STM32F407ZGT6 芯片无法写入擦除程序 Error: Mass erase operation failed.Please verify flash
Kong先生 提问时间:2023-5-13 15:19 / 未解决
使用STM32CubeProgrammer可以连接到芯片,但是不能擦除
  15:17:06 : STM32CubeProgrammer API v2.12.0 | Windows-64Bits
  15:17:10 : ST-LINK SN  : 390A070A2416303030303032
  15:17:10 : ST-LINK FW  : V2J41S7
  15:17:10 : Board       : --
  15:17:10 : Voltage     : 4.70V
  15:17:10 : SWD freq    : 4000 KHz
  15:17:10 : Connect mode: Under Reset
  15:17:10 : Reset mode  : Hardware reset
  15:17:10 : Device ID   : 0x413
  15:17:10 : Revision ID : Rev Y
  15:17:10 : Debug in Low Power mode is not supported for this device.
  15:17:11 : UPLOADING OPTION BYTES DATA ...
  15:17:11 :   Bank          : 0x00
  15:17:11 :   Address       : 0x40023c14
  15:17:11 :   Size          : 4 Bytes
  15:17:11 : UPLOADING ...
  15:17:11 :   Size          : 1024 Bytes
  15:17:11 :   Address       : 0x8000000
  15:17:11 : Read progress:
  15:17:11 : Data read successfully
  15:17:11 : Time elapsed during the read operation is: 00:00:00.007
  15:18:01 : MASS ERASE ...
  15:18:01 : Error: Mass erase operation failed.Please verify flash protection
使用最新版本的STM32CUBEIDE 调试STM32F407ZGT6单片机报错信息
STMicroelectronics ST-LINK GDB server. Version 7.3.0
Copyright (c) 2023, STMicroelectronics. All rights reserved.
Starting server with the following options:
        Persistent Mode            : Disabled
        Logging Level              : 1
        Listen Port Number         : 61234
        Status Refresh Delay       : 15s
        Verbose Mode               : Disabled
        SWD Debug                  : Enabled
STM32_SystemReset(), failure reset target.
Waiting for debugger connection...
Debugger connected
Debugger connected
                       STM32CubeProgrammer v2.13.0
Log output file:   C:\Users\John9\AppData\Local\Temp\STM32CubeProgrammer_a12424.log
Board       : --
Voltage     : 3.14V
SWD freq    : 4000 KHz
Device ID   : 0x413
Revision ID : Rev Y
Device name : STM32F405xx/F407xx/F415xx/F417xx
Flash size  : 1 MBytes (default)
Device type : MCU
Device CPU  : Cortex-M4
BL Version  : 0x91
Memory Programming ...
Opening and parsing file: ST-LINK_GDB_server_a12424.srec
  File          : ST-LINK_GDB_server_a12424.srec
  Address       : 0x08000000
Erasing memory corresponding to segment 0:
Erasing internal memory sectors [0 2]
Error: failed to erase memory
Encountered Error when opening P:\Program\STMicroelectronics\STM32CubeIDE\STM32CubeIDE\plugins\com.st.stm32cube.ide.mcu.externaltools.cubeprogrammer.win32_2.0.600.202301161003\tools\bin\STM32_Programmer_CLI.exe
Error in STM32CubeProgrammer
Shutting down...
Exit.
赞 收藏 评论4 发布时间:2023-5-13 15:19
4个回答
butterflyspring 回答时间:2023-5-14 21:18:34
用cubeprogrammer 工具连上后,能读取FLASH 和 option byte 的内容么?如果能读取的话,重点检查一下option byte的内容是否正常。
xmshao 回答时间:2023-5-15 09:46:14
根据提示,你用STM32CubeProgrammer连接下,看看芯片是否被读、写保护。
再就是检查下是否有连接方面的问题,当然连接有问题的话,连STM32CubeProgrammer也会反映出来。
余森茂 回答时间:2023-7-29 23:16:00
你好,请问你的问题解决了吗,我也出现了这个问题。
