stm32g474开发FDCAN通信时,接收数据不能每次都能中断
shouhong829 提问时间:2020-6-28 15:12 /
        滤波器配置
void FDCAN1_Config(uint8_t SelectDevice,uint32_t AcceptCode,uint32_t AcceptMask)
  FDCAN_FilterTypeDef sFilterConfig;
  if(AcceptCode>0x7FF)
                /* Configure Rx filter */
                sFilterConfig.IdType = FDCAN_EXTENDED_ID;
                sFilterConfig.FilterIndex = 0;
                sFilterConfig.FilterType = FDCAN_FILTER_MASK;
                sFilterConfig.FilterConfig = FDCAN_FILTER_TO_RXFIFO0;
                sFilterConfig.FilterID1 = AcceptCode;
                sFilterConfig.FilterID2 = AcceptMask;
                if (HAL_FDCAN_ConfigFilter(&hfdcan1, &sFilterConfig) != HAL_OK)
                        //Error_Handler();
        else
                sFilterConfig.IdType = FDCAN_STANDARD_ID;
                        //Error_Handler();
  /* Configure global filter:
     Filter all remote frames with STD and EXT ID
     Reject non matching frames with STD ID and EXT ID */
  if (HAL_FDCAN_ConfigGlobalFilter(&hfdcan1, FDCAN_REJECT, FDCAN_REJECT, FDCAN_FILTER_REMOTE, FDCAN_FILTER_REMOTE) != HAL_OK)
    //Error_Handler();
  if (HAL_FDCAN_ActivateNotification(&hfdcan1, FDCAN_IT_RX_FIFO0_NEW_MESSAGE, 0) != HAL_OK)
    //Error_Handler();
  if (HAL_FDCAN_ConfigTxDelayCompensation(&hfdcan1, 5, 0) != HAL_OK)
    //Error_Handler();
  if (HAL_FDCAN_EnableTxDelayCompensation(&hfdcan1) != HAL_OK)
    //Error_Handler();
  /* Start the FDCAN module */
  if (HAL_FDCAN_Start(&hfdcan1) != HAL_OK)
    //Error_Handler();
  if(SelectDevice)                //CANFD_BUS
                TxHeader.BitRateSwitch = FDCAN_BRS_ON;
                TxHeader.FDFormat = FDCAN_FD_CAN;
        else        //CAN_BUS
                TxHeader.BitRateSwitch = FDCAN_BRS_OFF;
                TxHeader.FDFormat = FDCAN_CLASSIC_CAN;
  TxHeader.TxEventFifoControl = FDCAN_NO_TX_EVENTS;
  TxHeader.MessageMarker = 0;
//        HAL_NVIC_SetPriority(FDCAN1_IT0_IRQn, 5, 0);
//        HAL_NVIC_EnableIRQ(FDCAN1_IT0_IRQn);
初始化
void MX_FDCAN1_Init(uint8_t CAN_Filter)
  hfdcan1.Instance = FDCAN1;
  hfdcan1.Init.ClockDivider = FDCAN_CLOCK_DIV8;                                        //系统时钟160MHz,FDCAN内核时钟20MHz
  hfdcan1.Init.FrameFormat = FDCAN_FRAME_FD_BRS;
        hfdcan1.Init.Mode = FDCAN_MODE_NORMAL;
  hfdcan1.Init.AutoRetransmission = DISABLE;
  hfdcan1.Init.TransmitPause = DISABLE;
  hfdcan1.Init.ProtocolException = DISABLE;
  hfdcan1.Init.NominalPrescaler = 1;
  hfdcan1.Init.NominalSyncJumpWidth = 8;
  hfdcan1.Init.NominalTimeSeg1 = 0x1F;
  hfdcan1.Init.NominalTimeSeg2 = 8;
  hfdcan1.Init.DataPrescaler = 1;
  hfdcan1.Init.DataSyncJumpWidth = 4;
  hfdcan1.Init.DataTimeSeg1 = 5;
  hfdcan1.Init.DataTimeSeg2 = 4;
        if(CAN_Filter)
                hfdcan1.Init.StdFiltersNbr = 0;//顺序0
                hfdcan1.Init.ExtFiltersNbr = 1;//顺序1
        else
                hfdcan1.Init.StdFiltersNbr = 1;//顺序0
                hfdcan1.Init.ExtFiltersNbr = 0;//顺序1
  hfdcan1.Init.TxFifoQueueMode = FDCAN_TX_FIFO_OPERATION;
  if (HAL_FDCAN_Init(&hfdcan1) != HAL_OK)
    //Error_Handler();
中断处理
void HAL_FDCAN_RxFifo0Callback(FDCAN_HandleTypeDef *hfdcan, uint32_t RxFifo0ITs)
uint16_t numBytes;
uint8_t dataPayload[64] = {0};                          // Used to store the received data
uint8_t i;
        if((RxFifo0ITs & FDCAN_IT_RX_FIFO0_NEW_MESSAGE) != RESET)
//    test ^= 1;
//                CAN1_LED(test);
                /* Retrieve Rx messages from RX FIFO0 */
    if (HAL_FDCAN_GetRxMessage(hfdcan, FDCAN_RX_FIFO0, &RxHeader, dataPayload) != HAL_OK)
                        //Error_Handler();
                if (hfdcan->Instance == FDCAN1)
                        numBytes = RxHeader.DataLength>>16;
                        if (RxHeader.FDFormat)//CANFD_BUS
                                switch(numBytes)
                                                case 1:
                                                case 2:
                                                case 3:
                                                case 4:
                                                case 5:
                                                case 6:
                                                case 7:
                                                case 8:
                                                        memcpy(RxCANFDData, dataPayload, numBytes);
                                                        break;
                                                case 9:
                                                        memcpy(RxCANFDData, dataPayload, 12);
                                                        break;
                                                case 10:
                                                        memcpy(RxCANFDData, dataPayload, 16);
                                                        break;
                                                case 11:
                                                        memcpy(RxCANFDData, dataPayload, 20);
                                                        break;
                                                case 12:
                                                        memcpy(RxCANFDData, dataPayload, 24);
                                                        break;
                                                case 13:
                                                        memcpy(RxCANFDData, dataPayload, 32);
                                                        break;
                                                case 14:
                                                        memcpy(RxCANFDData, dataPayload, 48);
                                                        break;
                                                case 15:
                                                        memcpy(RxCANFDData, dataPayload, 64);
                                                        break;
                                canfd_receive_flag = 1;
                                CANFDLED_Memory = 1;
                        else//CANFD_BUS
                                memcpy(RxCANData, dataPayload, numBytes);
                                can_receive_flag = 1;
                                CANLED_Memory = 1;
                        }        //FDFormat
                        HAL_FDCAN_ActivateNotification(&hfdcan1, FDCAN_IT_RX_FIFO0_NEW_MESSAGE, 0);
                }//FDCAN1
有那位大神知道是什么问题
收藏 评论2 发布时间:2020-6-28 15:12
李康1202 回答时间:2020-6-29 08:38:03
顶一下
butterflyspring 回答时间:2020-7-17 12:24:26
这有个官方例程,照着一步一步跑通先。 一般用户都没有这类的检测工具~~~
STM32Cube_FW_G4_V1.2.0\Projects\STM32G474E-EVAL\Examples\FDCAN\FDCAN_Com_IT
