STM32F4 按键控制小灯亮灭例程
STMCU小助手 发布时间:2020-12-31 09:27
STM32F4 按键控制小灯亮灭例程
通过一个外接按键,来控制 LED 灯的亮灭。程序需要创建 led.h、led.c、key.h、key.c 文件。需要修改 main.c 文件。外接按键模块的 out 端口接单片机的 F0 端口。
LED 小灯程序
led.h
  1. # ifndef __LED_H
    ! H0 x9 r$ ^# X6 E! \
  2. # define __LED_H' B8 K! |% u8 ~( s  a9 X
  3. void LED_Init(void);0 ?' O) l' w) ^% D
  4. # endif<span style="background-color: rgb(255, 255, 255);"> </span>
4 Z( f! S7 q6 V% n+ z  t
led.c
  1. # include <led.h>
    6 V6 h, I: o, [* b  [* Y9 g9 v  f3 K/ L
  2. # include <stm32f4xx.h>3 m5 m1 q) r8 K0 t$ t* l% x
  3. void LED_Init(void) {
    % l5 F. N0 o/ |3 k& I! @1 D8 O
  4.     GPIO_InitTypeDef GPIO_InitStructure;1 ]( H1 K0 \6 j
  5.     RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOF, ENABLE); 3 C) Y' U! O. ]4 A
  6.     // F8
    * r4 a& w$ |8 I* E  _# C
  7.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
    3 R! i' v1 D" R
  8.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;, Y% Y6 o) j6 y' T6 V
  9.     GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    * @! z, I' {6 F% p! U+ _7 \
  10.     GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; // 上拉
    ' k5 @* `1 C+ S# g2 G9 u0 W5 g8 h
  11.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;# a5 }/ H! C/ W$ d
  12.     GPIO_Init(GPIOF, &GPIO_InitStructure);
    / F" \9 J- W3 e
  13.     GPIO_SetBits(GPIOF, GPIO_Pin_8);
    ' @3 ~8 B: \1 ^" H. ~6 G& y' d* H3 A
  14. }
7 c  H. d# W, x$ N6 P2 G$ }
KEY 按键程序
按键程序采用上拉输入
key.h
  1. # ifndef KEY_H% @. B2 a1 i) f, h
  2. # define KEY_H$ ^0 N# Q+ l5 A  T2 @4 |: b  J
  3. # include <sys.h>
    9 }9 [" \& e% Z
  4. # include <stm32f4xx.h>6 M& ]0 I' }$ V* ]% n
  5. #define KEY_ON 1 // 按键初始化程序设置为上拉,所以要达到按键按下小灯亮/ P$ A2 c* n; [& o
  6. #define KEY_OFF 0 // 的功能需要设置 KEY_ON 为高电平,KEY_OFF 为低电平
    ; t- |3 E: t5 \0 q& `2 R6 y, u0 w
  7. 7 T! T! G! q0 z3 i) l: Q
  8. void key_Init(void);
    , g0 \% c( |" o; B' S% Z
  9. 9 V! Z) n! R" b$ s
  10. u8 Key_Scan(GPIO_TypeDef * GPIOx, u16 GPIO_Pin);
    3 l! Q& r3 U  P% y2 g. M5 t8 e
  11. 2 L, Z: F! d; s" U8 m
  12. # endif
/ s3 i0 m9 N7 B  I/ T& \3 j& E
key.c
  1. # include <key.h>5 ]4 d! ?& n. d) R
    ) d& J0 L' M$ y
  3. # include <delay.h>
    $ S) U' ?" G! a  j5 \
  4. // 按键初始化- Z) U5 O5 h1 i2 r
  5. void key_Init(void) {0 o; q( |% p7 W, p! R4 k# U9 G/ I
  6.     GPIO_InitTypeDef GPIO_InitStructure;/ n, A) e  Y2 g% Y
  7.     RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOF, ENABLE); // 打开 PA 口时钟 ! Z) d0 h' v; o
  8.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
    1 r6 w! G7 ]! `. C! ~4 _
  9.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;# t/ H2 n/ Y0 m( L
  10.     GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    % v3 M7 L3 K+ X8 n# N- e* S! L
  11.     GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; // 上拉. h# Z" S+ @; b3 C4 f7 n7 i
  12.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
      T% q7 T* O8 {* u! Y( T
  13.     GPIO_Init(GPIOF, &GPIO_InitStructure);! k7 L/ [0 u! T1 b; b4 s
  14.     GPIO_SetBits(GPIOF, GPIO_Pin_0);' v" H5 r/ }8 Y
  15. }
    * t- }" B" r; X% a" p
  16. // 判断按键是否按下3 K# l$ A2 e( ?* H# B1 i: q. M: @
  17. u8 Key_Scan(GPIO_TypeDef * GPIOx, u16 GPIO_Pin) {4 M+ B4 u' v/ l3 |  r$ o5 {
  18.     if(GPIO_ReadInputDataBit(GPIOx, GPIO_Pin) == KEY_ON) {
    0 L6 b& X5 w) W! G/ K" N: ]
  19.         delay_ms(50); // 战略性消抖,根据实际情况加减延迟时长
    9 v4 p/ v- Y2 @9 {5 h; J6 J* v! e9 ^
  20.         if(GPIO_ReadInputDataBit(GPIOx, GPIO_Pin) == KEY_ON) {
    : h$ I8 T' \; I" Z6 u1 }
  21.             return KEY_ON;0 `$ Z+ h3 T3 r
  22.         }
    $ W1 M- \. `# r
  23.         else, d& U! {3 f- J& K7 v2 x/ b9 R
  24.             return KEY_OFF;. S4 E# c0 m. l1 |
  25.     }
    . V5 w7 j4 v' X; m
  26.     else( S* }9 S8 L8 C4 c# t
  27.         return KEY_OFF;
    - S" X5 W, }) x$ S" f! s8 m: J: s
  28. }
/ e* i# W2 T  @4 E- i
主程序 main.c
  1. # include <stm32f4xx.h>6 n+ F; k3 J( C/ y# \8 ~
  2. # include <led.h>- ^0 l4 g0 r0 ]# r# l- s( U: X- r0 u
  3. # include <key.h>1 _( {; H4 {" G: T7 P0 q
  4. # include <delay.h>
    % _4 ?6 ~7 Y! Y( ^/ [9 ?
  5. int main() {8 b4 ?7 A$ r  N# x' m8 {3 E
  6.     delay_init(168);
    # H" b$ t& t. p  A* z: B- |
  7.     LED_Init(); // LED 初始化, _* {/ I( u; U4 l2 \$ c
  8.     key_Init(); // 按键初始化$ [+ a& @8 r2 L, S, C, p
  9.     2 ]( d2 R) L9 m* Z2 H
  10.     while(1) {1 }) @2 E& A* Q: M% j8 N
  11.         if(Key_Scan(GPIOF, GPIO_Pin_0) == KEY_ON) {
    " c( l4 y$ Y% A
  12.             GPIO_SetBits(GPIOF, GPIO_Pin_8);
    " p5 U& j8 |  q: m
  13.         }
    $ C- }& {: `+ s2 I3 i! L
  14.         if(Key_Scan(GPIOF, GPIO_Pin_0) == KEY_OFF) { ) E# Y2 s- |# I) }) f& P
  15.             GPIO_ResetBits(GPIOF, GPIO_Pin_8);/ b& I9 ?3 D* H; C3 Y2 M
  16.         }
    % {9 l6 K2 o0 i* S$ _, }
  17.     }
    ' \1 v* Z% u* l
  18. }
- g4 I+ \3 a1 ?, i2 m, Y6 Q( {4 ]
现象
按键按下后,LED0 小灯亮;松开按键,小灯灭。
文章出处: ZZZX 是你鸭鸭
6 y1 o4 r: T, o8 l
赞 收藏 评论1 发布时间:2020-12-31 09:27
radio2radio 回答时间:2020-12-31 13:31:56
为什么不用HAL库, 这很重要。
