103的ADC配置,请大家帮我看看问题在哪里
scfor123456 提问时间:2020-12-30 11:17 /
需求是这样的:adc0~3通道由TIM1_TRGO触发 注入采样,adc4通道由SWSTART触发 规则采样,注入采样4路AD完成后进入ADC中断,规则采样在需要的时候开启并读取。
void adc_init(void)
   ADC_InitTypeDef ADC_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);
    RCC_ADCCLKConfig(RCC_PCLK2_Div6);//60M/6 = 10M
    ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
    ADC_InitStructure.ADC_ScanConvMode = ENABLE;
    ADC_InitStructure.ADC_ContinuousConvMode = DISABLE; //非连续转换
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//SWSTART
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_InitStructure.ADC_NbrOfChannel = 1;
    ADC_Init(ADC1, &ADC_InitStructure);
    ADC_RegularChannelConfig(ADC1,ADC_Channel_4,1,ADC_SampleTime_7Cycles5);//通道一转换结果
        /* Set injected sequencer length */
        ADC_InjectedSequencerLengthConfig(ADC1, 4);
        /* ADC1 injected channel Configuration */
        ADC_InjectedChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_7Cycles5);
        ADC_InjectedChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_7Cycles5);
        ADC_InjectedChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_7Cycles5);
        ADC_InjectedChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_7Cycles5);
        /* ADC1 injected external trigger configuration */
        ADC_ExternalTrigInjectedConvConfig(ADC1, ADC_ExternalTrigInjecConv_T1_TRGO);
        /* DISable automatic injected conversion start after regular one */
        ADC_AutoInjectedConvCmd(ADC1, DISABLE);
        /* Enable ADC1 external trigger */
        ADC_ExternalTrigConvCmd(ADC1, ENABLE);
        ADC_ExternalTrigInjectedConvCmd(ADC1, ENABLE);
        ADC1->CR1 |= 0x80;                //Interrupt enable for injected channels
    ADC_Cmd(ADC1, ENABLE);
    ADC_ResetCalibration(ADC1);
    while(ADC_GetResetCalibrationStatus(ADC1));
    ADC_StartCalibration(ADC1);
    while(ADC_GetCalibrationStatus(ADC1));
赞 收藏 评论4 发布时间:2020-12-30 11:17
4个回答
scfor123456 回答时间:2020-12-31 11:04:02
没人?
scfor123456 回答时间:2021-1-12 12:03:17
butterflyspring 回答时间:2021-1-14 17:21:57
看起来缺少注入ADC的启动函数 ,试试看
void ADC_SoftwareStartInjectedConvCmd(ADC_TypeDef* ADCx, FunctionalState NewState)
scfor123456 回答时间:2021-1-16 18:52:18
void ADC_SoftwareStartInjectedConvCmd(ADC_TypeDef* ADCx, Func ...
好的,感谢
