stm32f103rct6的PB3口关闭JTAG后仍然无法使用
harper2xs 提问时间:2020-1-10 12:27 /
悬赏1ST金币未解决
如题,,,
        EXTI_InitTypeDef EXTI_InitStructure;
         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
        GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
        GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_3;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
          GPIO_EXTILineConfig(GPIO_PortSourceGPIOB,GPIO_PinSource3);
          EXTI_InitStructure.EXTI_Line=EXTI_Line3;
          EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
          EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
          EXTI_InitStructure.EXTI_LineCmd = ENABLE;
          EXTI_Init(&EXTI_InitStructure);
          NVIC_InitStructure.NVIC_IRQChannel = EXTI3_IRQn;
          NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x02;
          NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x01;
同样的代码在其他IO口就可以正常触发中断,板子自己做的,也测到中断信号了,也尝试关闭跟踪了,但是在PB3就是无法触发中断。。。求大佬指点迷津
赞 收藏 评论5 发布时间:2020-1-10 12:27
5个回答
废鱼 回答时间:2020-1-10 14:19:13
楼主试一下是不是可以输出高低状态,如果不行,建议换成GPIO_Remap_SWJ_Disable。
yklstudent 回答时间:2020-1-10 19:51:16
习惯了标准库,用LL库也不错:
void sEXIT_Configuration(void)
        LL_GPIO_InitTypeDef GPIO_InitStructure;
        RCC->APB2ENR |= RCC_APB2ENR_IOPBEN;
        GPIO_InitStructure.Mode = LL_GPIO_MODE_INPUT;
        GPIO_InitStructure.OutputType = LL_GPIO_OUTPUT_PUSHPULL;
        GPIO_InitStructure.Speed = LL_GPIO_SPEED_FREQ_HIGH;
        GPIO_InitStructure.Pull = LL_GPIO_PULL_UP;
    GPIO_InitStructure.Pin = LL_GPIO_PIN_3;
    LL_GPIO_Init(GPIOB, &GPIO_InitStructure);
        RCC->APB2ENR |= RCC_APB2ENR_AFIOEN;
        LL_GPIO_AF_SetEXTISource(LL_GPIO_AF_EXTI_PORTB, LL_GPIO_AF_EXTI_LINE3);
        LL_EXTI_EnableIT_0_31(LL_EXTI_LINE_3);
        LL_EXTI_EnableFallingTrig_0_31(LL_EXTI_LINE_3);
        NVIC_SetPriority(EXTI3_IRQn, 0);
        NVIC_EnableIRQ(EXTI3_IRQn);
void EXTI0_IRQHandler(void)
        if(LL_EXTI_IsActiveFlag_0_31(LL_EXTI_LINE_0) != RESET)
                LL_EXTI_ClearFlag_0_31(LL_EXTI_LINE_0);
void EXTI1_IRQHandler(void)
        if(LL_EXTI_IsActiveFlag_0_31(LL_EXTI_LINE_1) != RESET)
                LL_EXTI_ClearFlag_0_31(LL_EXTI_LINE_1);
void EXTI2_IRQHandler(void)
        if(LL_EXTI_IsActiveFlag_0_31(LL_EXTI_LINE_2) != RESET)
                LL_EXTI_ClearFlag_0_31(LL_EXTI_LINE_2);
void EXTI3_IRQHandler(void)
        if(LL_EXTI_IsActiveFlag_0_31(LL_EXTI_LINE_3) != RESET)
                LL_EXTI_ClearFlag_0_31(LL_EXTI_LINE_3);
void EXTI4_IRQHandler(void)
        if(LL_EXTI_IsActiveFlag_0_31(LL_EXTI_LINE_4) != RESET)
                LL_EXTI_ClearFlag_0_31(LL_EXTI_LINE_4);
harper2xs 回答时间:2020-1-13 09:13:51
安 发表于 2020-1-10 14:19
楼主试一下是不是可以输出高低状态,如果不行,建议换成GPIO_Remap_SWJ_Disable。 ...
这样不也关闭了SWD?
harper2xs 回答时间:2020-1-13 09:14:34
yklstudent-1794 发表于 2020-1-10 19:51
习惯了标准库,用LL库也不错:
请问我的代码有问题吗
废鱼 回答时间:2020-1-13 09:41:20
harper2xs 发表于 2020-1-13 09:13
这样不也关闭了SWD?
从理论上排除一下,看看是不是配置的问题。
