#include "main.h" #include <stdlib.h> #include <stdio.h> #include <ctype.h> #include <math.h> e* z) H/ w: W3 C# D0 { #include <string.h>8 {0 G$ v3 [6 w t7 K+ b & U* D. o6 G; L# _8 Q; [) Y # `" d' a) |: \" {0 ?* V$ Y7 L5 j ADC_HandleTypeDef hadc1;* D4 s0 Z7 D! O UART_HandleTypeDef huart4; UART_HandleTypeDef huart2; void SystemClock_Config(void);! o- r9 y/ J, d+ k static void MX_GPIO_Init(void);5 t0 b) c/ M' U static void MX_ADC1_Init(void); static void MX_UART4_Init(void);! {7 c& m. g/ Q6 m; f! X1 F uint32_t ADC_Convert(ADC_HandleTypeDef* hadc); int main(void) { uint32_t adresult; uint8_t sendstr[20]; HAL_Init(); SystemClock_Config(); MX_GPIO_Init();9 R- `/ U/ r( O$ ~ MX_ADC1_Init(); MX_UART4_Init(); while (1) { / k' {; L+ t6 a+ ~! k0 a( B. Z adresult=ADC_Convert(&hadc1);- b8 a2 z* U* g# y, e sprintf((uint8_t *)sendstr,"%6d\r\n",adresult);& m( u# H6 ?; W$ Z1 O8 d ?1 j HAL_UART_Transmit(&huart4,sendstr,8,10);( p3 j# a$ D$ Z k9 k7 W" R % J* t3 O7 E$ _0 L# q! T ) r4 m5 G. c2 t9 V0 ~2 p: h }% J( D3 W6 F8 |- v$ e, c% t4 }& E } uint32_t ADC_Convert(ADC_HandleTypeDef* hadc) { uint32_t nCount1,ConVal,ConVal1=0;5 I% W, P7 c4 V) x3 f. } for(nCount1=0;nCount1<64;nCount1++) {- A% A6 y V( B, O . N, U7 M$ Q+ Z$ ?6 o; {7 G. D HAL_ADC_Start(hadc);6 c- i o' W9 U$ J& G* _ HAL_ADC_PollForConversion(hadc,20); ConVal=HAL_ADC_GetValue(hadc);, x; B6 B, A# K //HAL_ADC_Stop(hadc); ConVal1=ConVal+ConVal1; } HAL_ADC_Stop(hadc); ConVal1=ConVal1>>6; return ConVal1; } 7 B* u( _4 s- z- V void SystemClock_Config(void) {8 Q' G+ e: `- Q RCC_OscInitTypeDef RCC_OscInitStruct = {0}; RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};( U; Y! o' l3 o7 @, b( H 1 p1 X$ L% h9 l __HAL_RCC_PWR_CLK_ENABLE();2 @% f3 H$ r% I% R. P8 x( s# p __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3); RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI; RCC_OscInitStruct.HSIState = RCC_HSI_ON;2 G' b* n1 O" l0 q& f RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT; RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;" p n2 G- ^1 w4 _7 h* q# j if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)1 m3 I9 ~) z3 m: M4 V7 x0 i {2 V! i# i7 ?* k) S( k" C0 ?( Z Error_Handler(); } ; O6 \2 P; n7 ^5 O& _* `, X# k RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2; RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI; RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1; RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;3 u8 Z7 v1 z9 P4 `3 ]6 Z" a! ? 3 W8 b) ]; A; |2 j* s d if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)0 Y$ g' A9 _& o { Error_Handler();6 h2 |6 Y; W2 K) P# @" m7 ~8 ? }$ [, s% j) ^8 j$ {1 R, p }8 ~# q& a, ?/ L3 s3 X3 i static void MX_ADC1_Init(void) { ADC_ChannelConfTypeDef sConfig = {0}; hadc1.Instance = ADC1;" w s4 i4 h1 q hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV2; hadc1.Init.Resolution = ADC_RESOLUTION_12B; hadc1.Init.ScanConvMode = DISABLE; //hadc1.Init.ContinuousConvMode = DISABLE;( Y3 B. q7 `# c" u& _7 g+ T hadc1.Init.ContinuousConvMode = ENABLE; hadc1.Init.DiscontinuousConvMode = DISABLE; hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE; hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START; hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT; hadc1.Init.NbrOfConversion = 1; hadc1.Init.DMAContinuousRequests = DISABLE;& [; Z$ d7 L5 B2 Y3 A8 g hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV; if (HAL_ADC_Init(&hadc1) != HAL_OK) { Error_Handler();, |- `- {/ k d8 q }; A5 F' x) Z- }0 ]% g8 ^% Y ( |( E" s2 }% y3 ~/ i sConfig.Channel = ADC_CHANNEL_8;* d" H6 I' W- L- f4 D( t sConfig.Rank = 1;, i3 X& Y7 @# S/ f. {( ]: I2 ] sConfig.SamplingTime = ADC_SAMPLETIME_3CYCLES;' ?& ^: A' `6 Z. w/ V+ Q if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)) o0 ?3 K3 I, ]4 x6 J7 A* [ { Error_Handler(); } ^ X; q- G( T* Z/ K: q: O - X- `; E" _4 G; t2 ` }9 C' M& z* O+ X3 S' {. O( ]8 l; U ! i& p! c* Z; q9 d static void MX_UART4_Init(void) {( B5 j- O# u6 H* k' J( S 2 Q' \. A' C9 K* T9 V huart4.Instance = UART4; huart4.Init.BaudRate = 115200; huart4.Init.WordLength = UART_WORDLENGTH_8B; huart4.Init.StopBits = UART_STOPBITS_1; huart4.Init.Parity = UART_PARITY_NONE; huart4.Init.Mode = UART_MODE_TX_RX;4 t; k- m) }4 M3 |; E huart4.Init.HwFlowCtl = UART_HWCONTROL_NONE; huart4.Init.OverSampling = UART_OVERSAMPLING_16; if (HAL_UART_Init(&huart4) != HAL_OK)) V- C* N, k2 a, p { Error_Handler();7 P! m$ ] `9 u8 [0 { }. n& B0 D' z' T1 ~. m } # W* h# X% k; y8 Q0 H |
