| 我要用USART2_RX(PA3)来接受串口发来的数据,USART2_TX(PA2)发送数据不用。但是我要用TIM2_CH3(同样是PA2)来输出PWM输出比较波形。 在串口初始化函数中USART_InitStructure.USART_Mode = USART_Mode_Rx;我没写USART_Mode_Tx。但是在USART2和PWM初始化完后,PWM的PA2口仍然输出不了指定波形,逻辑分析仪上什么也不输出。 把USART2初始化函数去掉,就可以正常输出。 有什么方法可以不用PA2当作串口发送口,而当作PWM输出口吗? |
修改复用功能为PWM时啥意思,PA2设置成复用推挽?我本来就这么设置的。。
我发现只要开启了USART2的时钟PA2就输出不了,关了就正常输出。所以和初始化顺序也没啥没关系。
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
//GPIO_PinRemapConfig(GPIO_Remap_USART2,ENABLE);
/* Configure USARTy Rx as input floating */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
USART_InitStructure.USART_BaudRate = 9600;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_Init(USART2, &USART_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
/* Enable USARTy Receive and interrupts */
USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
/* Enable the USARTy */
USART_Cmd(USART2, ENABLE);
void PWM_OC_Init()
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
/* TIM3 clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
/* GPIOA and GPIOB clock enable */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2;
/* Time base configuration */
TIM_TimeBaseStructure.TIM_Period = 999;
TIM_TimeBaseStructure.TIM_Prescaler = 71;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
/* PWM1 Mode configuration: Channel */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_Pulse = 100;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OC2Init(TIM2, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Enable);
TIM_OC3Init(TIM2, &TIM_OCInitStructure);
TIM_OC3PreloadConfig(TIM2, TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIM2, ENABLE);
/* TIM2 enable counter */
TIM_Cmd(TIM2, ENABLE);
库函数初始化外设大都考虑的是最常用工作状态,串口多为全双工模式
建议试一下用寄存器初始化USART2为单工方式,另外如楼上所说PWM初始化放在其后,别忘了开启复用时钟
可参考我的帖子: www.stmcu.org.cn/module/forum/thread-618512-1-1.html
我没试过是否能满足你要求。
如果内部TX和RX内部连接的话,应该更不可能空出PA2吧。。。
