA1_Channel5;
    hdma_spi2_tx.Init.Direction = DMA_MEMORY_TO_PERIPH;
    hdma_spi2_tx.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_spi2_tx.Init.MemInc = DMA_MINC_ENABLE;
    hdma_spi2_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
    hdma_spi2_tx.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
    hdma_spi2_tx.Init.Mode = DMA_CIRCULAR;
    hdma_spi2_tx.Init.Priority = DMA_PRIORITY_LOW;
    if (HAL_DMA_Init(&hdma_spi2_tx) != HAL_OK)
      Error_Handler();
    __HAL_LINKDMA(spiHandle,hdmatx,hdma_spi2_tx);
  /* USER CODE BEGIN SPI2_MspInit 1 */
  /* USER CODE END SPI2_MspInit 1 */
想实现SPI使用DMA全双工通信,但是一开启HAL_SPI_TransmitReceive_DMA程序就会一直复位,无法正常运行,找了很久原因都没有找到!不知道有人遇到过同样的问题吗?
赞 收藏 评论6 发布时间:2019-2-28 11:37
6个回答
ikxlf 回答时间:2019-2-28 12:13:59
第一,HAL_IWDG_Start(&hiwdg); 你开了看门狗,把狗关掉试试,第二就是开了看门狗你检查是不是程序死机了
STMCU + 2
yllqabz 回答时间:2019-2-28 17:16:22
斯文人 发表于 2019-2-28 12:13
第一,HAL_IWDG_Start(&hiwdg); 你开了看门狗,把狗关掉试试,第二就是开了看门狗你检查是不是程序死机了 ...
我的看门狗应该没有问题的,我只要不添加HAL_SPI_TransmitReceive_DMA这一句,即使开启看门狗程序都能正常运行,像ADC之类都正常。所以我觉得应该不会是看门狗的问题
ikxlf 回答时间:2019-2-28 17:21:38
yllqabz 发表于 2019-2-28 17:16
我的看门狗应该没有问题的,我只要不添加HAL_SPI_TransmitReceive_DMA这一句,即使开启看门狗程序都能正 ...
重启复位:某个地方卡死触发看门狗或者电源不稳
yllqabz 回答时间:2019-2-28 17:36:34
所以我一直觉得是这个SPI的问题
ikxlf 回答时间:2019-2-28 18:07:35
yllqabz 发表于 2019-2-28 17:36
所以我一直觉得是这个SPI的问题
所以我觉得是不是SPI代码的原因导致了你的看门狗被触发了,所以软件不断重启
vanaua 回答时间:2020-5-6 16:21:47
楼主找到原因了吗?请指教一下
