我用了ADC1,ADC2,ADC3,DMA1_Stream0,DMA1_Stream1,BDMA_Channel0,ADC1.ADC2.回调函数都是正常工作,就是ADC3.回调函数不能正常工作。有没有遇到这种情况的 芯片是STM32H750.ADC分频得80MHZ HAL_RCC_DMA1_CLK_ENABLE(); HAL_RCC_ADC12_CLK_ENABLE(); hadc1.Instance = ADC1; hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV10; hadc1.Init.Resolution = ADC_RESOLUTION_16B; hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE; hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV; hadc1.Init.LowPowerAutoWait = DISABLE; hadc1.Init.ContinuousConvMode = ENABLE; hadc1.Init.NbrOfConversion = 0x04U; hadc1.Init.DiscontinuousConvMode = ENABLE; hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START; hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE; hadc1.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DMA_CIRCULAR; hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED; hadc1.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE; hadc1.Init.OversamplingMode = DISABLE; HAL_ADC_Init(&hadc1) ; HAL_ADCEx_Calibration_Start(&hadc1, ADC_CALIB_OFFSET, ADC_SINGLE_ENDED); /* Configure the ADC multi-mode / multimode.Mode = ADC_MODE_INDEPENDENT; if (HAL_ADCEx_MultiModeConfigChannel(&hadc1, &multimode) != HAL_OK) { Error_Handler(); } hadc1.Instance = ADC2; hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV10; hadc1.Init.Resolution = ADC_RESOLUTION_16B; hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE; hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV; hadc1.Init.LowPowerAutoWait = DISABLE; hadc1.Init.ContinuousConvMode = ENABLE; hadc1.Init.NbrOfConversion = 0x04U; hadc1.Init.DiscontinuousConvMode = ENABLE; hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START; hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE; hadc1.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DMA_CIRCULAR; hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED; hadc1.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE; hadc1.Init.OversamplingMode = DISABLE; HAL_ADC_Init(&hadc2) ; HAL_ADCEx_Calibration_Start(&hadc2, ADC_CALIB_OFFSET, ADC_SINGLE_ENDED); HAL_RCC_BDMA_CLK_ENABLE(); HAL_RCC_ADC3_CLK_ENABLE(); hadc3.Instance = ADC3; hadc3.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV10; hadc3.Init.Resolution = ADC_RESOLUTION_16B; hadc3.Init.ScanConvMode = ADC_SCAN_ENABLE; hadc3.Init.EOCSelection = ADC_EOC_SINGLE_CONV; hadc3.Init.LowPowerAutoWait = DISABLE; hadc3.Init.ContinuousConvMode = ENABLE; hadc3.Init.NbrOfConversion = 0x04U; hadc3.Init.DiscontinuousConvMode = ENABLE; hadc3.Init.ExternalTrigConv = ADC_SOFTWARE_START; hadc3.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE; hadc3.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DMA_CIRCULAR; hadc3.Init.Overrun = ADC_OVR_DATA_PRESERVED; hadc3.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE; hadc3.Init.OversamplingMode = DISABLE; HAL_ADC_Init(&hadc3) ; HAL_ADCEx_Calibration_Start(&hadc3, ADC_CALIB_OFFSET, ADC_SINGLE_ENDED); hdma_adc1.Instance = DMA1_Stream0; hdma_adc1.Init.Request = DMA_REQUEST_ADC1; hdma_adc1.Init.Direction = DMA_PERIPH_TO_MEMORY; hdma_adc1.Init.PeriphInc = DMA_PINC_DISABLE; hdma_adc1.Init.MemInc = DMA_MINC_ENABLE; hdma_adc1.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD; hdma_adc1.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD; hdma_adc1.Init.Mode = DMA_CIRCULAR; hdma_adc1.Init.Priority = DMA_PRIORITY_MEDIUM; hdma_adc1.Init.FIFOMode = DMA_FIFOMODE_DISABLE; HAL_DMA_Init(&hdma_adc1); __HAL_LINKDMA(adcHandle,DMA_Handle,hdma_adc1); / DMA1_Stream0_IRQn interrupt configuration / HAL_NVIC_SetPriority(DMA1_Stream0_IRQn, 4, 0); HAL_NVIC_EnableIRQ(DMA1_Stream0_IRQn); hdma_adc1.Instance = DMA1_Stream1; hdma_adc1.Init.Request = DMA_REQUEST_ADC2; hdma_adc1.Init.Direction = DMA_PERIPH_TO_MEMORY; hdma_adc1.Init.PeriphInc = DMA_PINC_DISABLE; hdma_adc1.Init.MemInc = DMA_MINC_ENABLE; hdma_adc1.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD; hdma_adc1.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD; hdma_adc1.Init.Mode = DMA_CIRCULAR; hdma_adc1.Init.Priority = DMA_PRIORITY_MEDIUM; hdma_adc1.Init.FIFOMode = DMA_FIFOMODE_DISABLE; HAL_DMA_Init(&hdma_adc2); __HAL_LINKDMA(adcHandle,DMA_Handle,hdma_adc2); / DMA1_Stream1_IRQn interrupt configuration / HAL_NVIC_SetPriority(DMA1_Stream1_IRQn, 4, 1); HAL_NVIC_EnableIRQ(DMA1_Stream1_IRQn); hdma_adc3.Instance = BDMA_Channel0; hdma_adc3.Init.Request = BDMA_REQUEST_ADC3; hdma_adc3.Init.Direction = DMA_PERIPH_TO_MEMORY; hdma_adc3.Init.PeriphInc = DMA_PINC_DISABLE; hdma_adc3.Init.MemInc = DMA_MINC_ENABLE; hdma_adc3.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD; hdma_adc3.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD; hdma_adc3.Init.Mode = DMA_CIRCULAR; hdma_adc3.Init.Priority = DMA_PRIORITY_MEDIUM; hdma_adc3.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
__HAL_LINKDMA(adcHandle,DMA_Handle,hdma_adc3); / DMA interrupt init / / BDMA_Channel0_IRQn interrupt configuration / HAL_NVIC_SetPriority(BDMA_Channel0_IRQn, 4, 2); HAL_NVIC_EnableIRQ(BDMA_Channel0_IRQn); /**
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc) {
} void DMA1_Stream0_IRQHandler(void) { HAL_DMA_IRQHandler(&hdma_adc1); } void DMA1_Stream1_IRQHandler(void) { HAL_DMA_IRQHandler(&hdma_adc2); } /**
HAL_DMA_IRQHandler(&hdma_adc3); } |
研讨会送了一块NUCLEO-H7S3L8开发板,今天测试外部Flash有问题, 代码能下载进去,但加载不了代码
STM32U575 按照历程配置了ADC,参考电压采用默认,Vrefe和VADDA短接,3.3V。ADC引脚有1.8v,读取的结果为0。
STM32H747 的BOOT1 是哪个管脚?datasheet 里面只有BOOT0。
STM32IDE如何设定代码到ITCM中运行。
求一份STM32H723 SDMMC1 4线驱动SD卡的 CUBEMX例程或者教程
空项目有这个报错,跳线帽没有错,是官方的新板子,
STM32F723ZET6使用ADC捕获标准正弦波并通过USB主动上报,正弦波重新拟合后存在凹陷峰?
在其他电脑上编译成功没有错误并且能够烧录,换了电脑之后编译出现一堆错误,并且不能烧录程序
STM32H750B-DK 板载STLINK 无程序
ART-PI H750-USB-MSC 设备描述符异常
芯片是STM32H750VBT6.ADC分频得30 就是ADC3.回调函数不能正常工作,ADC1,ADC3回调函数能正常工作;
