#include "stm32f7xx.h" #include "stm32f7xx_hal.h" #include <stdio.h> #ifdef __GNUC__ /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf set to 'Yes') calls __io_putchar() */ #define PUTCHAR_PROTOTYPE int __io_putchar(int ch) #else #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f) #endif /* __GNUC__ */ static void Error_Handler(void); static void CPU_CACHE_Enable(void); void systemclockinit(int plln,int pllm,int pllp,int pllq); void uartinit(void); static UART_HandleTypeDef UARThandle; int main(void) { /* Enable the CPU Cache */ CPU_CACHE_Enable(); HAL_Init(); systemclockinit(432,25,2,9); uartinit(); printf("hello"); // HAL_icInit(); // printf("my printf test,compile time:%s %s\r\n",__DATE__,__TIME__); printf("hello"); while(1) { /* if(TIM5CH1_Capture_STA&0X40) { temp=TIM5CH1_Capture_STA; temp*=0xFFFFFFFF; temp+=TIM5CH1_Capture_VAL; sprintf(text, "AD value = 0x%04X", temp); } */ } } static void Error_Handler(void) { /* User may add here some code to deal with this error */ while(1) { } } static void CPU_CACHE_Enable(void) { /* Enable I-Cache */ SCB_EnableICache(); /* Enable D-Cache */ SCB_EnableDCache(); } //串口初始化 void uartinit(void) { UARThandle.Instance=USART1; UARThandle.Init.BaudRate=115200; UARThandle.Init.WordLength=UART_WORDLENGTH_8B; UARThandle.Init.StopBits=UART_STOPBITS_1; UARThandle.Init.HwFlowCtl=UART_HWCONTROL_NONE; UARThandle.Init.Parity=UART_PARITY_NONE; UARThandle.Init.Mode=UART_MODE_TX_RX; if (HAL_UART_Init(&UARThandle)!=HAL_OK) { Error_Handler(); } } //串口回调函数 void HAL_UART_MspInit(UART_HandleTypeDef *huart) { GPIO_InitTypeDef GPIO_InitStruct; RCC_PeriphCLKInitTypeDef RCC_PeriphClkInit; /*##-1- Enable peripherals and GPIO Clocks #################################*/ /* Enable GPIO TX/RX clock */ __HAL_RCC_GPIOA_CLK_ENABLE(); /* Select SysClk as source of USART1 clocks */ RCC_PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1; RCC_PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_SYSCLK; HAL_RCCEx_PeriphCLKConfig(&RCC_PeriphClkInit); /* Enable USARTx clock */ __HAL_RCC_USART1_CLK_ENABLE(); /*##-2- Configure peripheral GPIO ##########################################*/ /* UART TX GPIO pin configuration */ GPIO_InitStruct.Pin = GPIO_PIN_9; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_PULLUP; GPIO_InitStruct.Speed = GPIO_SPEED_HIGH; GPIO_InitStruct.Alternate = GPIO_AF7_USART1; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); /* UART RX GPIO pin configuration */ GPIO_InitStruct.Pin = GPIO_PIN_10; GPIO_InitStruct.Alternate = GPIO_AF7_USART1; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); } //printf重定向 PUTCHAR_PROTOTYPE { /* Place your implementation of fputc here */ /* e.g. write a character to the EVAL_COM1 and Loop until the end of transmission */ HAL_UART_Transmit(&UARThandle, (uint8_t *)&ch, 1, 0xFFFF); return ch; } |
硬件连接应该没问题,因为用开发板的附带的例程测试是可以在窜口上显示的
谢谢,搞明白了。原来是工程目标选项配置的c/c++编译中勾选了支持GNU扩展选项(为什么这样并不知道)
