STM32H7的LSE起振问题
使用STM32H7A3的FMC接口驱动LCD 是否可以用DMA传输数据
CubeMX再次生成代码时中文注释出现乱码,如何解决?
stm32h743 lan8720 cube配置lwip无法ping通
STM32G431 ADC只有软件触发,无法通过硬件触发
在stm32cubeAI上,打开Lanuch NeuralNet Studio提示打不开
型号相同,尾椎不一样
能修改Cube MX 存放文档资料的文件夹吗?
stm32cubmx2是否有计划推广到其他stm32芯片使用?
请问有没有人见过这样的报错
static void MX_TIM3_Init(void){
// USER CODE BEGIN TIM3_Init 0
// USER CODE END TIM3_Init 0
TIM_ClockConfigTypeDef sClockSourceConfig = {0};
TIM_MasterConfigTypeDef sMasterConfig = {0};
TIM_OC_InitTypeDef sConfigOC = {0};
/* USER CODE BEGIN TIM3_Init 1 */
/* USER CODE END TIM3_Init 1 */
htim3.Instance = TIM3;
htim3.Init.Prescaler = 71;
htim3.Init.CounterMode = TIM_COUNTERMODE_UP;
htim3.Init.Period = 9999;
htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
htim3.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
if (HAL_TIM_Base_Init(&htim3) != HAL_OK)
Error_Handler();
sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
if (HAL_TIM_ConfigClockSource(&htim3, &sClockSourceConfig) != HAL_OK)
Error_Handler();
if (HAL_TIM_PWM_Init(&htim3) != HAL_OK)
Error_Handler();
sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
if (HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig) != HAL_OK)
Error_Handler();
sConfigOC.OCMode = TIM_OCMODE_PWM1;
sConfigOC.Pulse = 800;
sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
if (HAL_TIM_PWM_ConfigChannel(&htim3, &sConfigOC, TIM_CHANNEL_2) != HAL_OK)
Error_Handler();
// USER CODE BEGIN TIM3_Init 2 /
//USER CODE END TIM3_Init 2 /
HAL_TIM_MspPostInit(&htim3);
然后 加上PWM启动函数:
HAL_TIM_PWM_Start(&htim3,TIM_CHANNEL_2);
