关于使用GCC编译STM32F1,makefile中引用.a库报错的问题
Ellsion_ST 提问时间:2021-5-13 11:04 / 未解决
使用STcube生成了一个基于GCC便于的工程且编译完成。
现在想加入自己的.a库文件,进行如下操作:
1)在main函数中加入.a库中的头文件;
2)引用.a库中的函数;
3)在makefile中加入.a库链接 LIBS +=Inc/Test.a (我的Test.a放在工程的Inc文件夹下)。
编译报错,找不到.a库中对应的函数。
现在怀疑是makefile中.a库的引用方式不对,有使用过的伙伴能帮忙看看吗?
收藏 评论4 发布时间:2021-5-13 11:04
4个回答
Ellsion_ST 回答时间:2021-5-13 11:07:08
# File automatically-generated by tool: [projectgenerator] version: [3.7.1] date: [Tue May 11 13:28:15 CST 2021]
# Generic Makefile (based on gcc)
# ChangeLog :
#        2017-02-10 - Several enhancements + project update mode
#   2015-07-22 - first version
# target
TARGET = F103
# building variables
# debug build?
DEBUG = 1
# optimization
OPT = -Og
# paths
# Build path
BUILD_DIR = build
# source
# C sources
C_SOURCES =  \
Src/main.c \
Src/stm32f1xx_it.c \
Src/stm32f1xx_hal_msp.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_gpio_ex.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_tim.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_tim_ex.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_uart.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_rcc.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_rcc_ex.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_gpio.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_dma.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_cortex.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_pwr.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_flash.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_flash_ex.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_exti.c \
Src/system_stm32f1xx.c
# ASM sources
ASM_SOURCES =  \
startup_stm32f103xb.s
# binaries
PREFIX = arm-none-eabi-
# The gcc compiler bin path can be either defined in make command via GCC_PATH variable (> make GCC_PATH=xxx)
# either it can be added to the PATH environment variable.
ifdef GCC_PATH
CC = $(GCC_PATH)/$(PREFIX)gcc
AS = $(GCC_PATH)/$(PREFIX)gcc -x assembler-with-cpp
CP = $(GCC_PATH)/$(PREFIX)objcopy
SZ = $(GCC_PATH)/$(PREFIX)size
else
CC = $(PREFIX)gcc
AS = $(PREFIX)gcc -x assembler-with-cpp
CP = $(PREFIX)objcopy
SZ = $(PREFIX)size
endif
HEX = $(CP) -O ihex
BIN = $(CP) -O binary -S
# CFLAGS
# cpu
CPU = -mcpu=cortex-m3
# fpu
# NONE for Cortex-M0/M0+/M3
# float-abi
# mcu
MCU = $(CPU) -mthumb $(FPU) $(FLOAT-ABI)
# macros for gcc
# AS defines
AS_DEFS =
# C defines
C_DEFS =  \
-DUSE_HAL_DRIVER \
-DSTM32F103xB
# AS includes
AS_INCLUDES =
# C includes
C_INCLUDES =  \
-IInc \
-IDrivers/STM32F1xx_HAL_Driver/Inc \
-IDrivers/STM32F1xx_HAL_Driver/Inc/Legacy \
-IDrivers/CMSIS/Device/ST/STM32F1xx/Include \
-IDrivers/CMSIS/Include \
# compile gcc flags
ASFLAGS = $(MCU) $(AS_DEFS) $(AS_INCLUDES) $(OPT) -Wall -fdata-sections -ffunction-sections
CFLAGS = $(MCU) $(C_DEFS) $(C_INCLUDES) $(OPT) -Wall -fdata-sections -ffunction-sections
ifeq ($(DEBUG), 1)
CFLAGS += -g -gdwarf-2
endif
# Generate dependency information
CFLAGS += -MMD -MP -MF"$(@:%.o=%.d)"
# LDFLAGS
# link script
LDSCRIPT = STM32F103R8Tx_FLASH.ld
# libraries
LIBS = -lc -lm -lnosys
LIBS +=Inc/Test.a
#LIBS +=$(shell find ./ -name '*.a')
LIBDIR =
LDFLAGS = $(MCU) -specs=nano.specs -T$(LDSCRIPT) $(LIBDIR) $(LIBS) -Wl,-Map=$(BUILD_DIR)/$(TARGET).map,--cref -Wl,--gc-sections
# default action: build all
all: $(BUILD_DIR)/$(TARGET).elf $(BUILD_DIR)/$(TARGET).hex $(BUILD_DIR)/$(TARGET).bin
# build the application
# list of objects
OBJECTS = $(addprefix $(BUILD_DIR)/,$(notdir $(C_SOURCES:.c=.o)))
vpath %.c $(sort $(dir $(C_SOURCES)))
# list of ASM program objects
OBJECTS += $(addprefix $(BUILD_DIR)/,$(notdir $(ASM_SOURCES:.s=.o)))
vpath %.s $(sort $(dir $(ASM_SOURCES)))
$(BUILD_DIR)/%.o: %.c Makefile | $(BUILD_DIR)
        $(CC) -c $(CFLAGS) -Wa,-a,-ad,-alms=$(BUILD_DIR)/$(notdir $(<:.c=.lst)) $< -o $@
$(BUILD_DIR)/%.o: %.s Makefile | $(BUILD_DIR)
        $(AS) -c $(CFLAGS) $< -o $@
$(BUILD_DIR)/$(TARGET).elf: $(OBJECTS) Makefile
        $(CC) $(OBJECTS) $(LDFLAGS) -o $@
        $(SZ) $@
$(BUILD_DIR)/%.hex: $(BUILD_DIR)/%.elf | $(BUILD_DIR)
        $(HEX) $< $@
$(BUILD_DIR)/%.bin: $(BUILD_DIR)/%.elf | $(BUILD_DIR)
        $(BIN) $< $@
$(BUILD_DIR):
        mkdir $@
# clean up
clean:
        del *.d /s
        del *.o /s
        del *.lst/s
# dependencies
-include $(wildcard $(BUILD_DIR)/*.d)
# *** EOF ***
Dandjinh 回答时间:2021-5-14 09:07:00
  1. # libraries
  2. LIBS = -lc -lm -lnosys
  3. LIBS += -l:Test.a
  4. #LIBS +=$(shell find ./ -name '*.a')
  5. LIBDIR = -LInc
  6. LDFLAGS = $(MCU) -specs=nano.specs -T$(LDSCRIPT) $(LIBDIR) $(LIBS) -Wl,-Map=$(BUILD_DIR)/$(TARGET).map,--cref -Wl,--gc-sections
Ellsion_ST 回答时间:2021-5-14 16:17:37
已解决,不是makefile的问题,是静态库生成的不对,需要指定内核信息
xmshao 回答时间:2021-5-17 10:41:13
谢谢 进一步的反馈!
