KEIL 编译问题
zjbwxl-75335 提问时间:2019-12-3 19:35 /
收藏 评论6 发布时间:2019-12-3 19:35
6个回答
wenyangzeng 回答时间:2019-12-3 20:33:42
错误的提示信息要用鼠标拉到信息窗口开头处寻找。
cloudcn 回答时间:2019-12-4 08:33:05
程序代码与编译链接没问题
关键你设置了在编译完成后要执行批处理
看样子好像是参数设置的不对
具体解决要看postbuild.bat里面的内容了
废鱼 回答时间:2019-12-4 08:46:19
bin文件转换命令错了,楼主把你的命令贴出来看一下。
zjbwxl-75335 回答时间:2019-12-4 18:14:27
下面是BAT文件里的东西:
:ost build for SECBOOT_ECCDSA_WITH_AES128_CBC_SHA256
:: arg1 is the build directory
:: arg2 is the elf file path+name
:: arg3 is the bin file path+name
:: arg4 is the version
:: arg5 when present forces "bigelf" generation
@echo off
set "projectdir=%1"
set "execname=%~n3"
set "elf=%2"
set "bin=%3"
set "version=%4"
set "SBSFUBootLoader=%~d0%~p0\\..\\.."
::The default installation path of the Cube Programmer tool is: "C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin"
::If you installed it in another location, please update the %programmertool% variable below accordingly.
set "programmertool="C:\\Program Files\\STMicroelectronics\\STM32Cube\\STM32CubeProgrammer\\bin\\STM32_Programmer_CLI""
set "userAppBinary=%projectdir%\\PostBuild\\"
set "sfu=%userAppBinary%\\%execname%.sfu"
set "sfb=%userAppBinary%\\%execname%.sfb"
set "sign=%userAppBinary%\\%execname%.sign"
set "headerbin=%userAppBinary%\\%execname%sfuh.bin"
set "bigbinary=%userAppBinary%\\SBSFU_%execname%.bin"
set "iv=%SBSFUBootLoader%\\2_Images_SECoreBin\\Binary\\iv.bin"
set "oemkey=%SBSFUBootLoader%\\2_Images_SECoreBin\\Binary\\OEM_KEY_COMPANY1_key_AES_CBC.bin"
set "ecckey=%SBSFUBootLoader%\\2_Images_SECoreBin\\Binary\\ECCKEY.txt"
set "sbsfuelf=%SBSFUBootLoader%\\2_Images_SBSFU\\MDK-ARM\\B-L475E-IOT01_2_Images_SBSFU\\SBSFU.axf"
::comment this line to force python
::python is used if windows executeable not found
pushd %projectdir%\..\..\..\..\..\..\Middlewares\ST\STM32_Secure_Engine\Utilities\KeysAndImages
set basedir=%cd%
popd
goto exe:
goto py:
:exe
::line for window executeable
echo Postbuild with windows executable
set "prepareimage=%basedir%\\win\\prepareimage\\prepareimage.exe"
set "python="
if exist %prepareimage% (
goto postbuild
:py
::line for python
echo Postbuild with python script
set "prepareimage=%basedir%\\prepareimage.py"
set "python=python "
:postbuild
::Make sure we have a Binary sub-folder in UserApp folder
if not exist "%userAppBinary%" (
mkdir "%userAppBinary%"
set "command=%python%%prepareimage% enc -k %oemkey% -i %iv% %bin% %sfu%  > %projectdir%\output.txt 2>&1"
%command%
IF %ERRORLEVEL% NEQ 0 goto :error
set "command=%python%%prepareimage% sha256 %bin% %sign% >> %projectdir%\output.txt 2>&1"
%command%
set "command=%python%%prepareimage% pack -k %ecckey%  -r 4 -v %version% -i %iv% -f %sfu% -t %sign% %sfb% -o 512 >> %projectdir%\output.txt 2>&1"
%command%
set "command=%python%%prepareimage% header -k  %ecckey% -r 4 -v %version%  -i %iv% -f %sfu% -t %sign% -o 512 %headerbin% >> %projectdir%\output.txt 2>&1"
%command%
set "command=%python%%prepareimage% merge -i %headerbin% -s %sbsfuelf% %elf% %bigbinary% >> %projectdir%\output.txt 2>&1"
%command%
IF  "%~5"=="" goto :finish
echo "Generating the global elf file (SBSFU and userApp)"
echo "Generating the global elf file (SBSFU and userApp)" >> %projectdir%\output.txt
set "command=%programmertool% -ms %elf% %headerbin% %sbsfuelf% >> %projectdir%\output.txt 2>&1"
%command%
:finish
::backup and clean up the intermediate file
del %sign%
del %sfu%
del %headerbin%
exit 0
:error
echo "%command% : failed" >> %projectdir%\\output.txt
:: remove the elf to force the regeneration
if exist %elf%(
  del %elf%
echo %command% : failed
pause
exit 1
:nothingtodo
exit 0
zjbwxl-75335 回答时间:2019-12-4 18:17:47
下面的是BAD文件:
@echo off
set "projectdir=%1"
set "execname=%~n3"
set "elf=%2"
set "bin=%3"
set "version=%4"
set basedir=%cd%
popd
goto exe:
goto py:
:exe
set "python="
goto postbuild
:py
::line for python
:postbuild
%command%
%command%
%command%
%command%
%command%
%command%
:finish
del %sign%
del %sfu%
del %headerbin%
exit 0
:error
if exist %elf%(
  del %elf%
pause
exit 1
:nothingtodo
exit 0
zjbwxl-75335 回答时间:2019-12-4 18:59:53
这个是BAT的原始文件。
postbuild.zip
1.38 KB, 下载次数: 0, 下载积分: ST金币 -1
关于意法半导体
创新和工艺
招聘信息
