! Q _; c8 ?' l& ~, T N3 N
1、库函数版
# w) \2 w Z( O X: W! c. a5 u: g9 r B
最常用的版本,使用ST标准外设库6 C# `6 T2 t1 T3 ?
4 P: P3 I. B9 a! y
* b1 T1 p c1 j/ H( p) i [- ) I) G4 f) B+ p
- void Led_Key_Init(void)
+ j* E$ e, ]( v$ @7 R. s - {
$ J t. \1 C; P# ?2 o. x7 f - GPIO_InitTypeDef GPIO_Init_s;: R. z& D2 W1 q% W/ D
/ t6 ]' t9 b+ J* ~5 B - RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE);//使能时钟 ' L% m; a( Z. F* k
- GPIO_Init_s.GPIO_Pin = GPIO_Pin_4;. o4 H: v& L k* P8 l% s: K
- GPIO_Init_s.GPIO_Mode = GPIO_Mode_OUT;. X6 J7 w: d. K2 j+ f0 |
- GPIO_Init_s.GPIO_OType = GPIO_OType_PP;
# g% P+ ]" u, Y' a' G - GPIO_Init_s.GPIO_Speed = GPIO_Speed_50MHz;
4 K* f0 n% h8 j+ ?" O, c S9 Z' Y - GPIO_Init_s.GPIO_PuPd = GPIO_PuPd_UP;
& _4 \+ z) @/ A- R& { - GPIO_Init(GPIOE, &GPIO_Init_s);( a$ Z% @# N# C' u2 Z( a
复制代码 ' p! X2 I# E F; c( S" q
: \' {5 x @# `
9 j0 t$ N& r) ~
; D+ n0 u- C4 X, O7 Y; T2、寄存器版& v. |4 c/ v7 M
寄存器版其实就是把ST标准外设库拷贝出来,可以简化一些操作4 a5 m0 o; b- r- I8 ?2 }8 F
" F4 k/ w: V: A8 b- /********使用寄存器---start********/4 k, U; w7 u9 Z7 T* x3 \! t
- //TP---PA15 O( ]% e5 ~, X# Q1 D2 o3 O
. w( h4 d' L1 Y- #define TP_PORT GPIOA
- C" ] V! V- u1 a: J - #define TP_PIN GPIO_Pin_15
( ?/ N3 w! ^( W: \7 a1 Y
$ `4 ]" I' W5 ~ d8 Q( b; \1 k7 C- #define TP_OUT() TP_PORT->CRH&=0X0FFFFFFF; TP_PORT->CRH|=0X50000000; //!IO输出
- H4 k5 {2 R+ a' Z+ f* A/ [ - #define TP_IN() TP_PORT->CRH&=0X0FFFFFFF; TP_PORT->CRH|=0X40000000; //!IO输入
# f; b: M( {+ H# ]2 ] - #define TP_READ() (((TP_PORT->IDR)>>15)?1:0) //!<IO读入# K3 o. C9 n' w/ k& l3 e
4 V* D$ x0 M& O! E) ~! \9 i- #define TP_SET() TP_PORT->BSRR = TP_PIN;//写1
1 g$ {4 j' ^+ s4 `8 n/ c3 B- m0 I0 v - #define TP_CLR() TP_PORT->BRR = TP_PIN;//写0
1 C- _- _# z3 O3 g - * U1 l% Z; r( G) A
- #define TP_DATA_SET() TP_SET() //IO写17 j% s& Z5 K/ l; n4 B2 |* O/ P. l$ o
- #define TP_DATA_CLR() TP_CLR() //IO写0
7 n2 c2 y. j: F- C* p3 L! } - #define TP_DATA_OUT() TP_OUT() //将IO设为输出1 _ a3 c3 f' d6 {* ~8 M" ]4 Z0 V
- #define TP_DATA_IN() TP_IN() //将IO设为输入
0 U0 W4 G; p9 B3 q ] - #define TP_DATA_READ() TP_READ()//读取IO的电平
! G0 p! P' t4 w0 r% a
' ?+ R) N! p: t- d8 V/ k( i! A- /********使用寄存器---end********/
4 k; H K2 t7 v( w6 g5 J- _
2 f9 c) u) E- A8 @: Y+ Z* Y1 t! P6 M& n% p4 J
4 P: X" k+ k. P$ P+ |$ S3、位段版' L4 ^, a3 D) j0 L$ ^; c
基于位段的,操作方便
p2 l9 m6 L+ K$ Z2 h9 x
( v+ ]6 a( a: E% z- t) Y {4 X: n, n' k+ I
- 0 c5 S0 Q0 H% `+ E! ~0 Q
- /*LED配置---PE4*/% o, D/ M+ i/ t4 L
- #define GPIO_IDR_OFFSET (GPIOE_BASE+0x10 - PERIPH_BASE)+ T! T' U# ?0 r9 y/ i0 o. q6 [3 G
- #define GPIO_ODR_OFFSET (GPIOE_BASE+0x14 - PERIPH_BASE)' f& P% }' N+ }+ }2 f* o! }& k, w; R
& M9 a4 w7 v/ _7 b6 g. J( T7 U- #define GPIO_BitNumber 4
7 c6 z+ @. L5 q - #define GPIO_OUT_BB (PERIPH_BB_BASE + (GPIO_ODR_OFFSET * 32) + (GPIO_BitNumber * 4))
6 Q% |4 M- }! `- V4 w - #define GPIO_OUT_DATA *(__IO uint32_t *)GPIO_OUT_BB' K: R, G+ O! ^. D; b3 v, l9 t) w
; P" k2 P {/ t& ~ ?- #define GPIO_IN_BB (PERIPH_BB_BASE + (GPIO_IDR_OFFSET * 32) + (GPIO_BitNumber * 4)) 0 T) P# e7 y# ^
- #define GPIO_IN_DATA *(__IO uint32_t *)GPIO_IN_BB% H1 `4 o7 \& E$ D; H
/ A* ~$ K- A j- #define GPIO_DIR_REG *(__IO uint32_t *)(GPIOE_BASE+0X00)) n. b( }; }) s+ `6 [
- # Y; v- q8 g$ o- t) A6 I: b7 I6 f9 h- W: [
* V; N2 X$ W- w% G& W8 a0 `! D. k- #define PE4_SET() GPIO_OUT_DATA = 1 //!< IO写1
; J A- S$ Z* w1 P - #define PE4_CLR() GPIO_OUT_DATA = 0 //!< IO写0
5 |, f) p4 ~+ j/ _. R7 r - #define PE4_OUT() GPIO_DIR_REG = (((GPIO_DIR_REG) & 0xFFFFFCFF) | 0x00000100) //!IO输出
' k4 k/ D/ S2 f, V, I+ e - #define PE4_IN() GPIO_DIR_REG = ((GPIO_DIR_REG) & 0xFFFFFCFF) //!IO输入
* T; k4 @8 t4 `$ E, a7 Y) Z - #define PE4_READ() GPIO_IN_DATA //!<IO读入
! j. ^; Q$ C7 h& N- /*GPIO配置---PXX*/
% j5 g k+ A0 u0 h1 }' J7 Q - #define GPIO_SET(GPIOx_BASE,GPIO_BitNumber) *(__IO uint32_t *)((PERIPH_BB_BASE + ((GPIOx_BASE+0x14 - PERIPH_BASE) * 32) + (GPIO_BitNumber * 4))) = 1 //!< IO写1; j8 o: j8 e. W$ ]& i4 X
- #define GPIO_CLR(GPIOx_BASE,GPIO_BitNumber) *(__IO uint32_t *)((PERIPH_BB_BASE + ((GPIOx_BASE+0x14 - PERIPH_BASE) * 32) + (GPIO_BitNumber * 4))) = 0 //!< IO写0# e+ L% {$ W2 ^1 H4 g7 v; I$ L7 M
# x. c7 C8 b% f2 O- #define GPIO_OUT(GPIOx_BASE,GPIO_BitNumber) *(__IO uint32_t *)(GPIOx_BASE+0X00) &= ~(GPIO_MODER_MODER0 << (GPIO_BitNumber * 2));\
, `: X; U; v8 t& v - *(__IO uint32_t *)(GPIOx_BASE+0X00) |= ((GPIO_Mode_OUT) << (GPIO_BitNumber * 2)); //!IO输出
" p2 @: C3 M3 _8 ]
" q7 x# w; T$ l: `. G- #define GPIO_IN(GPIOx_BASE,GPIO_BitNumber) *(__IO uint32_t *)(GPIOx_BASE+0X00) &= ~(GPIO_MODER_MODER0 << (GPIO_BitNumber * 2));\( H8 F5 D; j$ ]$ w; \" }9 Z
- *(__IO uint32_t *)(GPIOx_BASE+0X00) |= ((GPIO_Mode_IN) << (GPIO_BitNumber * 2)); //!IO输入
( s: n- y% w# e -
3 A2 {6 @. j7 ]5 X0 Y( ] - #define GPIO_READ(GPIOx_BASE,GPIO_BitNumber) *(__IO uint32_t *)((PERIPH_BB_BASE + ((GPIOx_BASE+0x10 - PERIPH_BASE) * 32) + (GPIO_BitNumber * 4))) //!<IO读入
复制代码 8 S! e' B% X$ b5 n& x3 [
: \+ j; \$ h( d. D+ p, b6 C, f
& I) U/ X5 x8 w I6 _% d% ^/ [0 B
, B; _6 n5 y* T5 I9 h" T
调用方法GPIOx_BASE:GPIOE_BASE基地址,而不是GPIOEGPIO_BitNumber:4,而不是GPIO_Pin_4
2 \2 Y, w: V- r% N! G1 A# J1 F4 i
; c2 @% M2 D' n$ a( g6 X5 ^. ~
# k; L# M2 K# m0 W' D$ f1 n/ D6 Q7 z' f* g% o8 g9 R
# t* b% {' O; Z0 I t$ y; W } |
