keil中的 target IRAM1 和 IRAM 以及 noInit 什么作用
mfc4143 提问时间:2020-1-8 10:31 /
RAMxSpecify the ZI and RW areas, typically located in RAM space.
IRAMxSpecify the ZI and RW areas, typically configured through the startup-code.
defaultThe check box, in front of each entry, enables the area globally for the application. Individual modules may be assigned in the Properties dialog to specific areas.
off-chip/on-chipSpecifies whether this is an internal or external ROM or RAM.
StartSpecifies the starting address of the area in HEX format.
SizeSpecifies how large the area is. Also in HEX format.
NoInitSpecifies areas that should be excluded from zero initialization.
收藏 评论1 发布时间:2020-1-8 10:31
mfc4143 回答时间:2020-1-8 10:32:32
求大佬解释一下,虽然有英文,但是理解的不是很明白
