void Init_TIM2(void) { unsigned long num ; if ( Voltage_X4K<2376) { num = 20000 ; } else if (Voltage_X4K<2376) { num = 2122; } else { num = 20000-8045*Voltage_X4K/8192; } TIM2_TimeBaseInit(TIM2_PRESCALER_2, num);//3770Hz TIM2_OC1Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE,0, TIM2_OCPOLARITY_HIGH); TIM2_OC1PreloadConfig(ENABLE); TIM2_Cmd(ENABLE); 哪位大侠帮我分析下怎么Voltage_X4K变化时 ,num这个变量不变化啊? |
if(Voltage_X4K<2376)
else
但是我现在改成>19808,结果也是一样的
unsigned long num ;
num = Voltage_X4K;
TIM2_Cmd(ENABLE);
直接改成这样的不行
