stm32循环读取8个io口状态
qrskf
提问时间:2020-10-3 10:00 /
问答
是否解决:
救助:stm32的8个GPIO端口连接一个8位拨码开关,作为组网从机地址选择,怎么读取拨码开关状态,8个IO口不在一个GPIO组里面,在GPIOA GPIOB两个组里面,有参考案例代码,谢谢!
发布时间:2020-10-3 10:00
9个回答
老牛洋车
回答时间:2020-10-3 10:20:36
a0a.1 32b0c
逐个读取引脚的电平高低,然后组成您需要的数据。
qrskf
回答时间:2020-10-4 21:02:29
a4a.1 32b0c
有没有案例代码,分享一个,谢谢了!
qrskf
回答时间:2020-10-4 21:06:12
a4a.1 32b0c
有没有个案例代码,参考一下,谢谢了!
STM1024
回答时间:2020-10-4 22:10:23
a0a.1 32b0c
那就把GA,GB都读出来,然后提取对应bit位啊,基本的位操作
qrskf
回答时间:2020-10-5 16:54:35
a4a.1 32b0c
好的,谢谢大家
小歆-2051663
回答时间:2020-10-9 12:26:30
a0a.1 32b0c
我一般会定义一个联合体+结构体的变量,例如:
union {
uint8 Byte;
struct {
uint8_t bit0 :1;
uint8_t bit1 :1;
uint8_t bit2 :1;
uint8_t bit3 :1;
uint8_t bit4 :1;
uint8_t bit5 :1;
uint8_t bit6 :1;
uint8_t bit7 :1;
} Bits;
} Address;
读取IO并赋值变量这样写:
Address.Bits.bit0 = HAL_GPIO_ReadPin(GPIO_TypeDef * GPIOx, uint16_t GPIO_Pin);
Address.Bits.bit1 = HAL_GPIO_ReadPin(GPIO_TypeDef * GPIOx, uint16_t GPIO_Pin);
Address.Bits.bit2 = HAL_GPIO_ReadPin(GPIO_TypeDef * GPIOx, uint16_t GPIO_Pin);
Address.Bits.bit3 = HAL_GPIO_ReadPin(GPIO_TypeDef * GPIOx, uint16_t GPIO_Pin);
Address.Bits.bit4 = HAL_GPIO_ReadPin(GPIO_TypeDef * GPIOx, uint16_t GPIO_Pin);
Address.Bits.bit5 = HAL_GPIO_ReadPin(GPIO_TypeDef * GPIOx, uint16_t GPIO_Pin);
Address.Bits.bit6 = HAL_GPIO_ReadPin(GPIO_TypeDef * GPIOx, uint16_t GPIO_Pin);
Address.Bits.bit7 = HAL_GPIO_ReadPin(GPIO_TypeDef * GPIOx, uint16_t GPIO_Pin);
最后使用的时候这样写:
uint8_t tmp = Address.Byte;
butterflyspring
回答时间:2020-10-10 11:35:10
a0a.1 32b0c
读拨码开关一般不追求速度,用什么方法都能读出来。用库函数读就行。大家说的方法都可以实现的
qrskf
回答时间:2020-10-11 17:46:33
a4a.1 32b0c
我是这样写的: u8 addid[8];
addid[0] = GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_11);
addid[1] = GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_10);
addid[2] = GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_2);
addid[3] = GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_1);
addid[4] = GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_0);
addid[5] = GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_7);
addid[6] = GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_6);
addid[7] = GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_5);
qrskf
回答时间:2020-10-11 17:47:10
a1024a.1 32b0c
谢谢大家!!!!!!
读取IO并赋值变量这样写:
最后使用的时候这样写:
