如何在STM32上实现SPI通信连续传送24位数据
STMCU-管管 发布时间:2021-5-28 14:38
一、前言
+ Q6 Q$ _: n: I$ f最近因为需要读取传感器数据,需要单片机发送命令,传感器返回24位数据,因为使用SPI传输数据,虽然命令只有8位,但是必须发送24位数据才能获得传感器的24位数据。自己在这里困了很久,所以写这篇文章记录一下,也给后面需要的朋友一点帮助。9 d9 x/ R& o; p' l
我的目的就是消除或者减小每帧数据之间的发送间隔。# I+ c7 G- f* h& Y4 c: G" r
二、GPIO配置
7 c9 ?$ P  N7 d, ^6 ^7 F' @
  1. GPIO_InitTypeDef GPIO_InitStructure;! ^( k# q3 e* |7 ?; [+ D3 N
  2.   /* 使能AHB时钟 */
    - U; x$ ^! G; ~! |4 I  ~
  3.   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
    / z' P) a; N& |* K( Z- N! o
  4.   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
    4 q( e& d2 M$ @1 ~; a0 s
  5.   /*定义 SPI复用引脚 */
    " C% t5 D: V# e, P% |, Z4 h# e
  6.   GPIO_InitStructure.GPIO_Pin = PIN_SPI_SCK | PIN_SPI_MISO | . M# r2 J9 T* D2 ?% h6 o# l7 o+ E
  7.   PIN_SPI_MOSI;4 R8 d3 t* r( V5 s+ ?
  8.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;                   //复用模式0 t1 C, K' L8 \& F1 U* ]1 G+ j! U. W
  9.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;              //高速输出
    & h- Z% g# q  z- j
  10.   GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;                 //推完输出
    . t; H6 P6 s8 H% v
  11.   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;                   //上拉
    ) N" s  t3 e  `! B
  12.   GPIO_Init(PORT_SPI_SCK, &GPIO_InitStructure);: u" S5 R# U9 B( M
  13. & X3 V: f* d' h0 f. M, Y0 S
  14.   GPIO_PinAFConfig(GPIOB, GPIO_PinSource3, GPIO_AF_0);
    2 _, y% c6 Q6 q, I0 |5 m! \
  15.   GPIO_PinAFConfig(GPIOB, GPIO_PinSource4, GPIO_AF_0);
    8 F. }! I7 C* }: H& Q6 F+ [! V
  16.   GPIO_PinAFConfig(GPIOB, GPIO_PinSource5, GPIO_AF_0);* F! ^/ a2 e9 A8 A- h6 _: `6 J5 v
  17.   /* 片选CS */- y, \+ @# q* P# j' O5 W* ^
  18.   GPIO_InitStructure.GPIO_Pin = PIN_SPI_CS;
    3 c3 L; Z/ s5 z5 Z0 z
  19.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;                  //输出模式% D- w% v- y) r3 h3 a/ |
  20.   GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;                 //推完输出
    6 c) |& A( h* n# v+ t5 c
  21.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;              //高速输出
    4 q) N# ?% p" ]! h6 d: o! }, H2 f
  22.   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;                   //上拉4 V; r( b/ y8 |) j! o
  23.   GPIO_Init(PORT_SPI_CS, &GPIO_InitStructure);+ |, @" ~* R7 [- y8 R
三、SPI配置2 w, ^5 T" c& ^; n6 X& s  f
  1. /* SPI 初始化定义 */$ I3 C, o2 [0 v8 H
  2. SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //SPI设置为双线双向全双工
    2 u7 y; x* b- ^/ C& p
  3. SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                      //设置为主 SPI
    1 M/ q0 a8 `0 @
  4. SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;                  //SPI发送接收 8 位帧结构: _; H; t+ H2 _4 f* F1 M
  5. SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;                        //时钟悬空低* b/ w) a. l& T% p/ n0 X& O- ~
  6. SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;                       //数据捕获于第二个时钟沿! \; l+ {- Q; x  D
  7. SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;                          //软件控制 NSS 信号
    ) Q# h3 P; E: A6 o" S& q1 ?
  8. SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8; //波特率预分频值为8
    / H: ^& O8 `+ u9 y! W, |6 E
  9. SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;                 //数据传输从 MSB 位开始- u+ _" Q* W/ V1 P
  10. SPI_InitStructure.SPI_CRCPolynomial = 7;                           //定义了用于 CRC值计算的多项式
    ( r' u: `) a1 @
  11. SPI_Init(SPI1, &SPI_InitStructure);
    % o+ I/ x- h  r/ I0 \) B
  12. 6 z2 ]: {, G, w) P* a
  13. SPI_RxFIFOThresholdConfig(SPI1, SPI_RxFIFOThreshold_QF);
    % s" x: M+ k6 g9 k1 M* R& ~# B1 X
  14. SPI_Cmd(SPI1, ENABLE);
此处有一点需要注意哦,STM32F0区别于STM32F1系列,SPI初始化后需要初始化RxFIFO:SPI_RxFIFOThresholdConfig(SPI1, SPI_RxFIFOThreshold_QF);- r: Y& y" o1 e; s7 K- T- A9 W
至于结构体参数的初始化参数,根据自己项目改。我里使用的是内部晶振超频56M,8分频获取7M的SPI时钟。(为了获取最大传输速度,别问为什么,就是需要这么干,之前在群里讨论我的时钟速度为什么上不去,结果很多人问我为什么要那么高的时钟,追求速度?什么东西要那么高的速度?。。。。。。。。我。。。。对了,顺便说一下遇到的坑,我有示波器和逻辑分析仪,我一直用逻辑分析仪,时钟怎么都上不去,一直是2M,真的是找遍了原因,最后是逻辑分析仪的速度设低了,让你手贱!让你手贱!!)3 Y0 V$ z* A( _9 ~
四、SPI发送接收(非DMA)
" V4 j) w/ @6 Q4 b& _/ G9 {
  1. uint32_t SPI_WriteRead(void)5 [+ U- D  k; y9 g, O9 ~# H0 ^
  2. {5 p3 f0 u$ d. R4 G5 M5 w
  3.    uint16_t num1,num2,num3;
    9 a& |7 [4 h: g
  4.    uint32_t AngelData;
    7 C$ \2 I. }. q8 i/ w/ T& m
  5.    GPIO_ResetBits(GPIOA, GPIO_Pin_15);//拉低片选, z- d% p& D5 @
  6.    *((uint8_t*)&(SPI1->DR) + 1 ) = 0x3F;//发送指令
    / g6 w2 _: Q( z. i: Z% s% g8 ^
  7.    num1 = SPI1->DR;    //读SPI, Z$ f  c# d& T- b/ ?
  8.    while(SPI_I2S_GetFlagStatus(SPI1,SPI_I2S_FLAG_TXE) == RESET);   3 x' l: C; V. g& J& E) i
  9.    while(SPI_I2S_GetFlagStatus(SPI1,SPI_I2S_FLAG_BSY) == RESET);
    % l$ B+ Q0 F, q7 {; @- d' h* C4 |; g/ k
  10. / g/ F: g  F* _8 m  o! T  Q
  11.    *((uint8_t*)&(SPI1->DR) + 1 ) = 0xFF;//发送无关数据,为了获取返回数据, S: |8 D2 P4 O: a3 P; u
  12.    num2 = SPI1->DR;//读SPI/ X' C6 \1 T* ~" h
  13.    while(SPI_I2S_GetFlagStatus(SPI1,SPI_I2S_FLAG_TXE) == RESET);
    % O) l- n5 a$ q1 L% P
  14.    while(SPI_I2S_GetFlagStatus(SPI1,SPI_I2S_FLAG_BSY) == RESET);( v& e; P5 |" I0 L0 N& F: a
  15. ! ~5 X  M; Q+ B
  16.    *((uint8_t*)&(SPI1->DR) + 1 ) = 0xFF;//发送无关数据,为了获取返回数据
    1 _# k/ y5 e$ t  @
  17.    num3 = SPI1->DR;//读SPI, a7 h' ?1 v, W  \
  18.    while(SPI_I2S_GetFlagStatus(SPI1,SPI_I2S_FLAG_TXE) == RESET);+ D9 S/ g2 @+ k- q4 g8 K, H: a/ O
  19.    while(SPI_I2S_GetFlagStatus(SPI1,SPI_I2S_FLAG_BSY) == RESET);
    0 U4 i! n/ S7 Z& l% Y+ E& X
  20.    GPIO_SetBits(GPIOA, GPIO_Pin_15);//拉高片选
    $ K6 P$ r& ^: b. m
  21.    AngelData = ((num2&0xFF)<<16 |(num3&0xFF)<<8 | (num1&0xFF));( |4 E6 _2 u5 j; @+ r( c
  22.    return AngelData ;
    7 y4 Q! _5 D' T; l' R! X; M5 o1 X
  23. }
说一下注意的点,STM32F0慎用while(SPI_I2S_GetFlagStatus(SPI1,SPI_I2S_FLAG_RXNE) == RESET);判断数据接收完整,非常容易卡死在这里面,可以使用忙标志判断,很好用,不然会提前拉高片选信号,导致数据不完整。
. |' O, h8 R, F; r: N
如图,我发送24位数据,时钟却输出很多。因为DR寄存器是16位的,如果你直接SPI1->DR = 0xFF ; 这样的操作是不正确的,你的数据会变成0x00FF之后赋值给DR寄存器,也就是操作了16位,所以STM32会输出16个时钟脉冲" @4 K  J* @( c: D
解决方法:0 d: k. q- ?. m- P4 }
我们先找到DR寄存器的地址,再用一个八位的指针指向这个地址,现在指向的是DR寄存器的开头,那么指针+1,指针指向了DR寄存器的低八位这时候给指针指向的地址赋值0xFF,那么这个字节就会放入DR低八位的空间内,而不是操作整个16位DR寄存器," N- x+ u3 _. |' U
((uint8_t)&(SPI1->DR) + 1 ) = 0xFF;
) m8 d3 z( i' Y$ ^; a' z% k经过上面的代码就已经可以获得24位数据,时钟也会连续,不会出现上面两张图片的问题,后面贴上DMA的代码。" g- ]: Q8 I2 F. _9 W( P8 B
五、SPI DMA配置
- E7 v8 o8 h+ u7 I# s
  1. void MYDMA_TX_Config(DMA_Channel_TypeDef* DMA_CHx,uint32_t cpar,uint32_t cmar,uint16_t cndtr)4 m6 S# S/ Q' q# _5 I
  2. {
    : e" y% S' ~: d- u# Y
  3.     DMA_InitTypeDef DMA_InitStructure;- R/ q, c/ d/ S7 [& x5 B* w; k- b
  4.     RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);  //使能DMA传输
    7 }7 b0 Y7 o# ?' g& ~' r
  5.     DMA_DeInit(DMA_CHx);   //将DMA的通道3寄存器重设为缺省值8 L+ W! J. ?7 d) ~; T
  6.     DMA1_MEM_LEN=cndtr;; Q  S9 V; p4 T1 O# @- O
  7.     DMA_InitStructure.DMA_PeripheralBaseAddr = cpar;  //DMA外设基地址
    5 a! Y8 W  j" G4 G+ Y/ f$ ]1 _8 P/ H
  8.     DMA_InitStructure.DMA_MemoryBaseAddr = cmar;  //DMA内存基地址) w, d: k  F% t3 z- L
  9.     DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;  //数据传输方向,从内存读取发送到外设
    % _4 K% J- b& a' i, i! f% v
  10.     DMA_InitStructure.DMA_BufferSize = cndtr;  //DMA通道的DMA缓存的大小: ~2 e0 U) S/ B' n6 d; i5 f$ q  ?' Y* x
  11.     DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;  //外设地址寄存器不变5 b1 l& q$ h7 |' b% A0 ]
  12.     DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;  //内存地址寄存器递增$ \% Z# H/ {. e; \, {+ O
  13.     DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;  //数据宽度为8位
    - G( i( i8 g; K& b2 Q5 k  @3 r) q8 Z( C
  14.     DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; //数据宽度为8位1 e, X  a2 J7 I
  15.     DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;  //工作在正常缓存模式  P/ y+ h) [; ~+ R; j, u- T- w
  16.     DMA_InitStructure.DMA_Priority = DMA_Priority_Medium; //DMA通道 x拥有中优先级 3 h$ v0 h" H/ ^% E6 O
  17.     DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;  //DMA通道x没有设置为内存到内存传输
    # _1 w5 V: ]/ D. I6 \2 j
  18.     DMA_Init(DMA_CHx, &DMA_InitStructure);  //根据DMA_InitStruct中指定的参数初始化DMA的通道SPI_Tx_DMA_Channel所标识的寄存器
    ' ^% v3 W$ J$ t1 d7 u
  19. }
    4 V1 `3 `4 M6 _( N
  20. //开启一次DMA传输
    0 c2 l2 P6 o; |0 f% b; W
  21. void MYDMA_TX_Enable(DMA_Channel_TypeDef*DMA_CHx)! ~' C" F3 s" h% x( c6 q% F
  22. {
    . y3 v/ Z+ I- J4 d) B$ h) e
  23.     DMA_Cmd(DMA_CHx, DISABLE );  //关闭SPI TX DMA1 所指示的通道
    9 H1 [6 A4 E% X2 ^/ O6 t7 ^% h% u
  24.      DMA_SetCurrDataCounter(DMA_CHx,DMA1_MEM_LEN);//DMA通道的DMA缓存的大小1 J& s+ z' H0 Q* B  z$ R# w( l5 ?
  25.      DMA_Cmd(DMA_CHx, ENABLE);  //使能SPI TX DMA1 所指示的通道
    + E8 J5 _6 G+ h8 \  r2 l
  26. }
    * a. J8 c0 C' B+ m+ z0 t
  27. - z5 P2 d& s6 J! s, I- u
  28. 9 y4 [" M4 N+ c( C! _8 d
  29. void MYDMA_RX_Confog(DMA_Channel_TypeDef* DMA_CHx,uint32_t cpar,uint32_t cmar,uint16_t cndtr)/ \0 G* ^% S/ s& V! u
  30. {
    4 @2 i, p9 g7 m& e1 G( P
  31.         DMA_InitTypeDef DMA_InitStructure;
    ' O' A4 }( G$ D
  32.      RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);  //使能DMA传输( `- c: n$ x" _, U, \
  33. 6 {0 d3 P9 q2 {: i. X
  34.   DMA_DeInit(DMA_CHx);   //将DMA的通道2寄存器重设为缺省值
    , e! D% d- W4 _1 y, S& s7 |6 T8 Z0 O
  35. 6 i6 \# A4 i$ n1 ?! I$ e; ]& [) x
  36.     DMA1_MEM_LEN=cndtr;
    ' Y, R6 h% I/ \0 x" ]& g. p$ D
  37.     DMA_InitStructure.DMA_PeripheralBaseAddr = cpar;  //DMA外设基地址
    ' e! [( f& t" E5 I. V4 {8 }* _
  38.     DMA_InitStructure.DMA_MemoryBaseAddr = cmar;  //DMA内存基地址
    & B4 b% D  M. @0 L/ @7 B
  39.     DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;  //数据传输方向,从外设到内存
    9 {' Q' n- k* C2 P
  40.     DMA_InitStructure.DMA_BufferSize = cndtr;  //DMA通道的DMA缓存的大小
    - H1 r8 C+ o( ]9 T' a4 c- s& ~5 P* W
  41.     DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;  //外设地址寄存器不变9 e" p6 G+ V% S/ J# ~( z
  42.     DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;  //内存地址寄存器递增
    / n; P$ V- Q" `9 v8 O" i& ~
  43.     DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;  //数据宽度为8位
    : T( L# ?0 v% F3 N0 g+ b; @/ N
  44.     DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; //数据宽度为8位# z: e1 A: L" d: R
  45.     DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;  //工作在正常缓存模式
      r3 N' C" _. R0 y$ m( Y
  46.     DMA_InitStructure.DMA_Priority = DMA_Priority_Medium; //DMA通道 x拥有中优先级 * O  a: J. x; ]1 G* W% U
  47.     DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;  //DMA通道x没有设置为内存到内存传输
    2 p+ t" x: e! P9 }
  48.     DMA_Init(DMA_CHx, &DMA_InitStructure);  //根据DMA_InitStruct中指定的参数初始化DMA的通道USART1_Tx_DMA_Channel所标识的寄存器
    # w/ J/ C/ _; x* b1 C9 r) o" F
  49.     DMA_Cmd(DMA1_Channel2, ENABLE);  //使能USART1 TX DMA1 所指示的通道
    * y0 u) q* M8 @: o
  50. }6 \" R6 S/ r  r' I1 ~
  51. & i+ Q5 a  o# H* X3 q6 l# {& B8 U/ w# b
  52. //开启一次DMA传输
    - c, _, c( K; T+ g
  53. void MYDMA_RX_Enable(DMA_Channel_TypeDef*DMA_CHx)6 U4 L: u$ k; q: w! s
  54. { . P! S3 \8 I0 N0 s
  55.     DMA_Cmd(DMA_CHx, DISABLE );  //关闭SPI RX DMA1 所指示的通道
    / b2 k2 E: X: ^+ h' Z! y2 _
  56.      DMA_SetCurrDataCounter(DMA_CHx,DMA1_MEM_LEN);//DMA通道的DMA缓存的大小
    + x; R0 Q5 i) d2 b  K
  57.      DMA_Cmd(DMA_CHx, ENABLE);  //使能SPI RX DMA1 所指示的通道 6 F& w6 p3 z! s5 h: x* R$ p
  58. }
六、SPI发送接收(DMA模式)& M  ]& x$ g0 e6 O, g
  1. void SPI_DMA_WriteReadByte(void)
    4 G! U# R+ ~4 `2 c; Y
  2. {
    5 F8 E- ]0 y9 y& @' Q5 f" E2 c6 U
  3.     GPIO_ResetBits(GPIOA, GPIO_Pin_15);//拉低片选       (放在此处为了节省0.5us的时间)& j5 x. S+ ]8 V4 z# C" h# E
  4.     SPI_I2S_DMACmd(SPI1,SPI_I2S_DMAReq_Tx, ENABLE);//SPI 发送DMA使能
    ! {" k; n2 Q* k
  5.     SPI_I2S_DMACmd(SPI1,SPI_I2S_DMAReq_Rx, ENABLE);//SPI 接收DMA使能( v& j0 D1 b: h, Y( [1 h1 e  B
  6.     MYDMA_TX_Enable(DMA1_Channel3);     //发送, x- D) O; A" I1 W5 t" H
  7.     MYDMA_RX_Enable(DMA1_Channel2);//接收
    4 s. M( o( d# J2 g. `
  8.     if(DMA_GetFlagStatus(DMA1_FLAG_TC3) == RESET)
    2 K$ t. z2 Q4 H1 }. V
  9.     {
      ]- ~, u- k/ @0 D$ R
  10.         DMA_ClearFlag(DMA1_FLAG_TC3);
    & X4 C# Y7 F- `+ t+ f# e1 {
  11.     }                   , K! B; M1 i/ W  U6 a6 d
  12.     while(SPI_I2S_GetFlagStatus(SPI1,SPI_I2S_FLAG_TXE) == RESET);   2 ~" `5 p0 C+ Q* D2 s, A
  13.     while(SPI_I2S_GetFlagStatus(SPI1,SPI_I2S_FLAG_BSY) == 1);   //保证发送接收数据完整
    6 s& \; }9 C8 i  _
  14.     GPIO_SetBits(GPIOA, GPIO_Pin_15);//拉低片选' T- Q2 b. m$ [8 Z# Z
  15. }
2 X/ ]2 Y- p$ S! D7 \
/ @% C1 K* i* r# R: J, E9 q
& Z# p. I& Q, o3 _; ?; c6 r! E
. b! d3 X# C$ G: v7 Y4 V
9 V4 a6 I8 F$ P/ A9 O4 o- P9 v$ ]
赞 收藏 1 评论0 发布时间:2021-5-28 14:38
