STM32F0使用FLASH5 ?3 C0 m$ y$ O* |( a' _
* m4 Y0 a' |/ v3 h* r- 5 O' \ A5 }2 x4 V
- /* Private typedef -----------------------------------------------------------*/4 W1 q( k- U- f( }
- typedef enum {FAILED = 0, PASSED = !FAILED} TestStatus;
$ T9 h+ y7 ^0 I( L - /* Private define ------------------------------------------------------------*/; _ x _3 r# [# {! g9 M/ k5 M. `
- #define FLASH_PAGE_SIZE ((uint32_t)0x00000400) /* FLASH Page Size *// ], N# D6 q' k0 y7 ^+ j
- #define FLASH_USER_START_ADDR ((uint32_t)0x08003000) /* Start @ of user Flash area */
* x2 z0 a5 S) N3 G% H - #define FLASH_USER_END_ADDR ((uint32_t)0x08003000) /* End @ of user Flash area */
: Q4 T' h+ L0 \% D& Y& Z0 E) ? - #define DATA_32 ((uint32_t)0x12345678): _5 |8 n" l3 \: [" z6 W G
- * R8 x' H7 [' U+ z5 O% ?
- /* Private macro -------------------------------------------------------------*/7 R" W2 O6 x! I. |* L0 `, S
- /* Private variables ---------------------------------------------------------*/" D2 M6 V ]/ e8 I) s
- uint32_t EraseCounter = 0x00, Address = 0x00;
$ r# v: u! F: D- b( J7 s& h* c6 e - uint32_t Data = 0x3210ABCD;
0 Q ~+ I# H) V. o - uint32_t NbrOfPage = 0x00;5 Z9 g# I& `) L; H7 u: k0 ]
- __IO FLASH_Status FLASHStatus = FLASH_COMPLETE;1 Z( e: r6 p6 J$ Z3 W3 s1 ^) E
- __IO TestStatus MemoryProgramStatus = PASSED;
2 f6 u$ \6 M3 g! @. a: b4 M$ b
2 L& m- x' V; i2 {) M- /* Private function prototypes -----------------------------------------------*/& g. p6 B9 m# p8 d4 a+ a
- /* Private functions ---------------------------------------------------------*/; r# ]8 E* B3 S! y8 `
- 9 U1 N. I& J' j8 [7 K4 c
- : e! q6 J: N, D k0 C( o- f9 h
- //void delayus(uint16_t u16us) # Z+ J6 j \, d% G
9 h4 I9 H3 f: q$ u _2 Q/ j - // uint16_t i,j; 2 o9 J' B: g, I- c, ?8 I1 [
- h2 r2 p* T8 j - // for(i=0;i<u16us;i++)
" H; U" B3 [( M' w4 | - // {
' }4 i# l- ^. A, R$ M. R- w0 _$ B - // // for(j=0;j<30;j++) + Z8 `6 Q o4 v& z7 F& S s
- // { / G& Y- s- I! l( S; I- u
- // __NOP();
; T* x6 Z( ^9 e% p8 Y - // }
( `6 q5 q, P; [8 F" V( X - // } 1 Y! M, b B) w% D9 p3 _ Y& }
- //} ' a. l8 ]4 z- g! U
- void FlashRead()5 S2 c1 `2 c. Q9 Q/ i: j; X
- {, Y/ a1 C) h0 _3 ^0 A
- ' X) Z0 }9 j) K4 |6 a7 G0 v2 N
- /* Lock the Flash to disable the flash control register access (recommended% @% `- Z2 p1 S
- to protect the FLASH memory against possible unwanted operation) *********/5 |1 F+ j- ?1 c1 ^- R
- FLASH_Lock();
# Q3 \; K9 y0 S4 X
4 q# }0 ~- }' ^+ Z- r; i1 z; L; o- ' |7 F% k3 }8 A
- /* Check if the programmed data is OK . _ K9 p+ \3 R" \
- MemoryProgramStatus = 0: data programmed correctly+ q Q U$ a/ i# W
- MemoryProgramStatus != 0: number of words not programmed correctly ******/! g* p1 C; @, r0 ?* l
- Address = FLASH_USER_START_ADDR;
3 ]4 ?, U& y$ l* K - // MemoryProgramStatus = PASSED;
2 D e3 \; b0 X5 b# H0 h6 _- H f
0 P. O: w: b0 O7 D8 K- CONFIG_A = *(__IO uint16_t *)Address; Address = Address + 2; \! U$ C0 P) C
- CONFIG_B = *(__IO uint16_t *)Address; Address = Address + 2;
8 e/ L5 N! U9 L; A5 M- k+ ? - CONFIG_C = *(__IO uint16_t *)Address; Address = Address + 2;) G4 E& O# h8 `/ l% G; d
- " s& y0 C9 T3 c) q- ?& U
! k9 v1 ~, `' E( u - {2 D( ?2 ?0 ?! k! g5 K
- void FlashSave()
, c: n. J' ~" w8 @ - {* v. x0 I% S/ J! M- ?" g; o
- /*!< At this stage the microcontroller clock setting is already configured,
7 D2 }* b+ I* A5 j% f# M - this is done through SystemInit() function which is called from startup) b2 U& R. @8 G" G4 r f) b
- file (startup_stm32f0xx.s) before to branch to application main.1 e& G# j- _( _; T6 E1 _7 ?
- To reconfigure the default setting of SystemInit() function, refer to
1 Q! _) K* _, Z! z0 O - system_stm32f0xx.c file, I: K! D( @, ?, t; I
3 J+ J4 l# E9 M! g
0 a0 K l6 r) S" c2 i- /* Unlock the Flash to enable the flash control register access *************/ , Y6 k) E: F, p }0 T
- FLASH_Unlock();7 p! E/ v; I6 @: H$ M
- 1 \3 k$ ?6 E0 I, B' `
- /* Erase the user Flash area4 O+ K: Q$ ^- W+ m3 x i
- (area defined by FLASH_USER_START_ADDR and FLASH_USER_END_ADDR) ***********/
- y, N' `- R0 g% \+ p# u - - S7 ]9 u0 P5 Y6 Y; K+ T
- /* Clear pending flags (if any) */
! `# O1 s; _; C& Y. h3 w - FLASH_ClearFlag(FLASH_FLAG_EOP | FLASH_FLAG_PGERR | FLASH_FLAG_WRPERR);
5 z4 ^( s, y8 Y% H* ^ T - E1 v: u/ d. q$ K7 S* b
- /* Define the number of page to be erased */
: Z: B3 y; ]% F7 [( t1 i - // NbrOfPage = (FLASH_USER_END_ADDR - FLASH_USER_START_ADDR) / FLASH_PAGE_SIZE;
9 o* H0 J4 h, n2 G
' R, s7 e- q. @7 H' b4 Y. a! ]
* h; R+ ~: _) d2 |, `! A- /* Erase the FLASH pages */
1 g' L2 Z- s2 Y - // for(EraseCounter = 0; (EraseCounter < NbrOfPage) && (FLASHStatus == FLASH_COMPLETE); EraseCounter++)! Y4 Y( V& u' Y) k" |
- {, Q2 T* x: V7 s* O) u* T
- if (FLASH_ErasePage(FLASH_USER_START_ADDR )!= FLASH_COMPLETE)
5 { k/ T! s3 s4 j- ] v - {
' k! [* m7 J/ ~ - /* Error occurred while sector erase.
! ?( N6 t! Q9 R) F - User can add here some code to deal with this error */
: F6 J! d4 q8 {4 i) J& {( s - while (1)$ I2 n5 ]* E* r6 G" ]2 B
- {9 _" {8 ~3 y7 ~4 l! L
- TM1620_DISPLAY_DOT(999,0,PAGEB);//B999标识存储器错误+ r/ S* C+ f# K+ U
5 b( _2 ~: }, |4 h e" ?4 ^ - }1 ]1 _9 C- K9 k ]& y7 T# p9 C
6 ]( W- O% l- R j- ^3 r. B1 P - /* Program the user Flash area word by word
7 @3 J, b3 O) [, \1 A - (area defined by FLASH_USER_START_ADDR and FLASH_USER_END_ADDR) ***********/9 v( h# ]1 L0 X' v; d
" n" {+ W, T- g" E# [+ v3 B* K2 ]- Address = FLASH_USER_START_ADDR;& {2 O3 x4 s5 }# C# T
- $ X9 k0 r: |$ B
- // while (Address < FLASH_USER_END_ADDR)& m4 z5 Q- ^+ S' B" [/ N
! Y1 Y k: t! d# w3 i - if (FLASH_ProgramHalfWord(Address, CONFIG_A) == FLASH_COMPLETE)
) k0 j* c0 l7 d. M - {
$ Q/ I% o2 P4 l; x4 V! v
' @) W1 E' E- H& O5 o9 B0 d- }
# h% O' v7 t, n* x4 p$ o8 f - else
. X0 a* T6 N E7 Q2 @ - {
6 Z. ?! ?$ w2 F. V" t5 D* J) L7 { - /* Error occurred while writing data in Flash memory.
4 g4 S$ y& t: S - User can add here some code to deal with this error */
1 @! c$ s+ }2 H - delayus(100);
* G0 x. H( Y6 I. b1 r
m7 c9 @$ b0 H4 S* p! L# o* Q- # [' g" M! i* K4 u7 ~: R! J( r
! d' i% w9 o7 ]% r+ G' A, k- }, I+ @/ S$ z- R+ Z. p# M2 a
- Address = Address + 2;5 G8 ]# x& z" a, [+ j) x2 j' d+ {
- if (FLASH_ProgramHalfWord(Address, CONFIG_B) == FLASH_COMPLETE); h- @ |% I m# g& a
% u7 ?. G1 F2 N; N# x1 g
p/ g% U( R9 I: N- }
0 ` m9 q! K: k6 ~4 _ - else6 ^' ?. B. f* k/ L' I
- { 3 ]/ o5 I4 M: W% [5 d) t
* S; s9 X) e" M+ D! T& S5 Y - User can add here some code to deal with this error */
+ k/ o9 U, R' ?* I) F8 c7 y - delayus(100);
. {$ q. ^; m) L9 Y8 y7 u: s - }
5 C- v. R2 _* Y6 v - Address = Address + 2;
( R( O6 [6 g" S$ b - - ^8 k1 e D# R$ u
- if (FLASH_ProgramHalfWord(Address, CONFIG_C) == FLASH_COMPLETE) ) X4 r4 }1 e4 L; x0 a; U: [
- {: v; N3 c8 m; A5 u
" b3 G/ d0 U0 p5 d5 I% I4 }- }' v/ C3 d/ X7 G+ P# ]
- else5 |3 }9 O* [. X2 j
/ L8 h% E6 z. u - /* Error occurred while writing data in Flash memory. * f) [0 B; I( v R1 f7 ]3 W
: `# V: i; W! d; E+ c* p G - delayus(100);) ~: E: p2 y f7 E. \/ G$ d2 E
- }6 `2 z6 |0 W3 T5 F: f2 g- I
2 V* `% @- k6 b$ A
# E% p) N' l" Z/ u6 u- , ?% }6 v% k5 W! R4 ~( a* ?$ I
4 @4 J9 K$ ~( q5 u5 \- h) C- }
6 S4 ?" l7 }& @( t
) V' h) M- A9 s2 j2 ]
- @+ M3 u& ]6 ~0 v9 V |
