我用STM32F030C8T6我用定时器延时,SYSTICK想给别的用比如OS,反正留用。
我在初使化的时候我已经把APB时钟2分频别的地方要用。
- if (HSEStatus == (uint32_t)0x01)
- /* Enable Prefetch Buffer and set Flash Latency */
- FLASH->ACR = FLASH_ACR_PRFTBE | FLASH_ACR_LATENCY;
- /* HCLK = SYSCLK */
- RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
- /* PCLK = HCLK */
- RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV2; // //24MHZ
- /* PLL configuration = HSE * 6 = 48 MHz */
- RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
- RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL6);
- /* Enable PLL */
- RCC->CR |= RCC_CR_PLLON;
我的延时程序如下:
- void TIM_Config(void)
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- /* TIM3 clock enable */
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
- /* Compute the prescaler value */
- PrescalerValue = (uint16_t) (SystemCoreClock / 1000000) - 1;
- /* Time base configuration */
- TIM_TimeBaseStructure.TIM_Period = 1; //1 u second
- TIM_TimeBaseStructure.TIM_Prescaler = 23;//PrescalerValue;
- TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Down;
- TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
- TIM_Cmd(TIM3, DISABLE);
- void TimeDelay1us(uint16_t Times)
- TIM3->CR1 |= TIM_CR1_CEN; //启动定时器
- while(Times--)
- while((TIM3->SR & TIM_FLAG_Update) == RESET);
- TIM3->SR &= ~TIM_FLAG_Update;
- TIM3->CR1 &= ~TIM_CR1_CEN; //关闭定时器
- void Delay(uint16_t Times1)
- uint16_t dd,count;
- for(count=0;count<Times1;count++)
- for(dd=1;dd<1000;dd++)
- TimeDelay1us(1);
- void delay_us(uint16_t Times2)
- uint16_t count;
- for(count=0;count<Times2;count++)
- TimeDelay1us(1);
- void delay_ms(uint16_t Times3)
- uint16_t count;
- for(count=0;count<Times3;count++)
- Delay(1);
复制代码 我运行了一下,怎么将4秒,而我定时是1秒。而且好像我改变参数时间并不变求解。
谢谢回答
