NUCLEO-H743ZI cubemx生成lwip以太网工程ping不通
byronsong 提问时间:2019-4-16 17:23 /
同样的配置在STM32F4上用DP83848则没问题。。。
1.修改链接配置文件
/* Highest address of the user mode stack */
_estack = 0x24080000;    /* end of RAM */
/* Generate a link error if heap and stack don't fit into RAM */
_Min_Heap_Size = 0x800;      /* required amount of heap  */
_Min_Stack_Size = 0x400; /* required amount of stack */
/* Initialized data sections goes into RAM, load LMA copy after code */
  .data :
    . = ALIGN(4);
    _sdata = .;        /* create a global symbol at data start */
    *(.data)           /* .data sections */
    *(.data*)          /* .data* sections */
    . = ALIGN(4);
    _edata = .;        /* define a global symbol at data end */
  } >RAM_D1 AT> FLASH
  /* Uninitialized data section */
  . = ALIGN(4);
  .bss :
    /* This is used by the startup in order to initialize the .bss secion */
    _sbss = .;         /* define a global symbol at bss start */
    __bss_start__ = _sbss;
    *(.bss)
    *(.bss*)
    *(COMMON)
    . = ALIGN(4);
    _ebss = .;         /* define a global symbol at bss end */
    __bss_end__ = _ebss;
  } >RAM_D1
  /* User_heap_stack section, used to check that there is enough RAM left */
  ._user_heap_stack :
    . = ALIGN(4);
    PROVIDE ( end = . );
    PROVIDE ( _end = . );
    . = . + _Min_Heap_Size;
    . = . + _Min_Stack_Size;
    . = ALIGN(4);
  } >RAM_D1
  .lwip_sec (NOLOAD) : {
    . = ABSOLUTE(0x30040000);
    *(.RxDecripSection)
    . = ABSOLUTE(0x30040060);
    *(.TxDecripSection)
    . = ABSOLUTE(0x30040200);
    *(.RxArraySection)
  } >RAM_D2 AT> FLASH
2.配置mpu
static void MPU_Config(void)
  MPU_Region_InitTypeDef MPU_InitStruct;
  /* Disable the MPU */
  HAL_MPU_Disable();
  /* Configure the MPU attributes as Device not cacheable
     for ETH DMA descriptors */
  MPU_InitStruct.Enable = MPU_REGION_ENABLE;
  MPU_InitStruct.BaseAddress = 0x30040000;
  MPU_InitStruct.Size = MPU_REGION_SIZE_256B;
  MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
  MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE;
  MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
  MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
  MPU_InitStruct.Number = MPU_REGION_NUMBER0;
  MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
  MPU_InitStruct.SubRegionDisable = 0x00;
  MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
  HAL_MPU_ConfigRegion(&MPU_InitStruct);
  /* Configure the MPU attributes as Cacheable write through
     for LwIP RAM heap which contains the Tx buffers */
  MPU_InitStruct.BaseAddress = 0x30044000;
  MPU_InitStruct.Size = MPU_REGION_SIZE_16KB;
  MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
  MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE;
  MPU_InitStruct.Number = MPU_REGION_NUMBER1;
  /* Enable the MPU */
  HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
int main(void)
  /* USER CODE BEGIN 1 */
        MPU_Config();
  /* USER CODE END 1 */
/* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
          MX_LWIP_Process();
  /* USER CODE END 3 */
cube lwip配置静态IP
cube lwip配置静态IP
NUCLEO-H743ZI_eth.zip
1.67 MB, 下载次数: 67, 下载积分: ST金币 -1
以太网
收藏 评论4 发布时间:2019-4-16 17:23
4个回答
byronsong 回答时间:2019-4-17 10:29:08
cubemx 生成的 h7系的程序,使用非DTCM RAM ,目前得手动配置mpu。
你若安好_清风徐来 回答时间:2019-4-17 18:25:59
我调试了两天,没通,各种各样的错误,让我眼花缭乱啊,你写好了分享分享啊
折翼的信鸽 回答时间:2020-11-26 14:21:11
我还是没有ping通,不知道还有哪块的配置没配,方便说一下么
byronsong 回答时间:2020-11-27 10:40:09
1.配置好MPU
2.注意刷cache
