1)pgrep pgrep名字前有个p,我们可以猜到这和进程相关,又是grep,当然这是进程相关的grep命令。不过,这个命令主要是用来列举进程ID的。如: - 9 y, y% _- o8 T! j3 x7 `2 d
- $ pgrep -u hchen9 S* E7 j, ? s Z$ `6 F2 L4 }1 d
- 22441
) S9 w, L0 l/ Y0 R7 h9 Z - 22444
复制代码 * T1 |1 f* [- }" s5 ~$ ^- o6 A
这个命令相当于: - ps -ef | egrep '^hchen' | awk '{print $2}'& `3 x% ]. h* s. U) i- S9 X$ T
2)pstree 这个命令可以以树形的方式列出进程。如下所示:
* _ G$ j0 k9 g: V: N) Z - & ~1 d( {, E" L {
- [hchen@RHELSVR5 ~]$ pstree
& O7 V0 q! u' P1 s2 t- L3 {8 q - init-+-acpid
$ k$ v0 Z- }( _ b3 p) B - |-auditd-+-python" @$ N7 a8 _. m+ r
- | `-{auditd}9 z' @ p. l+ w' Q' q) A
- |-automount---4*[{automount}]3 K, \. G) g( Y' Z& i
- |-backup.sh---sleep% u9 O) [3 F8 P: n, y
- |-dbus-daemon
4 S! l1 Q3 @4 `6 v3 Y - |-events/0 L9 n9 m' @" N
- |-events/1
3 Y& N% w! z& F) f% X - |-hald---hald-runner---hald-addon-acpi% G; A1 q3 Q0 Q
- |-httpd---10*[httpd]
1 O9 M; y+ L! D& W2 C* H$ k: X - |-irqbalance+ p/ O1 C% p- S$ s3 Q
- |-khelper
$ n$ Z3 l) a6 A - |-klogd5 A9 ]1 c P" N% T
- |-ksoftirqd/0
9 P% ]! s0 n- g! l - |-ksoftirqd/1: }! n; M5 z! ]8 }
- |-kthread-+-aio/0
; d! l0 V( s2 V/ l, R7 G! F - | |-aio/12 Z/ H# i/ [+ w# e0 d1 V
- | |-ata/0
2 _+ A2 C% f! A! B Z# m - | |-ata/12 ^* |* n5 b! T5 U! t
- | |-ata_aux* {: o, E# A! e2 a
- | |-cqueue/0
1 z5 m: I/ A; _" O1 |9 X - | |-cqueue/1
) V; _+ V1 X0 W/ |2 ~4 V - | |-kacpid I* {0 ^, T! A" G) n2 R
- | |-kauditd! I) s2 r2 K9 Q5 [2 r) j" Q; z
- | |-kblockd/0" o" o8 b" f B, ~: N& J" w$ }
- | |-kblockd/1: R' _2 e8 p! Y& J
- | |-kedac2 C' g& G% @. f N) j1 q* x
- | |-khubd5 d' a) ]2 k) k% q
- | |-6*[kjournald]' T5 r6 p$ m& ^5 y0 i
- | |-kmirrord/ n4 T& i9 H- o4 Y+ K
- | |-kpsmoused
. o' u/ G E8 I) Q6 `/ u - | |-kseriod% ?+ |( G' U. ?* Q
- | |-kswapd0. K* V' H1 h5 B# L, l
- | |-2*[pdflush]" ]. O2 {2 [, d
- | |-scsi_eh_0 d- u2 J1 Z# [5 ?
- | |-scsi_eh_1
% @, V+ u$ k. g+ ]" H$ b. k - | |-xenbus; z/ x6 b, S% {* W7 k5 z
- | `-xenwatch
7 `5 \: U3 U6 l/ G% S3 J0 I - |-migration/0
1 p6 M8 t! U$ P# I4 x6 X - |-migration/1
. L6 s T" }9 w - |-6*[mingetty]
' H, t+ p& [3 m& p2 Q. ~- Y - |-3*[multilog]
# R! s3 K$ U k6 ]4 i: { - |-mysqld_safe---mysqld---9*[{mysqld}]- G. Y! }( a: k
- |-smartd" s( r0 X, _9 e! x& t: @! d Z
- |-sshd---sshd---sshd---bash---pstree
7 h! r: x( r, {- b" X( Z - |-svscanboot---svscan-+-3*[supervise---run]
. L/ b5 D9 q% C2 v - | |-supervise---qmail-send-+-qmail-clean
' B! F2 r2 s4 Y) q7 A - | | |-qmail-lspawn
8 I& i' n7 l. r4 Z - | | `-qmail-rspawn
, s% D5 ~) m) B$ Q3 Q - | `-2*[supervise---tcpserver]: F+ w8 b/ g& B* Z4 w# v
- |-syslogd
0 g7 C! d3 z3 C6 _" \1 N# P3 b5 O - |-udevd
1 O$ }/ e S, ^ - |-watchdog/0
1 O/ c/ N6 d+ q5 Y - |-watchdog/19 H' v' v# @' o. o
- `-xinetd
& `- ~1 G" q. J! z: ]# a+ k3)bc 这个命令主要是做一个精度比较高的数学运算的。比如开平方根等。下面是一个我们利用bc命令写的一个脚本(文件名:sqrt)# I3 g3 y4 I% U! X
" c" u; N7 f: T+ k, R; [3 N- M# Y# ~- D5 m- #!/bin/bash
' m2 N3 x6 f% u: O0 v
- ~# `+ P) c% h) a, @- if [ $6 _) a+ H6 J, ~! v7 c- N% ]
- then3 M) _0 r. w% x% v+ y) |, o
- echo 'Usage: sqrt number'
+ e3 Z {$ V4 O! o$ p8 N - exit 1
. B, j( D: u- x% Q1 E - else
; q/ h, i, H6 {8 D - echo -e "sqrt($1)\nquit\n" | bc -q -i
9 c0 d. ~( j/ z% |8 V - fi
3 i9 T; H$ L# k# [/ k3 H9 @于是,我们可以这样使用这个脚本进行平方根运算:. h0 ]" P2 E4 w
- / z9 f- e( \0 a b( v$ R$ V
- [hchen@RHELSVR5]$ ./sqrt 36
& Y* \( X9 E/ ]5 m) e - 6" P5 a7 D! i" A Q
- [hchen@RHELSVR5]$ ./sqrt 2.0000
' {# x2 N% f+ y) v" q - 1.4142
; M8 G, ^3 ^6 v' b/ A5 C+ ]/ q3 C/ l - [hchen@RHELSVR5]$ ./sqrt 10.0000% m& ]* a1 [; y' O! G2 U
- 3.1622
复制代码 " r; [4 x4 o/ v8 b4 e9 y2 x
4)split 如果你有一个很大的文件,你想把其分割成一些小的文件,那么这个命令就是干这件事的了。 - % h# {+ V2 W; w
- [hchen@RHELSVR5 applebak]# ls -l largefile.tar.gz" \. J) |" l. _
- -rw-r--r-- 1 hchen hchen 436774774 04-17 02:00 largefile.tar.gz
) R8 y) H# O3 D: l3 L+ v$ Y - - h5 J3 O+ W9 H: K0 @9 Q
- [hchen@RHELSVR5 applebak]# split -b 50m largefile.tar.gz LF_
# Y. B4 M" d0 m% o0 r) |
, Q1 C6 y* e$ T6 S; \- [hchen@RHELSVR5]# ls -l LF_*% D2 x9 a- R: E/ h
- -rw-r--r-- 1 hchen hchen 52428800 05-10 18:34 LF_aa! L( H' {6 P# k# C6 K
- -rw-r--r-- 1 hchen hchen 52428800 05-10 18:34 LF_ab
+ u; l b! {/ p3 C8 h& g& g. t - -rw-r--r-- 1 hchen hchen 52428800 05-10 18:34 LF_ac; j* a- @! E; m
- -rw-r--r-- 1 hchen hchen 52428800 05-10 18:34 LF_ad
6 ~* L# S8 W/ t# e# t# `, C - -rw-r--r-- 1 hchen hchen 52428800 05-10 18:34 LF_ae, W% y1 b) ~+ {& j4 H
- -rw-r--r-- 1 hchen hchen 52428800 05-10 18:35 LF_af
- ]4 t9 v3 c8 y9 T( ?" V% D" N - -rw-r--r-- 1 hchen hchen 52428800 05-10 18:35 LF_ag
2 C. K. m1 l v! l3 j - -rw-r--r-- 1 hchen hchen 52428800 05-10 18:35 LF_ah' C! G6 K, s7 A( Y
- -rw-r--r-- 1 hchen hchen 17344374 05-10 18:35 LF_ai
- Z7 G( S: e, l* d! g文件合并只需要使用简单的合并就行了,如: - [hchen@RHELSVR5]# cat LF_* >largefile.tar.gz
) ?2 F9 U7 @6 W% _
5)nl nl命令其它和cat命令很像,只不过它会打上行号。如下所示:
. i, y% h+ j V. B7 C- [hchen@RHELSVR5 include]# nl stdio.h | head -n 10
( P% z# X9 i+ @* b$ Q# v: X - 1 /* Define ISO C stdio on top of C++ iostreams.
9 l# g4 `" n ?" A+ o1 q5 u( P$ \ - 2 Copyright (C) 1991,1994-2004,2005,2006 Free Software Foundation, Inc.
/ q8 A/ o' a1 I2 D h - 3 This file is part of the GNU C Library.
4 ~+ J& b+ F# Q& `, N/ a1 J8 u - : J5 w s5 Z7 E8 x" K& }" u/ I4 ^
- 4 The GNU C Library is free software; you can redistribute it and/or
: v0 {2 Z+ J8 f# p6 j6 P" K - 5 modify it under the terms of the GNU Lesser General Public( Y- |9 j i2 V1 ^7 S
- 6 License as published by the Free Software Foundation; either
9 O/ V, A3 y* S+ |; R: u- ^ - 7 version 2.1 of the License, or (at your option) any later version.
# I8 I# j9 F `+ W
# Y. z) w) Y8 q7 N, ?0 ~5 B- 8 The GNU C Library is distributed in the hope that it will be useful,
复制代码 2 j% y! i4 a0 I+ @$ ~
6)mkfifo 熟悉Unix的人都应该知道这个是一个创建有名管道的系统调用或命令。平时,我们在命令行上使用竖线“|”把命令串起来是使用无命管道。而我们使用mkfifo则使用的是有名管道。下面是示例: 下面是创建一个有名管道: - ( @; G; X' Y! {, I7 y3 N+ f
- [hchen@RHELSVR5 ~]# mkfifo /tmp/hchenpipe" @; ~* x( o T: s
* p% @7 Y8 H. A% s3 {# o% _- [hchen@RHELSVR5 ~]# ls -l /tmp9 g6 z+ `$ h8 T. f3 S: V u, h" _
- prw-rw-r-- 1 hchen hchen 0 05-10 18:58 hchenpipe
' j! i. g6 m8 n, S( }然后,我们在一个shell中运行如下命令,这个命令不会返回,除非有人从这个有名管道中把信息读走。& S) ^8 `0 w' [" U/ F
- [hchen@RHELSVR5 ~]# ls -al > /tmp/hchenpipe
`9 O7 L0 l1 ~& c9 c2 p, s. x
我们在另一个命令窗口中读取这个管道中的信息:(其会导致上一个命令返回)1 P# c7 o6 V( ]) e
- 1 s( |1 [" S! l* R H
- [hchen@RHELSVR5 ~]# head /tmp/hchenpipe6 H; C2 F5 u3 \. q
- drwx------ 8 hchen hchen 4096 05-10 18:27 .5 {% N& @. w8 G0 D+ z& r
- drwxr-xr-x 7 root root 4096 03-05 00:06 ..6 ?( i3 d3 c; k
- drwxr-xr-x 3 hchen hchen 4096 03-01 18:13 backup
' m7 I8 f9 u( v* l - -rw------- 1 hchen hchen 721 05-05 22:12 .bash_history! \4 J! }4 U4 f9 h. i
- -rw-r--r-- 1 hchen hchen 24 02-28 22:20 .bash_logout
5 u. I4 H1 L, J* ]( r, h - -rw-r--r-- 1 hchen hchen 176 02-28 22:20 .bash_profile- ?9 @/ ^ z' L2 @3 ~) ] f( k
- -rw-r--r-- 1 hchen hchen 124 02-28 22:20 .bashrc! b% o D. e; K4 U8 G1 Y, b
- -rw-r--r-- 1 root root 14002 03-07 00:29 index.htm4 Q( h2 j- ?* I4 Q
- -rw-r--r-- 1 hchen hchen 31465 03-01 23:48 index.php
# k! K! g J6 X1 M! S# D3 k7)ldd 这个命令可以知道你的一个可执行文件所使用了动态链接库。如: - 4 i$ x" w. r% g. Q+ E' k
- [hchen@RHELSVR5 ~]# ldd /usr/bin/java) Y/ G. ?$ x, M7 f
- linux-gate.so.1 => (0x00cd9000)
+ H! R" B. i: E0 ^( |* N - libgij.so.7rh => /usr/lib/libgij.so.7rh (0x00ed3000)" Y! Y2 i1 ?( j7 H7 I( ~
- libgcj.so.7rh => /usr/lib/libgcj.so.7rh (0x00ed6000)
/ o9 E9 F* l( G; ^3 y8 k; Z5 A) F - libpthread.so.0 => /lib/i686/nosegneg/libpthread.so.0 (0x00110000)
1 g1 T0 L6 K0 S" _1 a5 \9 `! N - librt.so.1 => /lib/i686/nosegneg/librt.so.1 (0x009c8000)
+ N1 G' e! G/ j X3 W# _8 h7 ]6 D - libdl.so.2 => /lib/libdl.so.2 (0x008b5000)4 n2 Q, f9 i" O3 {) G% Z. K U' `
- libz.so.1 => /usr/lib/libz.so.1 (0x00bee000)
" M4 ^* S C" r0 R& I4 H6 n - libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00aa7000)2 v) I* x9 E0 y: `! m
- libc.so.6 => /lib/i686/nosegneg/libc.so.6 (0x0022f000)
: d8 L+ K2 B# p+ W$ j- G1 r9 _2 y - libm.so.6 => /lib/i686/nosegneg/libm.so.6 (0x00127000)$ @$ O- e& [+ q6 _
- /lib/ld-linux.so.2 (0x00214000)
复制代码 8 o. i+ T9 |. X7 ^4 e5 a9 h
8)col 这个命令可以让你把man文件转成纯文本文件。如下示例:
3 C( B! ]* K# j' \" C- # PAGER=cat
7 V2 I k# g* b$ e! T - # man less | col -b > less.txt
2 c# D4 a& M4 e1 k( ~9 J# g) }9)xmlwf 这个命令可以让你检查一下一个XML文档是否是所有的tag都是正常的。如:
" X; C( G8 l: ?# {( }, v* M, s- [hchen@RHELSVR5 ~]# curl 'https://coolshell.cn/?feed=rss2' > cocre.xml
# a" ]% g9 J$ p( a) v - % Total % Received % Xferd Average Speed Time Time Time Current# z. C1 a9 j- ?
- Dload Upload Total Spent Left Speed- ^* g G% A+ \* Y- p- }
- 100 64882 0 64882 0 0 86455 0 --:--:-- --:--:-- --:--:-- 2073k
6 k9 W; j6 s3 Q7 f8 S1 f* c4 O - [hchen@RHELSVR5 ~]# xmlwf cocre.xml
, e- A: r: I! \6 L0 a" }$ \' H: ?( C - [hchen@RHELSVR5 ~]# perl -i -pe 's@<link>@<br>@g' cocre.xml
- @* s5 @1 l: `6 N) S) h% _ - [hchen@RHELSVR5 ~]# xmlwf cocre.xml) {7 F4 ^$ q# K: n/ F
- cocre.xml:13:23: mismatched tag
" n/ Q u1 o. q10)lsof 可以列出打开了的文件。
2 s; q1 a, l. t, i/ H8 w- [root@RHELSVR5 ~]# lsof | grep TCP8 i6 N1 H" S5 |. R
- httpd 548 apache 4u IPv6 14300967 TCP *:http (LISTEN)) `& b) f5 F4 J* ?; G/ D; k
- httpd 548 apache 6u IPv6 14300972 TCP *:https (LISTEN)" ^( P* ^0 X; z, A# T
- httpd 561 apache 4u IPv6 14300967 TCP *:http (LISTEN)
/ M. {0 }0 q* V3 ?2 Q7 L% i - httpd 561 apache 6u IPv6 14300972 TCP *:https (LISTEN)
! v: a( [ o' n' W - sshd 1764 root 3u IPv6 4993 TCP *:ssh (LISTEN)4 D' U0 s1 I) r3 {
- tcpserver 8965 root 3u IPv4 153795500 TCP *:pop3 (LISTEN)
1 Y# r) i: y- p. Z }, y7 S - mysqld 10202 mysql 10u IPv4 73819697 TCP *:mysql (LISTEN)
% L0 b+ U5 y9 g; v! y9 N - sshd 10735 root 3u IPv6 160731956 TCP 210.51.0.232:ssh->123.117.239.68:31810 (ESTABLISHED)1 o- B- j D* h
- sshd 10767 hchen 3u IPv6 160731956 TCP 210.51.0.232:ssh->123.117.239.68:31810 (ESTABLISHED)4 m- f% E5 t9 o2 D
- vsftpd 11095 root 3u IPv4 152157957 TCP *:ftp (LISTEN)
; V% L0 Z) M- k* `, y |
