我使用Truestudio在线调试出现Target is not responding, retrying... Error! Failed to read t
Dhch 提问时间:2021-9-14 17:48 /
现在我可以确定的是硬件电路应该没有问题,我用keil写了个点灯可以正常下载正常在线debug。但是用Truestudio跑STM32CubeMX生成的工程时出现如下报错:
STMicroelectronics ST-LINK GDB server. Version 5.1.0
Copyright (c) 2018, STMicroelectronics. All rights reserved.
Starting server with the following options:
        Persistent Mode            : Disabled
        Logging Level              : 1
        Listen Port Number         : 61234
        Status Refresh Delay       : 15s
        Verbose Mode               : Disabled
        SWD Debug                  : Enabled
Waiting for debugger connection...
Debugger connected
                       STM32CubeProgrammer v1.3.0
Log output file:   C:\Users\think\AppData\Local\Temp\STM32CubeProgrammer_a05256.log
ST-LINK SN  : 50FF6C066686575026510487
ST-LINK FW  : V2J37S7
Voltage     : 3.23V
SWD freq    : 4000 KHz
Connect mode: Under Reset
Reset mode  : Hardware reset
Device ID   : 0x441
Device name : STM32F412
Device type : MCU
Device CPU  : Cortex-M4
Memory Programming ...
Opening and parsing file: C:\Users\think\AppData\Local\Temp\ST-LINK_GDB_server_a05256.srec
  File          : C:\Users\think\AppData\Local\Temp\ST-LINK_GDB_server_a05256.srec
  Address       : 0x08000000
Erasing memory corresponding to segment 0:
Erasing internal memory sectors [0 4]
Download in Progress:
File download complete
Time elapsed during download operation: 00:00:02.454
Verifying ...
Download verified successfully
Error! Failed to read target status
Debugger connection lost.
Shutting down...
赞 收藏 评论2 发布时间:2021-9-14 17:48
Dhch 回答时间:2021-9-14 17:49:10
芯片是STM32F412RET6
butterflyspring 回答时间:2021-9-15 10:14:48
log 上看到下载成功了,会不会是下载的代码内容对调试有影响呢?可是试试其他程序先。
