- #define HAVEKEY_PIN 0x0003 //& u$ T y$ v+ v
- #define KEYPOP 0x0000
1 t i- S* g8 K/ |6 }3 z; Q$ Q. I u - # k( f( x8 D4 X h t
- #define KEY_START_PRESSED 1 //
% @5 K8 ^, v0 u, k
/ g; I; C# ?8 u4 E4 A. |- typedef struct
* o' [! ]0 ?$ R1 @1 D1 `) { - {
0 ~2 N8 C- | h+ A - INT8U bLastValue; //; x# I( D4 |5 X, J! Q9 ^/ X
- INT8U bDebunceTime; //
0 f; r2 L# J3 ^. ?) l - INT8U bPressed; //; }& i( r+ t$ D, U7 V
- INT8U bValue; //
# a- _! R0 N8 P9 ^ - INT8U bState; //
4 I5 P# K1 Q6 @; y - } tKEY;
复制代码 0 S( h1 ]" K( c7 I1 J
1. 按键IO口配置# c6 W# [$ B8 D$ J* ^" ]2 K4 s# ]
0 ?0 ]9 e: T# p- void KEY_Init(void)
0 ?9 k! e$ o6 p - {. e+ q1 c: R* U7 `8 R& r
( F# h4 q( U B% T8 H* T- GPIO_InitTypeDef GPIO_InitStruct;
" `1 M/ V$ ^' k0 C/ P - RCC_AHBPeriphClockCmd(RCC_AHBPeriph_KEY_PORT, ENABLE);
f5 s; _# g" \ - GPIO_InitStruct.GPIO_Pin = PAUSE_KEY_PIN | CLEAR_KEY_PIN ;//| ENTER_KEY_PIN | SET_KEY_PIN ;% r3 f# l- O% J# V( M+ O6 Z. ^
- GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN; //GPIO_Mode_AF,GPIO_Mode_OUT3 q/ }: ^6 V: u
- GPIO_InitStruct.GPIO_Speed = GPIO_Speed_Level_2;
* }, Y X- j1 U+ f( S8 _, ? - GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_UP;
# h4 ^- ?$ |9 `7 l) y4 G( z( o- ^' {, w - GPIO_Init(GPIO_KEY_PORT, &GPIO_InitStruct);1 w( N' y8 o7 d3 E) |$ z
- 5 _8 |8 Q/ r! u. a' @
- memset( &KeyCtrl,0,sizeof(tKEY));7 O" @; z$ \& v$ g& c" }& z
6 L9 ]; _5 b# m$ t+ g N
复制代码 ' [" G; Q2 Q) X0 e
2. 按键debunce时间,在timer里调用: E# l: G/ p: U. a
9 N0 E& U4 L, L' F' l- void KeyCtrlbDebunceTimeDec(void): N2 I% W& ?) f8 n
$ ?0 c+ u' K: a8 U* N4 A7 { - if(KeyCtrl.bDebunceTime)9 X- _& J7 G5 z( H: I
- {+ g( d$ {- E* t$ ~ W/ p
- KeyCtrl.bDebunceTime--;
. u4 B1 M2 ?& N" Y8 r( z# A3 C - }
7 K- P" G$ V+ \8 p5 y% D9 S8 @ - else
" R3 e& O9 E' D4 z! A - {
% O! E: ?: |9 a& g4 H& z - KeyCtrl.bDebunceTime = 20;. Z. X4 W+ M. ^& e
- }8 d, {0 K6 w/ ^" I6 F
/ B. C' w( z4 i3 R+ W) w3. 扫描按键& }; i7 i$ v4 f* [
6 l% K0 N, v+ T
- INT8U KeyScan(u8 *bKeyValue)
+ e0 C w( M0 S9 i - {
+ a3 x9 a1 ^6 c; K' x - int TempKeyIn;1 [* o. I6 b) j( k! O% V( P
- TempKeyIn = GPIO_ReadInputData(GPIO_KEY_PORT);" M1 e7 x- i7 Y k7 H, Z7 e
- ! s& V c% u% o- @8 m3 f
- TempKeyIn = GPIO_ReadInputData(GPIO_KEY_PORT) & HAVEKEY_PIN; //get high 8 bit
9 w% ]3 y7 u: M% p! { - TempKeyIn = (TempKeyIn ^ 0xffff) & HAVEKEY_PIN;
9 u/ n& u, e: X" k) Z - if(TempKeyIn == 0x0000) //no key pressed$ ?( G4 @6 J. ~1 g/ ~5 R& m
/ }7 q) z9 M# x. c% a: M9 e - memset( &KeyCtrl,0,sizeof(tKEY));
$ M: [# C9 l( z - return NOKEY_PRESSED; ; y* b. j( _& p
- }" A* k9 Q5 l N5 C1 N* ] r! |
- else. G8 Z3 n, K8 c* v& D) Q3 G
- {( {- [1 d# z3 S# d
- if(KeyCtrl.bState != KEY_START_PRESSED) //start key pressed# I" ?# e; ]6 ]" |" t+ K# } Y+ X. [
- {# ]3 v: }* U# J! _$ v
- KeyCtrl.bState = KEY_START_PRESSED;
% [7 _& C/ L+ ~5 \ - KeyCtrl.bDebunceTime = 20; //10ms
; S0 B! B3 \! ]6 L4 I2 j! e4 q - return NOKEY_PRESSED;
1 e0 E: G* z* g% Z; c# Q) F - }
" a, G f$ U' E - else( p- D" s8 t, b& A1 t
3 P7 `: c m! q& i - if(TempKeyIn == KeyCtrl.bLastValue) //lastkey" D! p) _ E3 x* h& W
: p( W P" @7 \3 K! o5 d: { - return NOKEY_PRESSED;
# R- m' Q+ n0 d - }9 I7 z! F0 h9 l' {
- else
1 g2 q' B$ K! j - { B1 F$ Y5 G0 ]( c# ?1 ] Y
- if(KeyCtrl.bDebunceTime !=0) //debunce time? 10ms1 {. F5 S6 y4 D) x" Z0 O% p; Y
- {+ ^* g6 R1 B+ T7 F+ e# n
- return NOKEY_PRESSED;8 h/ |2 p6 P" V: f m# A
$ Z8 x' b1 p, S- e4 l - else" ]) ~ F8 G2 l. }' q
- {$ t, Z6 s7 ]; E4 k
- KeyCtrl.bLastValue = TempKeyIn;
! P, p# s: G/ T% m) R) H u - KeyCtrl.bValue = TempKeyIn;- ~+ Q$ }) x9 p+ [8 l# ^5 w
- *bKeyValue = TempKeyIn;
8 r/ N4 k/ ?$ F7 p0 F - return KEY_PRESSED;, k2 z" Q7 {% K" j3 P; a( ~
- }( X4 n/ A3 V2 ^, n% r- {
' T% i/ K5 @3 H6 _7 _6 e - }
% U' Q0 n c( O7 Q+ t7 a \% m7 ^ - }
2 Q& |4 `* ^. G) I - }
9 S; X; \1 W! f1 b0 v4. 按键处理
0 X9 J# C. o% _! E8 r+ L2 G6 c9 k
- void KeyPro(void)/ o; T: s5 m8 g/ g# E" c
- {" e0 d n; I9 n0 \2 p
- u8 KeyValue;
! v$ r5 c! n% t3 A3 m. \0 K - if(KeyScan(&KeyValue) == KEY_PRESSED)- L8 d; T1 |* W" ^7 B
( i3 U6 H) d% u0 r- i+ h - if(KeyValue == CLEAR_KEY)
' q. ]/ f' G. Y4 X2 i - {
: N2 I( R" U8 c3 Y+ }* R - ExtiCnt = 0;2 o2 m5 i E( n' Q) z. w
- }9 V- B) x c# k3 ]: V& N5 s4 {: E$ a
- else if(KeyValue == PAUSE_KEY)! I; o/ i6 a' o' j! e: h# o0 C" Q5 M: K
- {7 L! P- \, I$ I/ p0 i' J
- PauseFlag = ~PauseFlag;
/ u, ^5 a: n4 [/ ~; R' M1 b) ^9 I2 a - }
5 x* _$ |7 q" S3 ?5 @2 M - }
, ?7 n& W8 n* w; r* c: M" { - }
复制代码 + L; h+ @* C9 l
8 y* X/ d! |; k Z+ p5 g/ f) |
