求助一个基于HAL库的PWM+DMA的例程代码,一直弄不出来啊。...
celeron 提问时间:2020-1-4 19:28 /
悬赏1ST金币未解决
我用Cube生成的代码,单纯PWM是可以的。但不知道为什么PWM加上DMA后完全没用,不可控。谁能发个例程给我,或者帮我检查一下我这里例程那里出问题了吗?谢谢了。STM32F030芯片,代码几乎都是用Cube生成的,除了main函数上的几行代码。
  1. int main(void)
  2. {
  3.   /* USER CODE BEGIN 1 */
  4.         uint16_t i;
  5.   /* USER CODE END 1 */
  6.
  7.   /* MCU Configuration--------------------------------------------------------*/
  8.   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  9.   HAL_Init();
  10.   /* USER CODE BEGIN Init */
  11.   /* USER CODE END Init */
  12.   /* Configure the system clock */
  13.   SystemClock_Config();
  14.   /* USER CODE BEGIN SysInit */
  15.   /* USER CODE END SysInit */
  16.   /* Initialize all configured peripherals */
  17.   MX_GPIO_Init();
  18.   MX_TIM3_Init();
  19.   MX_DMA_Init();
  20.   /* USER CODE BEGIN 2 */
  21.         //HAL_TIM_PWM_Start(&htim3, TIM_CHANNEL_3);
  22.
  23.
  24.         for(i = 0; i < SEND_SIZE; i++)
  25.         {
  26.                 pwm_buf[i] = 200;
  27.         }
  28.   /* USER CODE END 2 */
  29.   /* Infinite loop */
  30.   /* USER CODE BEGIN WHILE */
  31.   while (1)
  32.   {
  33.     /* USER CODE END WHILE */
  34.     /* USER CODE BEGIN 3 */
  35.
  36.                 HAL_TIM_PWM_Start_DMA(&htim3, TIM_CHANNEL_3, (uint32_t *)(&(pwm_buf[0])), SEND_SIZE*2);
  37.                 HAL_Delay(200);
  38.   }
  39.   /* USER CODE END 3 */
  40. }
  1. static void MX_TIM3_Init(void)
  2. {
  3.   /* USER CODE BEGIN TIM3_Init 0 */
  4.   /* USER CODE END TIM3_Init 0 */
  5.   TIM_ClockConfigTypeDef sClockSourceConfig = {0};
  6.   TIM_MasterConfigTypeDef sMasterConfig = {0};
  7.   TIM_OC_InitTypeDef sConfigOC = {0};
  8.   /* USER CODE BEGIN TIM3_Init 1 */
  9.   /* USER CODE END TIM3_Init 1 */
  10.   htim3.Instance = TIM3;
  11.   htim3.Init.Prescaler = 0;
  12.   htim3.Init.CounterMode = TIM_COUNTERMODE_UP;
  13.   htim3.Init.Period = 10000;
  14.   htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  15.   htim3.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
  16.   if (HAL_TIM_Base_Init(&htim3) != HAL_OK)
  17.   {
  18.     Error_Handler();
  19.   }
  20.   sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
  21.   if (HAL_TIM_ConfigClockSource(&htim3, &sClockSourceConfig) != HAL_OK)
  22.   {
  23.     Error_Handler();
  24.   }
  25.   if (HAL_TIM_PWM_Init(&htim3) != HAL_OK)
  26.   {
  27.     Error_Handler();
  28.   }
  29.   sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  30.   sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  31.   if (HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig) != HAL_OK)
  32.   {
  33.     Error_Handler();
  34.   }
  35.   sConfigOC.OCMode = TIM_OCMODE_PWM1;
  36.   sConfigOC.Pulse = 2;
  37.   sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
  38.   sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
  39.   if (HAL_TIM_PWM_ConfigChannel(&htim3, &sConfigOC, TIM_CHANNEL_3) != HAL_OK)
  40.   {
  41.     Error_Handler();
  42.   }
  43.   __HAL_TIM_DISABLE_OCxPRELOAD(&htim3, TIM_CHANNEL_3);
  44.   /* USER CODE BEGIN TIM3_Init 2 */
  45.   /* USER CODE END TIM3_Init 2 */
  46.   HAL_TIM_MspPostInit(&htim3);
  47. }
  1. static void MX_DMA_Init(void)
  2. {
  3.   /* DMA controller clock enable */
  4.   __HAL_RCC_DMA1_CLK_ENABLE();
  5.   /* DMA interrupt init */
  6.   /* DMA1_Channel2_3_IRQn interrupt configuration */
  7.   HAL_NVIC_SetPriority(DMA1_Channel2_3_IRQn, 0, 0);
  8.   HAL_NVIC_EnableIRQ(DMA1_Channel2_3_IRQn);
  9. }
  1. void HAL_TIM_Base_MspInit(TIM_HandleTypeDef* htim_base)
  2. {
  3.   if(htim_base->Instance==TIM3)
  4.   {
  5.   /* USER CODE BEGIN TIM3_MspInit 0 */
  6.   /* USER CODE END TIM3_MspInit 0 */
  7.     /* Peripheral clock enable */
  8.     __HAL_RCC_TIM3_CLK_ENABLE();
  9.
  10.     /* TIM3 DMA Init */
  11.     /* TIM3_CH3 Init */
  12.     hdma_tim3_ch3.Instance = DMA1_Channel2;
  13.     hdma_tim3_ch3.Init.Direction = DMA_MEMORY_TO_PERIPH;
  14.     hdma_tim3_ch3.Init.PeriphInc = DMA_PINC_DISABLE;
  15.     hdma_tim3_ch3.Init.MemInc = DMA_MINC_ENABLE;
  16.     hdma_tim3_ch3.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
  17.     hdma_tim3_ch3.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
  18.     hdma_tim3_ch3.Init.Mode = DMA_CIRCULAR;
  19.     hdma_tim3_ch3.Init.Priority = DMA_PRIORITY_VERY_HIGH;
  20.     if (HAL_DMA_Init(&hdma_tim3_ch3) != HAL_OK)
  21.     {
  22.       Error_Handler();
  23.     }
  24.     __HAL_LINKDMA(htim_base,hdma[TIM_DMA_ID_CC3],hdma_tim3_ch3);
  25.   /* USER CODE BEGIN TIM3_MspInit 1 */
  26.   /* USER CODE END TIM3_MspInit 1 */
  27.   }
  28. }
PWM_TEST.zip
3.95 MB, 下载次数: 0, 下载积分: ST金币 -1
MDK工程(没CMSIS)+Cube工程
赞 收藏 评论1 发布时间:2020-1-4 19:28
butterflyspring 回答时间:2020-2-10 12:12:04
建议你检查一下那个DMA使能函数的参数。另外在C:\project_32\STM32Cube_FW_F1_V1.7.0\Projects\STM3210E_EVAL\Examples\TIM\TIM_DMA  有个例程可以参考一下
