【经验分享】STM32 printf 函数原型
STMCU小助手 发布时间:2022-2-2 18:00
在STM32工程中调用printf函数,需要加入如下代码:
  1. <div align="left">#ifdef __GNUC__
    & _/ V7 [5 u: n6 _" W0 ^
  2.   /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf9 V% V  \, s, }* s0 {3 E1 U$ g
  3.      set to 'Yes') calls __io_putchar() */& s! O' r5 A- E4 z  \8 ]! V; N
  4.   #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
    . q; T& _1 d3 e+ W! T
  5. #else3 Q( l+ `9 W% l: E+ k4 q
  6.   #define PCHAR_PROTOTYPE int fputc(int ch, FILE *f)6 l) z, v! r: r7 M
  7. #endif /* __GNUC__ UT*/( f( Y/ `' n9 {3 K
  8. </div><div align="left">void Printf_Init(void)
    1 h( e+ y1 I7 }( y
  9. {
    ! X' A% I8 T/ Y7 j3 [1 @
  10.   /*!< At this stage the microcontroller clock setting is already configured,' L; i3 S( o& N$ r
  11.        this is done through SystemInit() function which is called from startup. J: E) w- \; e- V0 |
  12.        file (startup_stm32f10x_xx.s) before to branch to application main.  k1 m5 d/ c) _4 c0 y
  13.        To reconfigure the default setting of SystemInit() function, refer to0 l( b2 }) w. u' k. U& V9 _
  14.        system_stm32f10x.c file
    + u' y6 S/ \9 s( h
  15.      */
      i: n& r" w) Y7 ~2 F; Z
  16.        + ]  i+ ?$ x+ q
  17.   /* USARTx configured as follow:3 |- Y3 _$ K+ j  P& X4 Q: i0 _
  18.         - BaudRate = 115200 baud  # v" e. V6 Y0 d7 Y4 @
  19.         - Word Length = 8 Bits
    5 X3 s; G& c2 S( l+ c
  20.         - One Stop Bit
    7 {8 t1 s" g9 A* k
  21.         - No parity
    3 q6 D5 q7 W0 r4 c: \
  22.         - Hardware flow control disabled (RTS and CTS signals)2 j  l2 |- Z$ z* l- p- b. b( {( f
  23.         - Receive and transmit enabled
    . b  n* T$ w) z
  24.   */" ]' V4 y9 K2 t
  25.   USART_InitStructure.USART_BaudRate = 115200;- z! P! r7 E2 J" W' [. q% \! l" h
  26.   USART_InitStructure.USART_WordLength = USART_WordLength_8b;/ h5 E7 Z$ Q, j3 j* ~
  27.   USART_InitStructure.USART_StopBits = USART_StopBits_1;
      b, g3 j: w' c
  28.   USART_InitStructure.USART_Parity = USART_Parity_No;( t/ W6 A) D4 }; J" w2 {
  29.   USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;& _( ~0 D+ c% e$ r+ N
  30.   USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;* [9 R4 i% ?" G3 n
  31. ; C' q/ V, R  m' s5 H+ Y
  32.   STM_EVAL_COMInit(COM1, &USART_InitStructure);. i- o/ N' E, W# J4 x
  33. 2 l6 c! w/ c2 a: ~
  34.   /* Output a message on Hyperterminal using printf function *// z- ~# q# W- N5 J
  35.   //printf("\n\rUSART Printf Example: retarget the C library printf function to the USART\n\r");<div align="left">//  printf("\r\n\n\n <a href="http://WWW.ARMJISHU.COM" target="_blank">WWW.ARMJISHU.COM</a>  %s configured....", EVAL_COM1_STR);</div><div align="left">//  printf("\n\r ############ <a href="http://WWW.ARMJISHU.COM" target="_blank">WWW.ARMJISHU.COM</a>! ############ ("__DATE__ " - " __TIME__ ")\n\r");</div>}# q/ i+ g# y( Y, U# K2 d( {- G
  36. 8 x6 J( X/ {2 a0 t+ F8 Z
  37. /**
    : ~( }8 Q$ ]( N' ~) X/ X
  38.   * @brief  Retargets the C library printf function to the USART.
    : x5 ]/ V+ Z( i7 u
  39.   * @param  None
    3 t% G0 Q. y* Z& z
  40.   * @retval None
    + ~! }/ x8 P/ O, p. P4 D
  41.   *// X9 G% H9 m# D  a1 c( N5 D2 a2 j
  42. PUTCHAR_PROTOTYPE
    : Z0 }! D7 s3 [
  43. {
    4 ]- ]7 C, E; k9 F
  44.   /* Place your implementation of fputc here */
    ; f3 Z  ]; f2 \% U4 _
  45.   /* e.g. write a character to the USART */
    7 {2 H* W6 C& Q3 |$ B0 R  h
  46.   USART_SendData(EVAL_COM1, (uint8_t) ch);
    , r  I* U3 w! |
  47. ) `0 R( r/ Y. |
  48.   /* Loop until the end of transmission */
    & o) d5 v! h; V- L: H, L
  49.   while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)8 Z' m" w9 b% V& L$ T3 s
  50.   {}
    / b1 M# u9 S# ?5 S% e
  51. 9 y: g& D/ \7 w2 z2 v. b- t
  52.   return ch;6 o( ^+ q4 R* f$ D- p9 M
  53. }</div>
    $ ?& l, A1 O+ }9 u- e0 e
& t7 h, {( V5 Z% L( x" t- [5 B. W
赞 收藏 评论0 发布时间:2022-2-2 18:00
