( P3 g5 S( a6 `0 i6 c' K% Q. ^下面可能是你不曾用过后十个Linux的命令。相当的有用。
1 z0 t. z7 f; ~* y; _4 \1)pgrep
$ s) Q$ Y/ \6 A# O$ Ppgrep名字前有个p,我们可以猜到这和进程相关,又是grep,当然这是进程相关的grep命令。不过,这个命令主要是用来列举进程ID的。如:
+ n3 g( F! D; l0 a% E. T
' i% |- Z' h- J( t4 O" W- $ pgrep -u hchen4 d* p: O) o: Z. X- i$ I" z& c
- 22441- Q* _: C; G3 g( y! D5 X
- 22444
- N% R' y- v" Y% i* q9 `/ w/ v
复制代码这个命令相当于:
! V6 s/ ?2 H+ e. W0 O/ ?- D- ps -ef | egrep '^hchen' | awk '{print $2}'! _0 h: Q2 K. v' f. Z
! m; H( P) q6 K; G& D2)pstree
+ d4 x+ Z, m- k3 M$ p
# o' s* ]( g" h& E1 n1 u这个命令可以以树形的方式列出进程。如下所示:5 m: C8 l4 o9 m) b. r9 K* X) ]- |, {
- + [+ {% z9 q4 H; o; Z' y3 x
- [hchen@RHELSVR5 ~]$ pstree
, m5 v$ X0 P* f8 @9 x% @ - init-+-acpid- z9 P0 {) I( ^6 |
- |-auditd-+-python
# X# p. m6 \0 z A- q - | `-{auditd}
( G! Q2 I' S( a8 G. f; B! u) B, @; c - |-automount---4*[{automount}]
8 {! a9 V! c( e) w/ [; F. o) U - |-backup.sh---sleep+ l( [: z" _/ a. k, _% T9 c7 {
- |-dbus-daemon
" |, E4 ^2 [0 ? - |-events/0& ? u+ N9 r& P4 R" u# f4 z3 D
- |-events/1
& w" P9 u, ]0 x9 X4 ]$ {3 G8 }1 W - |-hald---hald-runner---hald-addon-acpi
: I& M/ I& p" G% i0 M7 u/ H& a - |-httpd---10*[httpd]
% R! [! D7 b+ Y* E& X" @ - |-irqbalance
" N8 r. `0 I7 q8 ]0 \4 `" Q5 c - |-khelper" z! R0 ^/ W/ z
- |-klogd2 {; H' j ]% l' a$ H Y+ R
- |-ksoftirqd/0
4 V6 d; }0 g: B- C. u - |-ksoftirqd/1
( Q% r0 {) j5 p; X0 ?/ ` - |-kthread-+-aio/0
. r, ^4 T7 b0 F) n, ~2 |. B( | - | |-aio/1
! u5 T. o8 k: y+ O! O - | |-ata/0 c: t0 v! H5 U4 F
- | |-ata/19 B' t. h, G! a- |) S
- | |-ata_aux
) t0 a, H# J' M( O: ] - | |-cqueue/0
- Q* o) ]0 u/ ?1 I! f; W! l - | |-cqueue/1! P$ M0 `+ s- ^2 o
- | |-kacpid
2 ^( L0 ?! Q' S$ ^5 a% R: @, D - | |-kauditd
/ l9 e3 B* q A' _ - | |-kblockd/03 \$ d/ J3 I$ R
- | |-kblockd/1
+ B# p4 f( N2 t - | |-kedac8 F" @4 ]' T! S1 K1 |1 e: G4 ?4 y; J
- | |-khubd
: |- P" E5 l8 l1 Y! c - | |-6*[kjournald]/ ^: Q a) ?3 I0 @- h
- | |-kmirrord
^$ }2 E: A. g6 ^ - | |-kpsmoused+ u& G! S4 J3 o# |
- | |-kseriod
0 c- ^3 y# Y" O( L% T: a - | |-kswapd0& a" r1 L$ m9 Q$ [( `6 v0 Z
- | |-2*[pdflush]
W7 n/ a& N. S - | |-scsi_eh_0, t G) H/ ]! v4 j+ l0 s+ v
- | |-scsi_eh_18 k; _1 R! n- n( A
- | |-xenbus
& ^8 q! N% L. F1 o: g" z+ f - | `-xenwatch( `0 `& i7 Y( K) h7 @& |0 Z: Y2 G* [
- |-migration/0
0 T" n% \ U/ `% P0 T- p% Z, S - |-migration/1
/ L7 ~( N- l1 _( K( @ - |-6*[mingetty]/ m9 {& z1 i$ F7 }0 A( Y6 }
- |-3*[multilog]" S5 V) `# d3 h1 \! ]7 j
- |-mysqld_safe---mysqld---9*[{mysqld}]
4 M/ f9 _# I# p( h* ~4 L - |-smartd
) Z, H! n9 l! P1 P& C; J e3 g - |-sshd---sshd---sshd---bash---pstree
- U5 Q, T3 E$ U* }" C s, q - |-svscanboot---svscan-+-3*[supervise---run]
! `& S0 `: |! t( k4 e/ p, t - | |-supervise---qmail-send-+-qmail-clean
* m9 ~" ^( m! U8 m; R - | | |-qmail-lspawn
$ X5 f# E0 N3 k% _ - | | `-qmail-rspawn
3 `1 V5 {$ q1 g - | `-2*[supervise---tcpserver]
5 L) @5 `! g. D+ n - |-syslogd9 a/ I" j5 P& c' z! c/ ?: B5 c
- |-udevd& O8 I- f% N8 X
- |-watchdog/03 N2 n9 M9 j5 u [5 |& V
- |-watchdog/13 L2 A5 E: e- a* W$ V
- `-xinetd
3 H+ k/ V- U! D/ @- l& v
' r1 c& j$ A# K3)bc
2 ]9 V/ c. i) J- b& n" y! w# R
! s, h' E, ~6 ~- T* y这个命令主要是做一个精度比较高的数学运算的。比如开平方根等。下面是一个我们利用bc命令写的一个脚本(文件名:sqrt)
. _( m7 G: W3 T# ^# C - 9 u) I! m3 B& S% v5 ]
- #!/bin/bash
! A! p) `9 W: {# E) L - 4 Y2 j. u1 w: k: B3 L
- if [ $4 T1 d8 Z7 S3 J& x! e
- then" p) C: w6 l5 x J. ~, s9 e
- echo 'Usage: sqrt number'
|& Y# e7 S( U1 C$ q- T7 s$ U) y - exit 1 G% c0 r& N8 ^4 A c
- else
& Z( a* `9 B. H# P- c F - echo -e "sqrt($1)\nquit\n" | bc -q -i" Y$ Z6 m, @% n; g
- fi
* _( \/ \3 M2 J0 W5 u5 Z l4 z% `
复制代码 * [. s+ P1 N e
于是,我们可以这样使用这个脚本进行平方根运算:/ N% S( ]) u, p, d h% `" P
: o1 T% h$ s) [. P; z. Y- [hchen@RHELSVR5]$ ./sqrt 36
& p& J. x: v8 a" l6 Z4 u% F. ~; Q - 6
2 L. G5 t3 O r( h% ] - [hchen@RHELSVR5]$ ./sqrt 2.0000
! B9 u2 ?$ T# f; d. Z - 1.4142
. m" q6 w7 G& U) l+ P - [hchen@RHELSVR5]$ ./sqrt 10.0000
0 @+ ~- m* z( W$ l( e: J - 3.1622
4 h# L8 `, c# w% n! @6 W* O
复制代码 W! P( j: W& o3 U& e
4)split & h: G( K9 _" M5 c8 W( m
如果你有一个很大的文件,你想把其分割成一些小的文件,那么这个命令就是干这件事的了。
* U; ~4 D( @5 W3 O - : S! b8 p2 Z* A! r
- [hchen@RHELSVR5 applebak]# ls -l largefile.tar.gz/ |9 q$ h- O- S3 m6 s
- -rw-r--r-- 1 hchen hchen 436774774 04-17 02:00 largefile.tar.gz3 N/ a/ c. y" ]) C0 S7 W+ R
- 6 A& p$ z% c" C2 [# X" p. u; {
- [hchen@RHELSVR5 applebak]# split -b 50m largefile.tar.gz LF_
: D0 Q, c" o- U3 A - ! n t9 B1 E% J. l G/ Y( J! g6 t
- [hchen@RHELSVR5]# ls -l LF_*
1 l I: y+ i# M6 |- T - -rw-r--r-- 1 hchen hchen 52428800 05-10 18:34 LF_aa% m1 C2 p% U: M
- -rw-r--r-- 1 hchen hchen 52428800 05-10 18:34 LF_ab
3 Z- o, q: [) X6 j- h8 `6 c" E - -rw-r--r-- 1 hchen hchen 52428800 05-10 18:34 LF_ac* [6 h% y- x0 ~. y
- -rw-r--r-- 1 hchen hchen 52428800 05-10 18:34 LF_ad
1 y! s* V7 s7 ` - -rw-r--r-- 1 hchen hchen 52428800 05-10 18:34 LF_ae
. n- L6 B2 L6 {& P4 v- c) i - -rw-r--r-- 1 hchen hchen 52428800 05-10 18:35 LF_af8 x/ b- |" b7 B: s% N+ n, J
- -rw-r--r-- 1 hchen hchen 52428800 05-10 18:35 LF_ag
0 y; j! @; b' ` - -rw-r--r-- 1 hchen hchen 52428800 05-10 18:35 LF_ah: g; |3 {- }" M
- -rw-r--r-- 1 hchen hchen 17344374 05-10 18:35 LF_ai
5 Q2 ?2 H( X4 \: S9 S! m
复制代码4 m* S( \; B, J& Z" T8 R
文件合并只需要使用简单的合并就行了,如:' M3 {! h% L: }, J c0 o% O
6 Y6 G |# S8 m" i& O7 h- [hchen@RHELSVR5]# cat LF_* >largefile.tar.gz
5 U, p- [! }) F2 B+ v" j
复制代码5)nl
6 p" k+ ^6 z H7 f1 |nl命令其它和cat命令很像,只不过它会打上行号。如下所示:
+ c) |3 S. }+ c# F0 c; g
9 ^4 T7 l2 p- |& l: {) _6 T- [hchen@RHELSVR5 include]# nl stdio.h | head -n 102 J2 R Z' o. F) e8 S3 X0 n. a: P7 E
- 1 /* Define ISO C stdio on top of C++ iostreams.
2 s' D/ C" `- L, t - 2 Copyright (C) 1991,1994-2004,2005,2006 Free Software Foundation, Inc.
# m4 v# X' p/ l - 3 This file is part of the GNU C Library.
; W, X' W' ?7 A* ^/ q - ( Y2 Q, z. W' n9 j: [
- 4 The GNU C Library is free software; you can redistribute it and/or8 u! M; r7 [. H! `' `( B c
- 5 modify it under the terms of the GNU Lesser General Public
! ^- b9 U( n6 w$ L+ i6 u5 J3 s - 6 License as published by the Free Software Foundation; either9 y0 I& U3 f; Y- I
- 7 version 2.1 of the License, or (at your option) any later version.8 p& H; @# q% ?' u8 z: _" Y
- * |* j/ Y: \) a) n& W8 T
- 8 The GNU C Library is distributed in the hope that it will be useful,
. N t0 B! z& n- a* `* J4 m
复制代码6)mkfifo 熟悉Unix的人都应该知道这个是一个创建有名管道的系统调用或命令。平时,我们在命令行上使用竖线“|”把命令串起来是使用无命管道。而我们使用mkfifo则使用的是有名管道。下面是示例: 下面是创建一个有名管道:
4 t& M. \" l8 P7 Z: L - ! h. k% Y, @6 T) ~9 f$ ?- |' [$ C
- [hchen@RHELSVR5 ~]# mkfifo /tmp/hchenpipe2 q+ c) z% {, l: ^/ V) ~* ^/ W
- / L! o# b, \4 | m% F/ l
- [hchen@RHELSVR5 ~]# ls -l /tmp
8 Q: I5 v# g/ I9 ?; h - prw-rw-r-- 1 hchen hchen 0 05-10 18:58 hchenpipe. S& {3 Q8 Z% \0 k0 w
复制代码 ( k o @9 J- u1 T1 a8 b" ?
然后,我们在一个shell中运行如下命令,这个命令不会返回,除非有人从这个有名管道中把信息读走。, l) i! f8 e% z( f( K+ |5 M# X
- 6 _6 c, W4 j8 B9 l: A7 Y& ?
- [hchen@RHELSVR5 ~]# ls -al > /tmp/hchenpipe: J7 [. z% h' k. b8 D% v
复制代码 9 F; K8 X$ O6 c5 b: n
我们在另一个命令窗口中读取这个管道中的信息:(其会导致上一个命令返回). B/ ^& k- z- X+ A* q
j6 ]7 J& G4 Y& n% `' x- [hchen@RHELSVR5 ~]# head /tmp/hchenpipe* a {6 G, a O/ l, ?
- drwx------ 8 hchen hchen 4096 05-10 18:27 .+ Z4 \- u% t% H% w
- drwxr-xr-x 7 root root 4096 03-05 00:06 ..% g' e/ J6 F* c
- drwxr-xr-x 3 hchen hchen 4096 03-01 18:13 backup
; X a8 V8 C' Z - -rw------- 1 hchen hchen 721 05-05 22:12 .bash_history- G2 E& v4 I6 |' S4 |
- -rw-r--r-- 1 hchen hchen 24 02-28 22:20 .bash_logout
$ L1 V- I7 e5 | - -rw-r--r-- 1 hchen hchen 176 02-28 22:20 .bash_profile" k) n7 J S) y w. h+ y
- -rw-r--r-- 1 hchen hchen 124 02-28 22:20 .bashrc
+ |0 G7 b p# y, r0 M* S& [7 x - -rw-r--r-- 1 root root 14002 03-07 00:29 index.htm
- Z; w) t. I( n, v$ s2 R( l5 s - -rw-r--r-- 1 hchen hchen 31465 03-01 23:48 index.php$ K4 \2 z3 E7 Q; L+ w7 y2 X
8 ?6 R; h. i; ~9 w) `1 r7)ldd. o$ g7 R# Z! y1 J! E
9 l0 I' d; Q% R' @
这个命令可以知道你的一个可执行文件所使用了动态链接库。如: - <font color="#001000"><font face="Tahoma">
$ m' O) O5 r6 h% h7 j- M - [hchen@RHELSVR5 ~]# ldd /usr/bin/java( m9 A5 Y4 g3 ]: O
- linux-gate.so.1 => (0x00cd9000)+ }! J; \, F: y1 | J2 G: \
- libgij.so.7rh => /usr/lib/libgij.so.7rh (0x00ed3000)
( {% D$ p/ ?; U e* D - libgcj.so.7rh => /usr/lib/libgcj.so.7rh (0x00ed6000)
$ m4 g+ l2 J3 U* a9 X6 `! d - libpthread.so.0 => /lib/i686/nosegneg/libpthread.so.0 (0x00110000)
/ p% a( L3 ?3 @+ ]/ U3 m0 V0 T0 |2 l - librt.so.1 => /lib/i686/nosegneg/librt.so.1 (0x009c8000)
0 p2 y4 k4 d* M6 [4 n: F - libdl.so.2 => /lib/libdl.so.2 (0x008b5000)- w8 F/ B/ f" { b8 z
- libz.so.1 => /usr/lib/libz.so.1 (0x00bee000)
- Z' ]+ F# ]/ H# I - libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00aa7000)
& w+ T, @) ]3 @3 s: u7 y: _4 R - libc.so.6 => /lib/i686/nosegneg/libc.so.6 (0x0022f000)3 B5 y6 X; _4 M
- libm.so.6 => /lib/i686/nosegneg/libm.so.6 (0x00127000)
8 }+ E. n& \% B# U/ Q - /lib/ld-linux.so.2 (0x00214000)</font></font><font color="#001000"><b>
# @( J4 U! Y. b3 S7 L* j - </b></font>
复制代码8)col
7 D$ Y. `1 F, s S- Z
r+ J5 f6 k" M
这个命令可以让你把man文件转成纯文本文件。如下示例:
* |8 n4 e1 r' j5 |( g2 k- # PAGER=cat0 A# N" L: _- [3 Z, ?* o
- # man less | col -b > less.txt
J6 q. w2 A$ u) |" w! n/ H" w- ]0 A, A$ h
复制代码9)xmlwf- F4 @4 r( N ?9 L/ n% ~6 u9 h
! ?7 ]1 Y6 R" u9 Y' |& c
这个命令可以让你检查一下一个XML文档是否是所有的tag都是正常的。如:& X$ ^/ u' m4 O
5 L3 t( n# {4 J7 p7 d1 b- [hchen@RHELSVR5 ~]# curl 'http://coolshell.cn/?feed=rss2' > cocre.xml
" G1 @" j3 z1 n6 X - % Total % Received % Xferd Average Speed Time Time Time Current7 `; j% X- y9 B# g7 ~
- Dload Upload Total Spent Left Speed z4 y \1 y6 ?# d
- 100 64882 0 64882 0 0 86455 0 --:--:-- --:--:-- --:--:-- 2073k
2 S1 D2 H! Y- X. ~" r$ T$ c3 [: j - [hchen@RHELSVR5 ~]# xmlwf cocre.xml
6 _, u1 E1 \$ _2 t# Q3 K; } - [hchen@RHELSVR5 ~]# perl -i -pe 's@<link>@<br>@g' cocre.xml* T) V; N) } x: v
- [hchen@RHELSVR5 ~]# xmlwf cocre.xml. x. p7 Q$ P8 P% V
- cocre.xml:13:23: mismatched tag
( t4 u2 _1 _) a* d- a
复制代码 7 ~' G6 [% I! t' q
10)lsof3 X& f$ u7 f2 H
4 ^$ x4 r' `* {( {* \; @- I+ x C
可以列出打开了的文件。 - M% E8 T6 L; _( r: B" J
- [root@RHELSVR5 ~]# lsof | grep TCP
+ B. ~- I8 K4 I - httpd 548 apache 4u IPv6 14300967 TCP *:http (LISTEN)
% c! o# r& A' _# T, X8 r0 d, v: y- E - httpd 548 apache 6u IPv6 14300972 TCP *:https (LISTEN), K$ u$ c5 I3 X" k+ _
- httpd 561 apache 4u IPv6 14300967 TCP *:http (LISTEN)
) |9 W9 }0 r7 `+ d2 ^ - httpd 561 apache 6u IPv6 14300972 TCP *:https (LISTEN)
7 S5 c1 D) Q$ x* r2 H - sshd 1764 root 3u IPv6 4993 TCP *:ssh (LISTEN)
$ R* ]7 I* M+ w - tcpserver 8965 root 3u IPv4 153795500 TCP *:pop3 (LISTEN)
: t2 m8 o' s) r! R" A. j - mysqld 10202 mysql 10u IPv4 73819697 TCP *:mysql (LISTEN)
+ {! N2 ?. Z; S2 S - sshd 10735 root 3u IPv6 160731956 TCP 210.51.0.232:ssh->123.117.239.68:31810 (ESTABLISHED)
: G6 ?- p3 b& v: h( J' M - sshd 10767 hchen 3u IPv6 160731956 TCP 210.51.0.232:ssh->123.117.239.68:31810 (ESTABLISHED)
9 n4 |& A; {" f( j - vsftpd 11095 root 3u IPv4 152157957 TCP *:ftp (LISTEN)+ E2 u8 r! O0 y
复制代码% y( e e5 {- g% V o& D+ O; R
; I% m, a, [% c R! F- I |
