AD转换即模拟信号转换为数字信号,一般在单片机中模拟信号对应电压,通过ADC口将相应的电压转换为二进制的数字信号,从而推算出测得电压。下面我介绍下STM32中L0系列调用库函数来实现AD转换。* P3 h: W. L8 \( o' v
- D2 R- @8 h- k) L" o
首先最基本的AD转换模式,即单次单通道检测,且不用到DMA。L0系列一共有19个AD口对应19个AD通道,其中16到18为检测内部模拟信号的通道。下面代码中用到是PA0即对应通道0,具体代码如下图:
2 [" v0 w @, O! p1 r$ I! a! ^) q5 P) c
- Adc_init()+ S) \# q: [' L8 o7 v' J
( }+ J6 d( g8 n& d, M2 v8 k8 _) h- {4 q0 u5 ]# \+ d; i b9 o) X2 X
- __HAL_RCC_ADC1_CLK_ENABLE();( k( b+ W& L' t+ N& \/ c
- AdcHandle.Instance = ADC1;" j# u% ~+ I4 Y" b2 C; |- U& R. }: S
- 4 i8 M* P# r5 i0 b. T: T
- AdcHandle.Init.OversamplingMode = DISABLE;- S! R! q' s$ I3 r! t
5 a- X$ Q# L7 r6 d; ]- AdcHandle.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV1;
0 y0 j' d5 X1 G - AdcHandle.Init.LowPowerAutoPowerOff = DISABLE;6 x; w$ ~4 \9 p
- AdcHandle.Init.LowPowerFrequencyMode = ENABLE;
7 @9 O. y. H0 s% K1 J: W - AdcHandle.Init.LowPowerAutoWait = DISABLE;
9 L+ E, S1 H8 k - 3 \' ~. ^: v' Z0 p7 |5 o
- AdcHandle.Init.Resolution = ADC_RESOLUTION_12B;
4 k1 }1 d) W' o" m - AdcHandle.Init.SamplingTime = ADC_SAMPLETIME_7CYCLES_5;' V# U1 G' `7 F' e% `, @$ G3 O
- AdcHandle.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;, H# m q1 p* [% _1 ~/ f
- AdcHandle.Init.DataAlign = ADC_DATAALIGN_RIGHT;! V+ ]& ^* D: P9 B$ F7 G
- AdcHandle.Init.ContinuousConvMode = ENABLE;
2 S: O7 E0 [4 m$ M" s" Y3 B - AdcHandle.Init.DiscontinuousConvMode = DISABLE;
! Q$ A% L. [& ~0 `' C - AdcHandle.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;$ B4 ^ t# M/ n& j/ Z- s* v' d
- AdcHandle.Init.EOCSelection = ADC_EOC_SINGLE_CONV;1 u4 V! t. }$ e; f4 L
- AdcHandle.Init.DMAContinuousRequests = DISABLE;
% F2 \8 z6 |: ~ - 0 k- b1 J% a" B7 Y) g8 ^, |
- HAL_ADC_Init(&AdcHandle);" o( t; Z6 g. m {2 T$ {
- HAL_ADCEx_Calibration_Start(&AdcHandle, ADC_SINGLE_ENDED);
! ~* Q7 j9 i$ O0 A$ Z$ \. G
$ y; R' J X1 q) s J- }" k$ D& m0 _8 ^; H
0 y( c" N% \' E: f- n1 [! A% \- //配置ADC初始化' q- M' x$ b+ v) D8 @
- ! N, m! D5 V, M' q
- void HAL_ADC_MspInit(ADC_HandleTypeDef *hadc)8 w+ Q; C( S {
% h7 e1 F, q6 [+ p, O9 \$ ~ - GPIO_InitTypeDef GPIO_InitStruct;$ a0 l C" s" P9 M# ], T6 j
- * t& l# t% W0 o Y
- /*##-1- Enable peripherals and GPIO Clocks #################################*/
5 _- u; S2 Z6 P, k0 \- M - /* Enable GPIO clock ****************************************/; q, w4 s5 C; d t: t1 Q
- __HAL_RCC_GPIOA_CLK_ENABLE();
/ B( R& R- w U3 M - /* ADC1 Periph clock enable */
8 u% s) \5 q9 A! Y - __HAL_RCC_ADC1_CLK_ENABLE();
$ R+ e% ^7 W! ?- T
2 M# l u& s6 f: Z$ P- /*##- 2- Configure peripheral GPIO #########################################*/# I2 |' O- I, e$ E
- /* ADC3 Channel8 GPIO pin configuration */3 E" P- V4 y r$ {# e1 e0 \* F
- GPIO_InitStruct.Pin = GPIO_PIN_0;
5 s* P* b: e- J7 |& W! v& o3 G2 E" b - GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
/ p4 _0 W' ^! W9 v! }4 V0 T- N - GPIO_InitStruct.Pull = GPIO_NOPULL;) Y$ `+ |" i2 O& T3 y
- HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
& V/ H+ v: M0 ]+ _: V/ L - }/ z3 B: F; n% R1 v) \- g: G" \3 M$ V) Z
- 4 f4 C# O6 K+ [' v) B7 T
- //初始化ADC引脚PA0,开启时钟: [ H/ V- {$ e: X
- ( Z* |. b. ?; G4 |
- void get_voltage(void)
$ [1 P5 X+ }5 S - {& j$ K2 I' ` U7 `) r- \% a+ {
- bsp_adc_init();
& Y5 v) l y. a) q - HAL_ADCEx_EnableVREFINT();
4 {, f0 S7 ~' c! y9 j0 ?# D - HAL_ADC_Stop(&AdcHandle);
" V" ?/ {5 h! U; ? \5 i - AdcHandle.Instance->CHSELR=0;
7 \& N8 O' K4 U$ P- j - sConfig.Channel = ADC_CHANNEL_17; //通道17专门测内部电压值
+ W' y1 {2 N* b( C o - HAL_ADC_ConfigChannel(&AdcHandle, &sConfig);
, t o: f3 F" g- V& U - HAL_ADC_Start(&AdcHandle);3 N; @% C' C# V1 l4 N
- HAL_ADC_PollForConversion(&AdcHandle, 10);
0 h1 D' @& B# ?% U5 j8 z% Q - /* Check if the continous conversion of regular channel is finished */+ N; E2 f! h4 m, I
- if ((HAL_ADC_GetState(&AdcHandle) & HAL_ADC_STATE_REG_EOC) == HAL_ADC_STATE_REG_EOC)1 Y i/ r. I( w2 z
- {4 t* Z2 z0 q! U1 h: v
- /*##-6- Get the converted value of regular channel ########################*/5 J6 `4 n* a- j$ \; s9 F
- uwADCxConvertedValue = HAL_ADC_GetValue(&AdcHandle);% _ s$ {" _' V& {
3 w$ u. O9 U8 }$ [# E% \
% o9 d+ K X# y7 Q9 u+ d4 d6 v- vdd_value=VREF_IN_VALUE*FULL_ADC_DIGTIL_VALUE/uwADCxConvertedValue; //内部电源电压
, u, K% Z7 l( C, i: I, p - HAL_ADCEx_DisableVREFINT();
/ ?, E( q, {2 z/ W$ _ - HAL_ADC_Stop(&AdcHandle);- E0 m/ B+ q, A1 j0 d s( Z1 \
- AdcHandle.Instance->CHSELR=0;5 M7 I8 T/ F" E& c) x: u* Y
- sConfig.Channel = ADC_CHANNEL_0; //ADC0,去测外部PA0口接的电压
( M3 Z1 M Y. `: Q, q; t - HAL_ADC_ConfigChannel(&AdcHandle, &sConfig);" ^, X; Y) G$ F7 `6 i: e. L8 ]
# T% H) Q- r* B2 d `, a - HAL_ADC_PollForConversion(&AdcHandle, 10); 7 f8 K+ j; |, O, ^1 E2 M- E
; n6 |) e# T- T - if ((HAL_ADC_GetState(&AdcHandle) & HAL_ADC_STATE_REG_EOC) == HAL_ADC_STATE_REG_EOC)
# ?- ?: q: n$ ^+ \ - {* o+ E/ b$ Y, P4 K! Z! z+ P7 w
- /*##-6- Get the converted value of regular channel ########################*/" j7 `. D8 ^4 i! ~4 ]
- uwADCxConvertedValue = HAL_ADC_GetValue(&AdcHandle);5 H3 F) [* A5 @) J* \' a9 }
/ e7 D, {! @7 M4 p/ U8 { - //直接获取的是二进制码,14位对应最大值4095,内部电压为vdd_value通过比例计算得到电压数值
! C1 p$ D( A8 N8 J! u - temp_voltage=(float)uwADCxConvertedValue*vdd_value/4095;! G0 o" r2 n: p" z
- //得到浮点型电压值 是乘了1000倍的
8 h8 M4 T+ d% V) h* e/ R& @ - HAL_ADC_Stop(&AdcHandle);
+ [+ {$ ]" ~0 o3 Q2 ?) P- k - //HAL_ADCEx_DisableVREFINT();
/ z2 f; o) u2 h9 y2 m" H- f* I - __HAL_RCC_ADC1_CLK_DISABLE();
2 F: {. r: y# I- A5 K# Y* G' g2 B - }
- K/ x' N) M4 L* O, R; M - }
复制代码 0 F" \ S5 {, x9 H+ Z/ ?) b7 K
! N9 y2 e: m4 \# r" I; L$ m 以上ADC检测,相当于一次连续检测了两次,第一次为内部电压用的特地通道17,第二次检测的是外部电压对应硬件连接的PA0对应通道0' R- M* x) A) ]9 B
" e: m6 f6 A0 k: u4 G) \8 i& g( c8 r& y9 X8 V( {9 c
