MDK5.27最新版(2019.3.24)分享
yongjun 发布时间:2019-3-25 13:21
最新 MDK5.27版本下载/ R4 [1 Y/ D/ i6 M: O, M7 {
http://armkeil.blob.core.windows.net/eval/MDK527.EXE/ U( H' ~3 E' Q! F& h: U; m
MDK5.27.jpg 1 O7 u0 B, B6 B; A
Microcontroller Development Kit - Version 5.27 release
  • [MDK installation]" F- F% K' t, J0 @4 Y$ m" q
    • With this MDK release the default directory for pack installation has been changed from            C:\Keil_v5\ARM\PACK to %LOCALAPPDATA%\Arm\Packs.
    • The End User License Agreement is now unified across all Arm software development tools and links to product specific license information.
      . x0 j& `% k& X8 W8 O4 O- C+ t' @+ Y
  • [uVision updated to V5.27.1.0]/ s$ X0 C0 z6 x0 L1 \' Q
    • Improved µVision multi-core debugging support          using CMSIS-DAP and ULINK debug adapters. The first connected instance of the debugger is the master; every other instance now displays Client Mode            in the status bar.
    • The System Analyzer shows statistical information            for exceptions and Event Recorder events, for example Keil RTX5 thread switches.
    • The Event Statistics window shows thread execution statistics based on events from the RTOS.
    • µVision breakpoint management was extended            with the action to Kill All Breakpoints in active Project and Kill All Breakpoints in Multi-Project Workspace.
    • Corrected: µVision set incorrect ERRORLEVEL when Flex license checkout fails.
      8 R3 I8 H" u4 y$ c: ^4 N5 f8 w( r
  • [Arm Compiler included]
    % l/ m7 e8 f) C4 R- q2 n/ U
    • Included Arm Compiler 5 version 5.06u6 - same as in MDK version 5.26: see Release Notes for further details.
    • Updated Arm Compiler 6 to version 6.12: see Release Notes for further details.7 F; `- f' ]  X* a* V9 u3 j" ?
  • [Software Packs included]4 `( [3 ~- O4 V  b8 U4 n
    • ARM - CMSIS 5.5.1
      9 O2 [2 ?7 k0 {' G3 w- K
      •             The following folders have been removed:; U+ F6 I- F8 u1 I! n
        • The folder .\CMSIS\Lib\ has been superseded by .\CMSIS\DSP\Lib\.
        • The folder .\CMSIS\DSP_Lib\ has been superseded by .\CMSIS\DSP\.: B, s# ]1 b2 {' I- U: j( a) E6 C
      •             The following folder is deprecated:# @' X* H" u) ?) G! T: f
        • The folder .\CMSIS\Include\ has been superseded by .\CMSIS\DSP\Include\ and .\CMSIS\Core\Include\.
          & Q8 X; i5 S4 c; N, i; C
      • Updated: CMSIS-Core (Cortex-M) to version 5.2.0.
        * c- l8 h) Z2 s4 {( i- `- `$ x
      • Updated: CMSIS-Driver to version 2.4.0.
        " w- D7 d& p+ z& s) p7 X( m" m" C
        • Added components for project specific driver implementations.
        • Added WiFi Driver API version 1.0.0-beta.
          6 Z. Q5 N9 n8 J; H( F3 N
      • Updated: CMSIS-RTOS2 to version 2.1.3./ |* Q; ~2 W2 Y
        • Updated: CMSIS-RTOS RTX V5 to version 5.5.0
          ' Z+ |; q' }, v$ k6 ?$ W
          • Updated and enhanced generated events (reorganized components).
          • Updated configuration (Event Recorder).
          • Updated Component Viewer (improved performance).
            / C) o  Y# O/ S1 M7 ]8 k/ T6 h0 c
      • Updated: CMSIS-DSP to version 1.6.0.% \' k, A9 x" U" L% i* C
        • Reworked DSP library source files and documentation.
        • Updated Arm DSP libraries using Arm Compiler 6.12 for improved performance.
        • Added component variants 'Source' and 'Library'. 'Library' variant is selected by default.
        • Moved DSP libraries from .\CMSIS\Lib\ to .\CMSIS\DSP\Lib\.* x& r" ?, T6 t. ]3 V2 _! M7 V
    • Keil - MDK Middleware 7.8.0
      8 p9 H) G) ~, Y3 Q( t5 t8 X: v
      • Added support for Arm Cortex-M1 based devices.
      • Added Event Recorder configuration in debug configuration.
      • Network Component v7.10.09 [) g% a4 C  F" t+ o
        • Added Virtual LAN (VLAN) support in the Ethernet interface.
        • Added dynamic port range settings in TCP and UDP sockets.
        • Improved Ethernet debugging.
          + y  O0 M, h3 B; c* k9 E6 U% p4 m
      • USB Component 6.13.0  B% M; T+ M& p8 z8 D
        • USB Host
          , F. T3 G( V# ^$ Z& r
          • Added unsupported state for a mounted device in the Component Viewer if no driver is available for this device.
          • Corrected EHCI driver for handling transfers larger than 16kB.
          • Corrected Component Viewer display when ARM Compiler 6 is used.
            2 g: ~3 S7 t; M7 ?1 ^" z! ]3 |: b
        • USB Device' _% g. T0 _5 C: u! [
          • Implement application specific behavior for a CDC ACM class by using the RNDIS protocol.
          • Increased the number of available CDC instances to 8.
            + ~( }& c  p; C* |4 x- W4 L7 g
    • Keil - Arm Compiler Extensions 1.6.1- j) ]- B- e& w. k
      • Improved Event Recorder documentation and examples.
        7 n  x3 P1 n$ _5 Z/ r
  • [Cortex-M Architecture support]
    / j# r- a, Y5 ]! Q8 l
    • Updated Fixed Virtual Platform        (FVP) support to version 11.6.36 adding new models for:9 J3 t! b, B8 r% y' I
      • MPS2_Cortex-M35P
      • MPS2_SecureCore-SC000
      • MPS2_SecureCore-SC3008 A* v% [  @$ G% f3 h
              Note: some models added new parameters or updated parameter names. You may need to update project specific configuration files.        Updated default configuration files are located in C:\Keil_v5\ARM\FVP\MPS2_Cortex-M or C:\Keil_v5\ARM\FVP\MPS2_AEMv8M.
  • [Target debugging]* }0 v( S8 |/ _4 @0 E& ^- b0 B
    • Updated: STMicroelectronics ST-LINK debug driver to version 3.0.6.0.( w1 E4 R# ^8 B; s7 U% f
      • ST-Link now supports Pack settings that access debug definitions provided in Software Packs.
      • NOTE: It might be required to update the ST-Link firmware using ST-LinkUpgrade.exe provided in the folder \Keil_v5\Arm\STLink.$ _- b8 [3 q7 m/ U
    • Updated: Segger J-Link debug driver to version 6.44a.
    • Updated: NULink driver to version 2.06.6875.) h; ]9 `' k* r0 t, }
  • [FlexNet Floating Licenses]
    & o$ D. j6 J' Q8 C# G: K7 o& p
  • [Supported Operating Systems]8 o5 l) Y/ G: Q6 a8 n4 r
9 s) I- ]. n8 d: |; {# m1 B
赞 收藏 评论6 发布时间:2019-3-25 13:21
6个回答
我夏了夏天 回答时间:2019-3-25 13:39:04
希望编辑器能更好用
yklstudent 回答时间:2019-3-25 13:41:14
小白鼠快使用,记得写使用心得
七哥 回答时间:2019-3-25 14:18:02
下次需要重装系统时,考虑用最新版本的。
' X+ G0 c( _" @- i5 ~( \一般对版本不感冒,版本每年都有更新。7 e* T4 J* Z4 m. r" q- [
自从把MDK 4升级到一个能补全函数/变量名的版本之后,对各版本没太关注过。我一个做硬件的,写个固件程序属于不务正业。
edmundlee 回答时间:2019-3-25 14:32:05
用5.26就经常自动退出, 还有经常改了的文文件不让存盘, 怕怕了0 ~7 |" D+ N. P# C  n, r
等一下吧, 等到5.30时, 我才来装5.27
STMCU-管管 回答时间:2019-3-25 15:28:08
谢谢分享
jeffhe1 回答时间:2019-3-25 17:09:15
這有破解版嗎? 使用期限有超過2020的嗎 ?
